Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Need to replace the brush belt on Bissell Proheat Pet Model 8910
Replace brush belt bissell pro heat Have cap off and can not find the access to remove the pully to put the belt around it.
reddevil6
  • 1673 Answers
SOURCE: need to download users manual/how to install brush belt
http://bissell.com/images/UserGuides/7901.pdf
same as 8901
Posted on Jan 17, 2008
reddevil6
  • 1673 Answers
SOURCE: Bissell Proheat
Things to check are the cord, switch, and the motor.
Posted on Mar 20, 2008
  • 5 Answers
SOURCE: I have the bissell pro
turn dial on bottom front on the water tank to floor not tools..p.s. they only rotate when you push forward then pull back, manual motions... hope thats it
Posted on Feb 19, 2009
tooltech75
  • 80 Answers
SOURCE: bissell proheat model 8910 water will not come
  • check pump belt
  • seat tank properly
  • check tank filter
i have repaired many of these and found that 90% of the time its the pump! #41 on diagram < click
9% its the heater clogged up #65 on diagram < click
1st check the small problems i wrote above
if all else seems fine start by removing the heater and disconnect the hoses from it. blow through one end of the heater (should be no restriction)
Posted on Oct 08, 2009
heatman101
  • 43501 Answers
SOURCE: Bissell ProHeat, Brush won't turn, belt fine.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dh
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
How do i replace the brush belt to my bissel pro heat carpet cleaner?
Follow the link below for belt change instructions on bissell.com.<br /> <a href="http://www.bissell.com/VideoRating.aspx?id=1555">http://www.bissell.com/VideoRating.aspx?id=1555</a>
Aug 25, 2010 | Bissell 8910 ProHeat Clear View Upright...
The brush belt has come off my Bissell 8910. Part
heatman101
tey36
Apr 18, 2010 | Bissell 8910 ProHeat Clear View Upright...
Change belt on proheat bissell 8910
I have added a link for the owners manual for your model and a link for the replacement belts you need.
8910 User Guide (PDF)
Bissell Proheat 8910 Replacement Belt
Oct 30, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Need to replace a broken brush belt on Bissell Pro Heat Model # 88910-W
easy, unscrew the bottom plate, keep in mind that most bissell shampooers have one belt longer than the other based on the left vs right side
hope this helps
Sep 14, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
160 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
