Question about Maytag Dependable Clean Top Load Washer, MAV3955EWW
Matag model MAVT546EWW washer will not spin, like a brake is holding it locked, got it to spin a little after rotating counterclockwise.
  • Maytag Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineMatag model MAVT546EWW washer will not spin - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 05, 2010
Ge washer whre5550k2ww tub wont spin
It may be the rotor position sensor. i used you tube tutorials. There are many washers that are the same, but different brand names. Matag, whirlpool, kenmore elite oasis, all the same and parts. I got lucky and a cleaning hack. It was to clean between the tob and thre shell. This is located up under where you cannot see, use a mirror and look wherr your detergent, fabric softer and bleach dispensers are. And i found a tutorial on diagnosting code that will do it for you. I think it was holding a cycle 5x for 5 seconds and it will tell you. Whats wrong, Good Luck
Jun 27, 2016 | GE Washing Machines
I have a Kenmore washer #11026002010. I am having problems with the water overfilling and not progressing to the next cycle. Would you have info on the fault codes and also the recalibration procedure
Does it sound like it wants to spin? If so more than likely the motor coupler broke causing your washer to not spin. It is one of the most common parts that fail.
Anyhow Sears is the best bet for your answers they even list all the steps needed to trouble shoot.
Model 11026002010 Kenmore Automatic washer Repair
This one is from the link above and credit to:
Natasha12,November 17, 2014
Thank you for choosing Searspartsdirect.com and being a valued member. I can certainly assist you in locating the diagnostics for your washer.
ACTIVATING THE SERVICE
DIAGNOSTIC TEST MODES
1. Be sure the washer is in standby mode
(plugged in with all indicators off).
2. Perform the following sequence of
movement using the cycle selector knob.
NOTE: AFTER RESET, sequence "a" through
"e" must be completed within 6 seconds.
RESET - Rotate cycle selector knob
counterclockwise one or more clicks
to clear sequence.
a. Rotate cycle selector knob clockwise
one click and wait ½ second.
b. Rotate cycle selector knob clockwise
c. Rotate cycle selector knob clockwise
d. Rotate cycle selector knob
counterclockwise one click and
wait ½ second.
e. Rotate cycle selector knob
clockwise one click.
?Successful activation of Diagnostic Test
Modes will be indicated by all status
LEDs (except for Lid Locked) flashing
ON and OFF in half-second intervals.
NOTE: LED names may vary between
makes and models.
FAULT CODE DISPLAY MODE (Pgs 6-7)
To access fault/error codes, perform steps 1
and 2 of Activating the Service Diagnostic Test
Modes. Turn the cycle selector knob until the
status LEDs or display correspond as follows:
?"Done" LED On, "01" Displayed on 7-segment
01
Sensing Soak Wash Rinse Spin Done
Press the START button to enter Fault Code
Display Mode. The status LEDs will flash
ON and OFF and "cl" is displayed on the
7-segment (if display exists).
1. To view last 4 fault codes:
? Turn cycle selector knob clockwise to view
fault codes in the order of most recent to
oldest. (Refer to Fault/Error Code charts
on pages 6 & 7.)
NOTE: A fault/error code will be removed
from memory if it does not reoccur after
10 consecutive wash cycles.
2. To clear fault codes:
? Turn cycle selector knob until the status
LEDs flash ON and OFF or "cl" is displayed
on 7-segment. (See figure 2, page 2).
?Press and hold START button for 3
seconds to clear all fault codes. Press
POWER to exit Service Diagnostic Mode.
You can also visit searpartsdirect.com for parts, diagrams, and repair information.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services .
Thank you for your question. Have a great day.
Jan 10, 2015 | Kenmore Washing Machines
Motor locks up when the washer tries to spin opposite direction to agitate
When rotated on the opposite direction to agitate the main pulley below the drum releases the brake in order to spin, remove the pulley and lower plastic components and check condition, when they become worn the brake is not released properly hence no rotation.
Sep 06, 2013 | Admiral AAV7000A
Amana nav5805aww washing machine won't spin
You will need to replace the thrust bearing kit. Here is the part to order.
It comes with the instructions and is an easy fix.
Oct 30, 2012 | Amana NAV5805A Top Load Washer
Image of a timing belt diagram 2004 ford escape four wheel drive
Please rate, thx.
Installation
  1. ani_caut.gif CAUTION: The camshaft must be held stationary at the hexagons with locking pliers. Do not use the alignment tool to hold the camshaft in position or damage to the camshaft may occur.
    NOTE: To loosen the camshaft pulleys, hold the camshafts by the hexagon.
    Loosen the camshaft pulleys.
    1. Remove the blanking plug from the exhaust camshaft pulley.
    1. Loosen the exhaust camshaft pulley bolt.
    1. Loosen the intake camshaft pulley bolt.
  1. NOTE: Rotate the camshafts clockwise as necessary.
    Install the camshaft alignment timing tool on the back of the camshafts.
  1. NOTE: Cylinder No. 1 is at top dead center (TDC) when the keyway is in the 12 o'clock position.
    Confirm the crankshaft position is at TDC (No. 1 cylinder) by rotating it clockwise against the alignment peg.
  1. ani_caut.gif CAUTION: Do not rotate the crankshaft; as necessary check that it is still resting against the timing pin.
    NOTE: The lug of the belt tensioner should not be hooked in the sheet metal cover during timing belt installation.
    Position a new timing belt in place.
    • Starting from the crankshaft timing belt pulley and working counterclockwise, position the timing belt in place while keeping it under tension.
  1. NOTE: Incorrect timing belt tension will cause incorrect valve timing.
    Pre-tension the timing belt.
    1. Rotate the tensioner locating tab counterclockwise and insert the locating tab into the slot in the rear timing cover.
    1. Position the hex key slot in the tensioner adjusting washer to the 4 o'clock position.
    1. Tighten the attaching bolt enough to seat the tensioner firmly against the rear timing cover, but still allow the tensioner adjusting washer to be rotated using a 6 mm hex key.
  1. ani_caut.gif CAUTION: Tension the timing belt, working counterclockwise.
    Using the hex key, rotate the adjusting washer counterclockwise until the notch in the pointer is centered over the index line on the locating tab (the pointer will move clockwise during adjustment).
  1. While holding the adjusting washer in position, tighten the bolt.
    Tighten the bolt on the intake camshaft sprocket.
    Tighten the bolt on the exhaust camshaft sprocket in three stages.
    • Stage 1: Tighten the bolt to 50 Nm (36 lb-ft).
    • Stage 2: Remove the TDC peg and the camshaft alignment timing tool.
    • Stage 3: Tighten the bolt to 115-125 Nm (85-92 lb-ft).
  1. NOTE: Install a new oil plug seal.
    Screw in the new oil plug on the variable camshaft timing assembly.
  1. NOTE: Turn the engine two turns in the normal direction of rotation by the crankshaft.
    Check the valve timing by inserting the special tools and correct the alignment as necessary.
    • Screw in special tool 303-574 and make sure that the crankshaft is resting against the special tool.
    • Insert special tool 303-465 into the camshafts. If necessary loosen the timing pulleys and correct the camshaft alignment.
    • Remove the special tools.
Jul 05, 2011 | 2004 Ford Escape
Amana washer tub rotates counterclockwise during wash cycle.
The washer has a transmission.why are you openning the top it's a safety.the transmission may need to be replaced,You may be better off getting a new or new used washer,the transmissin is very expensive
Jul 29, 2010 | Amana Washing Machines
Clothes still wet after final spin cycle
It sounds like you might have a broken belt or the belt just slipped off the pulley!
Jan 22, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Washer noy spining water out.....
First check to make sure there is nothing sticking through the holes in the basket keeping the tub from turning. (screws, nails, etc)
Next, tilt the machine back and turn the large pulley by hand. If you turn it one direction it will agitate, turn it the other direction and it should release the brake and spin the basket.
As you turn it the direction that releases the brake, you should see the brake just above the pulley raise up. If it is not pushing the brake up, you probably need a new pulley assembly.
If the brake release on the pulley is ok, the brake liner may have come apart and the brake will have to be replaced.
Post back with any questions. You can go to sears.com, click on parts, enter your model number and look at parts diagrams to get a better idea of how it is put together.
Thanks/Mike
Dec 28, 2007 | Washing Machines
Maytag Dependable Clean Top Load Washer, MAV3955EWW Logo
331 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
