Question about Uwatec Aladin Tec 2G Wrist Computer SCUBA Equipment
Button has popped out
One of my buttons has come out of my Aladdin prime wrist computer, i need to see the service manual so I can see if i am missing a part or how to fix it
thx
Hi i have windows 7 but aladdin nasira's revenge won't start do you know what i need to do?
I have Nasira's Revenge installed on Windows 7 (x64) and it works very good. The only problem is the install, you need to do it manually by finding the setup.exe file.
Jan 28, 2011 | EA - Electronic Arts Disney's Aladdin:...
I need to know how to set my 8700 calibre watch
Hi,here is a solution to help you out:
1. Pull the crown out one click.
A. Turn dial until function hand rests on "CAL"
2. Pull dial out one more click (should be all the way out)
A. hold down button "A" (top button) until the second hand completes one counter clockwise rotation (should be pointing at current month)
B. Press "A" button a second time and the Day/Leap year hand will move.
3. At this point spin the crown either backwards or forwards and watch as the Day/Leap year hand spins clockwise or counter-clockwise. The Date will adjust per each revolution.
However,you still have every reason to own the manual of your wrist watch for future references,so follow the link below to download the manual of your wrist watch;
http://www.citizenwatch.com/COA/English/settings.asp
There are so many aplications use of the manual will be manditory.
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Thanks and take care
Jun 20, 2010 | Citizen 8700 BL8000-54L Wrist Watch
I want to set the analog time on my casio watch. I read manual but when I do what it says handsetting options don't pop up.
Keep pressing the "mode" button until "HS" appears in the digital display. Then use the right side buttons to adjust the hands.
If this does not work, go to "timex.com" find your support telephone number and give them a ring.
Mar 15, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Where can I get an Aladdin Pro Nitrox data trak? Need interface cable and CD for my dive computer. Please help.
Most Scuba stores that stock Aladdin will be able to order them for you. Also you could try ebay, sometimes seen there. Hope that helps.
Feb 21, 2010 | Scuba Diving & Snorkeling
Need manual for swan steam generater iron model s15040
you have probably solved this by now but
I just got the same model new
switch on instructions as follows
press and HOLD the POWER button for 3 seconds to switch the unit on
once temperature has been reached, press and HOLD the steam button on top of the iron for up to 20 seconds
this will prime the steam pump and only has to be done once for each ironing session
the pump noise will stop once it has been primed with water
hope this helps if still needed
if you need the user guide, let me know, I'll scan it for you
Wendy
Jun 29, 2009 | Black & Decker Steam Generator SG200 Iron
Problem about "services.exe - Application Error" pop-up menu
Apparently, you computer has some unexpected software running during the startup. In order to get ride of these software, you could check your register table manualy by regedit or download this software, which will help you to find if there are any suspect software running at the startup.
files.filefront.com/sreng2zip/;8049311;/fileinfo.html
May 07, 2009 | Computers & Internet
Tag Heuer Button Popping Out
If that buttun is pushbutton, then the fixing stopwasher has come off (inside watch).
If you meen the crown (winding and setting button), then setting lever or setting lever spring is damaged or broke.
Find your nearest watchmaker as both need professional repair and parts.
Dec 22, 2008 | Tag Heuer Link Automatic Chronometer...
Strange symbol
The same thing happened to me, and here is what I found in an online user manual (but not the one delivered with my watch). Switching the Backlight On
Press the Light button and the display is illuminated for a few seconds.
After you have illuminated the display once while exercising night mode symbol (MY WORDS HERE : the "eye symbol") appears in the display. The display automatically illuminates each time you press any button or bring the wrist unit near the Polar logo on the transmitter, until you stop recording the exercise.
Sep 16, 2008 | Polar F6 Wrist Watch
MISSING HASP DEVICE DRIVER
is Aladdin hardlock device driver ?? IF its so then go to this link
http://www.aladdin.com/support/hasp.aspx
goodluck,takecare.
May 09, 2008 | Computers & Internet
Connection Problem between the LCD screen and PC board
Sometimes you can solve this sort of problem by sticking a couple of small pieces of tape on the front side of the lcd screen in places where they wont be visible on the outside - they will push the screen back onto its connections - there is quite possibly a small piece or seal that is now missing that would have done this job before. If you want to conatct polar directly for help go to this link - you can get a user manual and all the contact details for service etc. http://www.polarusa.com/Products/fseries/f6.asp?cat=consumer My advice would be to send it to them to get it fixed - replacing a battery on its own is rarely all that needs to be done to a watch when the battery runs out - it is a convenient service interval as seals need replacing, parts need checking or lubricating or cleaning etc. Hope this helps :)
Apr 15, 2007 | Polar F6 Wrist Watch
Uwatec Aladin Tec 2G Wrist Computer SCUBA Equipment Logo
87 people viewed this question
Top Uwatec Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Uwatec Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
