Question about Kenmore Dryers
We have a Kenmore 80 gas dryer that tumbles, has hot air, but takes 2 hrs to dry. Vent line is clear, but lint filter is getting lint on back side of filter as well as normal amount on correct side. The fan motor is working. Any ideas what to check next?
  • Kenmore Master
  • 494 Answers
Have you cleaned out the lint build-up from inside of the dryer yet? When you disconnect the vent from the back of the dryer, look inside the dryer. It probably have years of lint build up covering everything and needs cleaned out. You also will need to clean out the filter reservoir (with the filter removed) if you can get to it with a vacuum attachment. Be sure to unplug the cord and close the gas valve while you are working on it. Also be sure your vent flap outside is not stuck and allows hot air to open it when in use. Lastly, when you push the dryer back into place, make sure you don't squish the vent tubing if it is an expandable plastic or foil vent, which will restrict air flow and cause drying clothes to take longer. Hope this helps. Douglas
Posted on Jun 03, 2010
Partial heat
when was the last time you cleaned out the dryer and vent line?all a dryer does is move air,if the dryer hasn't been cleaned it won't dry the clothes.your model has the lint filter on top,unplug the dryer,pull it out away from the wall,disconnect the vent line from the back,now pull it out so you can work on the back,first pull out the lint filter and remove the 2 phillips screws in front of it on the top panel,now go in the back and remove the back wall,on the left side you'll see the metal duct that the lint filter slides down into,remove the 4 screws and you already removed the other 2 screws on top so now you can remove the metal duct and clean it out,vac up ant lint in the back,if you have a shop vac set it up to blow and blow out the blower wheel and the heater duct on the right side,after it's all cleaned up put it back together but don't put the 2 top screws in,after you have it back together clean out the vent line,if it's a long run i use a leaf blower,stick the leaf blower into the vent line and blow it out to the outside,just make sure the outside duct is clear,no cage or anything that will block the lint,put the vent line back on and push the dryer back,now pop the top and clean out the front of dryer,i'll send you a viideo on how to take the dryer apart.
http://www.youtube.com/watch?v=xGIG8Wo5-N4
good luck and if you know the heat is working most likely you have a block somewhere and you should do this once a year so your clothes will dry on time,if you see that it takes more time to dry your clothes this is where to start also so you don't have a dryer fire.
Nov 12, 2013 | Whirlpool LER4634J Electric Dryer
Not gettin enough heat
if the dryer is heating most likely it hasn't been cleaned out.you have to clean out the duct that the lint filter slides into and if the vent line is long remove it from the back of dryer,stick a leaf blower in the vent and blow all the lint outside,this should be done once a year and also vac out and blow out the cabinet where the motor is more so if it's gas,lint catches fire and you have an open flame in there.next time send brand name and model number off of machine you're having problems with.all a dryer does is move air,if there's a block somewhere it will take longer to dry the clothes,also if this is a gas dryer you could have bad gas coils,the coils will run for the first 15 to 30 minutes,when they get hot no more heat,when they cool down they will work again,next time you run if it's gas,start it,after 15 to 30 minutes look at the ignitor,if it glows orange but no flame the coils are bad.
May 15, 2013 | Kenmore Dryers
Gas dryer heats and runs but not drying. There is very little lint in the dryer or the vent hose running outside. It takes about 3 hrs to get the moisture out.
A lint screen plugged with fabric softener deposits can block considerable air flow. Try running without the filter for a short time to see if the dryer action improves--if it does, wash the filter in hot water and detergent--allow to dry before installing. Hope this helps!
Dec 27, 2010 | Whirlpool LGR8648 Gas Dryer
I have a kenmore gas dryer model 110.74894401. When the start button is pressed it sometimes makes a clicking sound and the dryer does not start. However, when the dryer does start it tumbles for 15-20...
how old is the dryer?sounds like the motor is bad.i see this when the owner doesn't clean out the dryer,it's not that hard to change out the motor,if it's in good shape and not to old go for it but you gotta clean the dryer out,you need to clean out the duct that the lint filter slides into,if you have a shop vac blow off all the lint on the motor and out of the heating box or tube and vac out all the lint and if the vent line is long remove it from the back of the dryer,go outside and make sure the outside vent is clear and then from the back of the dryer blow out the vent line with a leaf blower,i've seen bird nests blow out of the vent lines,you could have a fire in the dryer or the dryer will run hot and damage parts and your clothes will take a long time to dry.all a dryer does is move air,if it can't your gonna have problems,let me know what you find and how you make out,if i can help you with anything else let me know
Aug 29, 2010 | Kenmore Dryers
It takes forever to dry a load of clothes. Drum
Have you checked your vent for blockage? Over time, lint build-up in the vent and in the back of the dryer makes your drying time longer and longer. Unplug the dryer, pull it out and disconnect the vent. Using a flashlight and a vacuum, clean out the back of the dryer that connects to the vent and the vent itself. If you have a long vent line, you'll need to find a away to clean it out to clear any blockage. I use a hand-held plumbers snake that rolls up and pulls out as much length as needed. Then spin it around in the vent to knock off lint attached inside the vent tube walls. It may be easier to do this from the outside, but you can do it from the inside too. Check your outside vent cap for blockage and make sure the vent flap outside is not stuck closed. Also make sure when you push the dryer back into place, that you don't squish the vent tube, if it is made of plastic or foil. After reconnecting the vent, turn on the dryer. The air flow may blow out the lint you have dislodged with the snake. Clean out as necessary at the outside vent. I have a long vent line on my dryer, so I have do this annually. This has helped shorten my dry time every time I do it. Of course, cleaning out the filter regularly, does help too. The more often you clean the filter, the less lint that will build up in the vent . Hope this helps. Douglas
Jul 17, 2010 | Maytag MED5600TQ Electric Dryer
Not drying clothes - have heat and tumble but probably not air Kenmore 80 series dryer.
Your vent is clogged. Remove hose from back of dryer and wall. vacuum out back of dryer, dryer hose an vent pipe in wall, if it goes out at roof you will need to clean out. Moisture from dryer is getting caught in excess lint trapped in vent causing dryer not to dry.
Sep 20, 2009 | Dryers
Kenmore dryer 90 series, heats a little, but doesn't get hot and takes 3 to 4 1/2 hrs to dry a med. size load.
Check vent path from lint filter all the way to the exhaust vent to make sure it is clear. If the dryer has a wet/dry sensor it could be malfunctioning. Try a manual cycle to see if the problem occurs then.
Jul 18, 2009 | Dryers
Kenmore 64672 dryer gets hot but clothes still wet
you have a clogged wall vent or clogged dryer vent or a clogged lint trap,you are trapping all the hot wet air in the dryer and that's why it's taking so lont to dry-mike
Apr 22, 2009 | Kenmore 64672 Electric Dryer
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
Dryer not drying cloths
HI thanks for your question. the lint filter housing is full of lint. remove the lint screen. 2 screws. remove. pry top up with a flat screw driver, from the almost the corner. lift the top up. pull dryer away from the wall remove the air duct that the lint filter goes in clean out the lint. thanks the appliance doc
Oct 16, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
64 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
