Question about Haier Heating & Cooling
Transformer died, got a Packard Universal PF42440 for Heil furnac
Transformer died, got a Packard Universal PF42440 replacement transformer...son took off the dead one w/o marking where the wire's went. Seems the colors don't match up...any suggestions or a wiring diagram would be greatly appreciated.
  • 674 Answers
Look at the tranformer. It should tell you which wires are the primary side and which are the secondary side. It may have more than 2 wires on the primary so it can be used for more than 1 voltage. Now depending on what voltage the a/c uses find the wires in the a/c with that voltage on them (110v or 220v) and connect one of those 2 to the lead for that voltage on the primary and the other to the common on the primary. Next the secondary side should have 2 wires, probably yellow and blue but maybe not. I don't know the color of the wires in your a/c but one leg of the primary usually connects to a red wire and the other to a blue wire that probably come from a ciruit board or thermostat. Make sure you do not connect 110/220 to the wires for the low voltage side. If this doesn't help let me know what color the wires in your unit are and we can go from there.
Posted on Jun 04, 2010
R-9H84B. It just stopped working.Went to use it and nothing , thought it was unplugged. Repair man replaced the 20 amp fuse and it immediately blew. He said it was the transformer.Is it transformer?
It could be the transformer. Is it generating any smoke? They usually burn up because of shorted windings.
If the fuse blew, however, when the door was opened or closed, then you have a bad door switch.
If the unit heats, and the fuse blew after a few minutes, then you could have a weak fuse holder.
Jan 12, 2017 | Microwave Ovens
I have a Reznor CUAU 400furnace that will not light. The 24vac transformer was bad, replaced but furnace will not light
Possible voltage spike took out your transformer and might have taken out something else? don-ohio
Dec 16, 2016 | Heating & Cooling
Amana furnace. How do I replace a 4-wire transformer with a 6-wire?
The new transformer should have a description on the side or top. Like: Com, Color, Volt. For example, say you have `120 volts, com-white, black wire - 120 Volts. Make sure you carefully read which wires to use or have a tech come out.
Nov 12, 2015 | Heating & Cooling
Before we replaced our furnace, I had to replace the transformer almost every year. When the new furnace was installed last year, the transformer disappeared. Now with winter coming on, the 550 hasn't
Hello, seems like there is no way to turn on the humidifier. There would either need to be a new transformer installed, a current sensing relay, or a sail switch to activate the humidifier when the blower motor kicks on.
Nov 22, 2011 | Aprilaire 550 Humidifier
We have a SV168n-36 Spagna Vetro Range Hood and it works well but the lights are having problems now. They only come on intermittently and when they do come on once they heat up they shut back off.
I had the exact same problem with my Spagna Vetro hood. The fan worked fine, but the lights started working intermittently and then stopped working altogether. The problem in my case was a failed transformer, which sits between the power switch and the lights and is necessary to step-down the voltage from conventional 120v to 12v to support the halogen bulbs in the unit. Although there are several steps to resolving the problem (replacing the transformer), it's really not difficult. Here's what I did to solve the problem:
1) Shut off the circuit at the breaker (always very important :^) )
2) Removed the glass arch from the top of the hood. Four screws hold it in place and are accessed from above the unit.
3) Removed the access panel above the fan and light switches. This panel is visible underneath the glass arch, when the glass arch is removed. I slid the lower section of the decorative stainless chimney cover upward to gain complete access to the back two screws of this panel.
4) I unplugged the original transformer from the light on/off switch (connected with two yellow wires on my unit). Remove the wire-nuts and disconnect the 12v leads from black and white wires that connect the transformer to the halogen bulb fixtures.
5) Using a flat-head screwdriver, I pried the transformer off the metal surface to which it was adhered with double-stick tape. This was strongly adhered and took a bit of prying.
6) Found a replacement step-down electronic transformer at the hardware store. My hood takes only two 10 to 20 watt bulbs, so only a small transformer is required. The original one I removed was rated to 70 watts max. I replaced it with a transformer rated to 60 watts max. Either was more than sufficient to cover the 20 watt load produced by my two 10 watt bulbs. Cost of the replacement was about $15.
7) Connected the replacement transformer to the hood power switch. Here, I had to be a little careful to maintain the original polarity of the wires from the switch. This is because the original transformer, though it had one white and one black wire on its 120v side, was attached to the switch via two identical-looking yellow wires, using a non-standard plastic connector. The new transformer did not have one of these connectors on its 120v input wires (black and white), and I wanted to make sure that the I wired the replacement exactly as the original had been wired. Fortunately, the original plastic connector ensured a consistent polarity. When I looked at the end of the connector, one lead was square and one lead was round and noted that the square lead had been attached to the White wire on the original transformer. The replacement transformer also had a white and black wire for its 120v side. So, I marked the yellow wire from switch that attached to the white wire through the square lead. Then, I cut off the plastic connector from the yellow wires, stripped the sheathing from them about 1/4 inch, and attached the white wire from the new transformer to the previously marked yellow wire, using a small wire nut. I then connected the black wire from the transformer to the remaining yellow wire in the same way.
8) On the 12v side of the transformer, the wires are the same color and I did not pay close attention to polarity, simply connecting each to the spliced wires leading to the halogen bulbs (that I exposed when I removed the wire nuts from them in step 4, above) using fresh wire nuts.
9) The double-stick tape that attached the original transformer to the hood remained firmly attached to the metal surface of the hood and it was still very tacky on the surface that had been attached to the original transformer. So, after I tidied up the wires in the space, I positioned the new transformer over the tape and pressed it down firmly, which seemed to adhere the new transformer to the hood pretty well.
10) With the connections completed, and power restored to the circuit at the breaker, the lights worked fine, and the fan continued to work fine. I reversed the steps I used to expose the switch and transformer.
So that's all there was to it. The cost of parts was about $20 for the transformer and a bag of wire nuts. Investigating the problem probably took more time than the actual repair, which took about 20 minutes from start to finish.
Aug 03, 2011 | Euro-Kitchen SPAGNA VETRO 198D-36...
We have a model B40 that seems completely dead. It was working earlier today and now we have no lights or sound at all. We have tested the plug and it's fine with another appliance. We had this...
One problem could be the thermal fuse. The hard part was taking the darned thing apart. I couldn't find the replacement part, but I did find an alternate replacement. The NTE8020 is a good substitute. I just ordered one from Mouser for $6.25.
After installation and first test all went well. The next morning however had revealed it died again.
Round two.
So by this time I'm confident the transformer is getting warm, though 130F isn't really hot for a transformer (which is the limit of the thermal fuse). So instead of replacing the fuse again with a higher value, I decided to simply install a switch in place if the thermal fuse. I only turn on the unit to make my coffee/tea so there's no time for the transformer to get too hot. It has been running great for 3 months now.
Jul 22, 2011 | Keurig Elite B40 Coffee Maker
Power died. TV was running then there was a short hiss followed by a pop and the tv died. Is it just a power unit problem. ie like replacing a computer CPU when it dies.
No,more complicated than that.The whole 2 ICS set of chips,must be replaced,near the FBT-the Flyback transformer,that the big block of plastic with a red wire with a cap hook into the CRT-(tv tube).The out wall of the FBT-the flyback transformer the "H" horizontal transistor output probally dead too.Require replacing too.Now analongue tvs are defective,components parts are not much available anymore,if the analogue tvs are more than five years old.Time to upgraded to a HD tvs.
May 24, 2011 | Televison & Video
The 24v transformer died in my Pentair MiniMax NT. How do i get a replacement? It is a Bestwill Model BC091802 Thanks, Patrick
To replace the dead transformer use a Packard Inc. transformer part number PF42440. This should be available at most heating/ AC companies and if this model is not available cross reference it to a model they sell. The installation is simply install the connectors from the heater, mount it, and plug it in. The installation took about ten minutes and the unit works fine with this transformer. There is nothing special about the Minimax transformer and the cost was $15.00 for the replacement unit.
Apr 01, 2010 | Pentair Minimax NT Heater
Heating & Cooling Logo
881 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
