Question about Xerox WorkCentre M-24 Color Copier
I used tranfer paper on the Xerox Workcentre 7345, have i caused major damage?
    Guru:
  • 1,049 Answers
It's possible, transfer paper can melt to the fuser roller, the drum, and other rollers in the printer and leave them sticky and unusable. Problems can manifest right away, if the plastic crud left behind is think. Or they can manifest several days later as toner turns the clear melted plastic black.
If several days later your still running, you're probably safe.
Posted on Jun 04, 2010
Xerox 7345 error 008-164 paper is folded with jams and 008/164
That error indicates that the paper was not sensed as passing the pob sensor which is right at the registration rollers. If the paper is folding there, the main cause is the registration clutch not being initialized or slipping. Replace registration clutch, part number: 121K22220
http://www.iteminconline.com/121k22220_121k22220-xerox-7760-registration-clutch.htm
Mar 25, 2016 | Xerox Workcentre 7345 Printer, Copier,...
WorkCentre 7345 Fuser Assembly replace soon showing. please how i reset this
Replace the fuser assembly.
The fuser melts the toner ink onto the paper.
As such, it's a vital part of the printing process.
Mar 25, 2015 | Xerox WorkCentre 7328 7335 7345 7346...
Error 007-276 xerox
  • Check that the paper size setting is correct
  • Check the switch actuators on Tray 3, for wear or damage. Repair or replace as required
  • Check the Tray 3 Paper Size Sensor for damage or incorrect mounting
Dec 28, 2013 | Xerox WorkCentre 7228 7235 7245 7328 7335...
How do i reset my drum for xerox workcentre 7345
You can't reset the drums counter on the machine. The drum has what they call a CRUM on it. It's the micro chip on the drum frame. You can buy new CRUM's or use one that still has some life on it. Press the two plastic retainers to remove the CRUM.
Nov 30, 2012 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Xerox 7328 error code 026-717
Make sure the DNS info is properly configured.
http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html
Jun 23, 2012 | Xerox Workcentre 5225 / Copier, With...
How do I clear fault code 016-311 for workcentre 7345
That error indicates the scanner is not installed. Check the connection from the scanner to the main ess board and reseat if necessary. If cable is damaged, replace with part number 117K38440.
http://www.iteminconline.com/117k38440_117k38440-xerox-workcentre-7425-iit-controller-cable.htm
Mar 12, 2012 | Xerox WorkCentre M128 Copier
Xerox WorkCentre M-24 Color Copier Logo
237 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
