Question about Magic Chef CAV4000 Top Load Washer
Leaking oil out of drum
Its leaking oil all over my clothing
Loud noise when spinning black marks on clothes leaves drum circle marks on clothes
it sounds like the bearings have gone ...are the marks on clothes oil marks ? or grease marks ? this is a sign of bearings. if there rubber marks it will be your door seal thats gone ( dose it leak )
May 05, 2015 | Beko Washing Machines
Brown streaks on laundry. possible loose drum?
It may be correct. This may also be caused by oil leaking from the washer machine. Perhaps the heat is burning the clothes leaving the streaks.
The common cause of this issue are oil leaks.
Dec 27, 2010 | Frigidaire FGQ332ES Gas Dryer
MY Estate TGDX640JQ Gas Dryer PROBLEM IS AS FOLLOWS ALL THE CLOTHING GOT BLACK SPOTS ALL OVER (DOESNT COME OUT ) SOMEONE SAID ITS FROM THE DRUM! ANY ADVICE?
It could be your washer leaking oil into the tub
Check paddles inside dryer drum for looseness if something oily got under
the paddles it will leak onto the clothes
Check felt strip at the back (and front) of the tub if it came off it could transmit junk into your dryer
if this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 02, 2010 | Estate TGDX640JQ Gas Dryer
Small flecks of dirt on clothes
If its noisy too then sounds like drum bearings gone / leaking oil/grease...
Apr 12, 2010 | Washing Machines
The washing machine leaked out transmission oil when it was tipped. Now it is sqeuking.
If it leaked oil or grease out for any reason, this is a serious problem and it's time for this machine to be replaced. It has grease in the transmission that is sealed with no way to leak unless it is worn out. If it leaked then this grease will get inside the drum and your clothing will be contaminated.
Oct 09, 2009 | Washing Machines
Frigidaire front load washer GLTF1240AS0 - noisy and leaves dirt/oil on clothes in dotted pattern (so dirt being put on thru drum at final spin?). Could it be oil leak? bearing?
good call.....
your bearing is leaking into the machine
you can verify this by simply removing the back
if the side walls are covered in ablack spray pattern
sometimes it does not leak on both sides (in and out) but if it is leaking your machine will get progressive louder in both aggitate and spin
Oct 09, 2009 | Frigidaire GLTR1670A Front Load Washer
My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Aug 02, 2009 | Washing Machines
Oil inside drum
Sometimes if your transmission is leaking oil it can creep inside the tub, tilt the machine back if you see oil underneath it then you"ll know if you have a leaking transmission.
Jul 16, 2008 | Kenmore 23822 Top Load Washer
Transmission oil is leaking into the basket of wash and staining clothing. the unit is 3 years old. repair service said to contact you for repairs since it is covered for 5 years.
sounds like the water seal in front of the drum bearings has failed causing grease from the bearings to get into the washtub this is usually accompanied by noisy spin cycle and rumbling noises from the drum when it is turning
Jul 15, 2008 | Whirlpool Washing Machines
Magic Chef CAV4000 Top Load Washer Logo
16 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
