Question about Fire Magic 11-S1S1N-A Stainless Steel Gas Grill
Need to manually light the grill as the starter is not working
  • 494 Answers
Is the igniter sparking? Some are battery powered-check the battery or replace it. If you have a standard push button piezzo igniter or a rotary styleneed to manually light the grill as the starter is - 2_bing.gif igniter, check for spark. Can you hear or see the spark? It's hard to see the spark in bright daylight. It's easier to view the spark at dusk or dawn. It should spark an "arc" at the burner. If not, adjust it if necessary. The igniter wire may have a short, causing the spark to arc somewhere else along the wire and not at the burner. Replace igniter wire. It's also possible the igniter tip where it sparks has a cracked or broken porcelain portion of the igniter, causing the spark to not arc at the tip where it's supposed to. Replace the igniter piece.
Hope this helps! Douglas
Posted on Jun 03, 2010
Grill light has stopped working.Replaced batts with new. still no light???
If it starts okay with a long match or fire starter, you'll need to replace the starter button. You can Google your model number for the part.
Nov 14, 2017 | Grilling
The starter button will not push down. Grill works with manual lighting
didnt specify unit--generic answer - they break order a new one most hardware / stores that sell outdoor products have a universal replacement
Jun 03, 2017 | Grilling
Burner not working
Traeger Industries burner not working Grills & Smokers ...
www.fixya.com > Forum > Tags > burner not working > Grills & Smokers
Traeger Industries grills & smokers burner not working related questions and answers. Ask your ... Question about BBQ075 All-in-One Grill / Smoker. 1 Answer ...
Traeger Industries water pump not working Grills & Smokers ...
www.fixya.com > ... > Tags > water pump not working > Grills & Smokers
Traeger Industries grills & smokers water pump not working related ... Question about BBQ075 All-in-One Grill / Smoker ... our auger stopped working how can we fixthis. it is not the electrical .when you put pellets in the burner it will light and ...
Support - Traeger Wood Pellet Grills
www.traegergrills.com/support.html
Traeger Pellet Grills, LLC. ... Why won't my grill light? ... Why is my grill running so hot on smoke? .... Large Commercial Trailer. Download manual. View All ...
FAQS - Traeger Wood Pellet Grills
Jan 01, 2016 | Traeger Industries BBQ075 All-in-One Grill...
Starter clicks but won't light
Let the gas run a few seconds before clicking (and stand back). If that doesn't work, you may need to replace the starter.
Feb 05, 2014 | Weber Q Grill
Why won't my Weber grill ignite after installing a
Disclaimer- be careful when working with gas. Starters in gas grills are just about novelty anymore. Often, they only light 1/3rd or 1/4th of the burners and they usually stop working within one grilling season. I recommend using a wand lighter. Try to light just one burner but if doesn't light in 5 to 7 seconds, turn the gas off and wait to try again. Incidentally, you are turning the gas on at the tank, right? You should hear it when you turn the burner on.
Apr 24, 2012 | Grilling
The electronic starter for my weber q 200 grill will not light, I am having to light it by hand?
You can purchase a generic replacement starter at Lowe's, H/Depot, W/Mart, etc.
Easy fix...
--W/D--
Feb 04, 2011 | Weber Q Grill
My silver c igniter does not work..need to manually light..burners work..is new igniter worth pruchase? grill is almost 6 years old
yes replace it. you can call weber and they will send you one FREE just tell them whats wrong and the model number of the grill
Jul 18, 2009 | Weber Genesis Silver C Grill
Starter button doesn't work. can't be pushed down so grill won't start. do I need a battery for this part?
When the igniters stop working the backs are corroded. Clean well and reinstall or replace altogether. In the meantime you can use long fireplace matches to light the burner until you are ready to effect repairs.
Apr 26, 2009 | Weber Genesis E-320 Propane Grill
Grill no longer producing good heat
read manual...possibly triggered propane safety bypass. Close tank, Turn OFF all burners, disconnect tank. Open one burner for 1 minute and turn off again. Reconnect tank. NOW OPEN tank slowly, all the way. Turn on first burner and ignite with starter or light through port hole manually. Hopefully works better.
Mar 25, 2009 | Weber Genesis E-310 Gas Grill
Electric starter doesn't work
hi my name is mark, if its like most of the battery starters unscrew the collar around the button. should be a AA battery. thanks for your question.
Feb 21, 2009 | Weber Genesis Silver A Grill
Fire Magic 11-S1S1N-A  Stainless Steel Gas Grill Logo
1,005 people viewed this question
Top Fire Magic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
