Question about KitchenAid KEHC379JSS Electric Double Oven
Touchpad has several keys that are non-functional. I replaced the touchpad, no luck. I replaced the control module, no luck. This problem occurred three years ago. Replacing the touchpad and control module solved that problem at that time. I don't have a repair manual.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems that you’ll have to replace the electronic control(part#7 in picture) in your oven.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
  • 10 more comments
  • James Canitz Jun 03, 2010
    If you'll notice in my post I already did that.
  • Rylee Smith
    Rylee Smith Jun 03, 2010
    I did noticed that however, you said you replaced the control module(part#1 in the previous diagram) not the electronic control which is part#7
    Part #1 was not mentioned in my post. Part #1 in the diagram is the SS outer plate of the display panel. In any case, lets get beyond it and agree I did replace part #7 and go forward.
  • Rylee Smith
    Please see this link and let me know which parts have you replaced.
    Part #2 and Part #7
  • Rylee Smith
    You replaced them three years back and now its giving the same issue so it should be replaced again.
    I have replaced parts 2 and 7 already. Problem is not solved.
  • Rylee Smith
    Okay, sorry I thought you replaced them three years back. If you have already replaced them then check part#6 which connects both part#2 and part#7 together as if that is bad touch pad wont respond.
    I replaced Part 2 and Part 7 under warranty three years ago.
    I have replaced Part 2 and Part 7 with new in box components about two weeks ago.
    Part 6 is an integral piece of Part 7 and comes attached as a component of Part 7. It should be new.
  • Rylee Smith
    If everything is new and its still not working then check the wire harness.
    I agree already thought of that.
    There is solid state type tape connector between the touch pad (Part 2) and control module (Part 7), that is integral to the touchpad and is new. The connector on the control module that the tape plugs into is also new.
    However that would seem to be the area where this problem would occur since it is the direct interface between the touchpad and the display imbedded in the control module.
    I would like to have a wiring diagram so I can isolate those wires that would carry the input signals.
    I can check continuity of all the wire harness of course.
    No wires appear to be disconnected or damaged.
  • Rylee Smith
    Please click on this link and download its repair manual. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Error code F2 EO oven not working
Ledgestone Technologies has replacement keypads for NO LONGER AVAILABLE Whirlpool and Kitchenaid models. Each one comes with a new ribbon cable and 2 year warranty.
Contact FixYourBoard.com for more information!
512-355-1108 info@fixyourboard.com
Nov 16, 2015 | Ovens
What s a EO F2?
The error code E0-F2 indicates that your touchpad has a stuck key. You might try disconnecting the electricity from the range and pushing and releasing the buttons on the touchpad several times. Be aware as you push them of any button that feels different. If you notice one that is stiffer or just doesn't feel like the others, give it several more pushes. Worst case scenario, you will need to replace the touchpad.
Sep 11, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
My stove is beeping and is flashing F7. What does this mean, it is a built in oven.
The F7 error code means that a function key on the touchpad is shorted or stuck, the F7 can be cleared by pushing the clear/off button,if the error code returns the touchpad would need to be replaced.
GENE
Sep 10, 2011 | GE Ovens
My stove keeps beeping and showing F1-8 on the display and telling me to call a tech. What is the problem. This slide in stove is abou 6 years old.
The F1-8 error code means that a button on the touchpad is stuck in and the touchpad needs to be replaced. The computer runs a self check on the oven several times per hour and it thinks a button on the touchpad has malfunctioned. Depending on your exact model the touchpad is a seperate peice or it has been intergrated into the control panel, so if it's seperate only it needs to be replace,if it's intergrated the whole control board needs to be replaced.
Hope this helps ya
Gene
Aug 01, 2011 | Jenn-Air Ovens
Is it easy to replace the keypanel of the GE
Hello, The simple answer is yes it's not too hard...Normally you have a couple of screw located underneath the control panel. In most mordern ovens today they just consist of 2 components, the EOC (Electronic oven control) and the touch pad which basically cosists of everything you see(the whole panel). If you are replacing the touchpad..remove screws holding old panel in...pull wire harness from control board (dont worry where they go because the will only fit in one place) remove tape from EOC and relocate the control board to the new touchpad panel...reattach wire harness and tape in the new touchpad panel and hook back on oven ..screws in and your good to go. if replacing the control board (EOC) drop touch pad panel from oven and pull wires install new control then reassemble..easy!. One thing i would check though before purchasing the part, check to see it is the touchpad and not the control board...Here is how to do it...shut breaker off...pull out control panel...remove ribbon for key pad from EOC the re install panel..go switch breaker back on. leave for 24 hours..if within the 24 hours the error messages come back it's the EOC that is bad, if the error messages do not come back then you can be sure it's the touchpad. I would check this before buying the part since they are expencive and offten non returnable. Good Luck!! If you have any other questions or concerns please feel free to comment again. Thanks for using Fixya!! Mike
Jul 24, 2009 | GE Profile JKP56 Electric Double Oven
How can i be sure that the f7 error in my ge built in over requires a key pad replacement.
Hello, I assume since you are asking about the touchpad you had an error code or the appliance just stopped working. The way to be sure the touchpad is at fault is to switch the power off and then remove the ribbon/wire harness from the touchpad to the EOC (Electronic oven control). turn the power back on. Leave for 24 hours if the error comes back it's going to be the EOC if the error does not come back then you have a bad touchpad. Hope this helps, If you have any other questions or concerns please feel free to comment again and thanks for using fixya! Good Luck. Mike
Jul 20, 2009 | Sharp R90GC Electric Single Oven
Error code F7
your problem is with the EOC (Electronic oven control) or touch pad if it is seperate from the control...if the touch pad is seperate...unplug range - access the control panel - remove the wiring/tape wire from touchpad to EOC...plug range back in...leave over night...if f7 code comes back it's the EOC...if the error code clears it's the touchpad...replace the part with the problem...if touchpad built into EOC replace the EOC. Hope this helps...if you have any other questions please feel free to comment again.
Jul 06, 2009 | GE Ovens
F-1 alrm sounding on stove
Your touchpad has a stuck key or is bad. Push all keys at random several times each. If that does not correct the problem replace the touchpad control.
Jul 04, 2009 | Maytag CWG3100A Gas Single Oven
Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 24, 2008 | Ovens
KitchenAid KEHC379JSS Electric Double Oven Logo
41 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
