Unit has power to display on door and interior light, display reads "0Ff" where temp is usually shown. cycled power on and off with plug. Do not see any switch inside or out to to unit on or off. Display panel has a quick freeze function but is not working. Does not sound like compressor or fan are coming on,
SOURCE: Fridgidaire upright freezer alarm FFU2065FW
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one of these:
The compressor,The Thermostat,The overload, relay, or capacitor,The defrost timer,The condenser fan motor.
Try to troubleshoot each of these componet one after the other using eliminating method.
That may solve your problem.
SOURCE: Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
SOURCE: upright freezer quit cooling, compressor runs,
Hi..
Try to check this
Good luck!!!
Regards
PCmania
SOURCE: Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
SOURCE: How do you get to the coils on a Kenmore Elite
you may check the internal fan, ran into that same problem tried cleaning the coils and ended up being the fan
