Question about Insignia D300a PC Desktop
Monitor gets no signal
I have an Insignia D300a Desktop comp. While using the comp. my monitor stopped working and flashes no signal on the screen, I switched the monitor with one I know is working and same thing, tried turning off comp. and restarting no luck. Could this be the video card? If so can I replace the video card with a non intergrated card even though the original is intergrated into the motherboard?
  • Anonymous Mar 16, 2014
    My PC is plugged into the wall, the VGA of my dell monitor, the monitor is on, and I start the computer. Lights and fans turn on in my PC, and the monitor is at the right channel. But the power button on the monitor turns orange meaning there is no signal. Please help!
  • 505 Answers
Yes. it is almost positively the video card.
you can get a PCI video card and install that in an open slot.
if you don't need to play games, you don't need a fancy one, just a basic card.
Posted on Jun 03, 2010
No signal gets to my monitor
have you try another vga cable?
Mar 16, 2014 | Insignia D300a PC Desktop
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Im looking for a owners manual for my D300a
http://www.devicemanuals.com/guide/Computer/Insignia/D300a-Insignia-D300a-Desktop-PC-Owner's-Manual-TnpZMU5EST.html
Click on this link Scroll down. Enter the code given there in the text box and click on download to get the owner's manual.
Hope this helps.
Jul 06, 2009 | Computers & Internet
Black screen only shows after initializing the words " error loading OS "
do a hard drive test or take it to local repair shop and get them to test it. I am about 98% sure it a bad hard drive, or you OS got deleted.
Replaced the hard drive, if its bad.
please rate my solution.
May 12, 2009 | Insignia D300a PC Desktop
Monitor Showing to much red
Is it possible that your PC or Monitor is just showing more red tones? Have you checked a WHITE background like a blank webpage? Does it have a red tint too?
Do you possibly have speakers or an external fan near your computer or your monitor? If so they sometimes have magnets that will interfere with your screen.
Another thing you might want to check is to unplug the monitor cable that attaches to the computer and check and see if any of the PINS in the plug are bent.
Please let me know how this works out for you.
Thanks,
Kaj
Dec 17, 2008 | Insignia D300a PC Desktop
Insignia D300a restore disc
go to www.restoredisks.com, you can get any restore disks that you want.
Oct 10, 2008 | Insignia D300a PC Desktop
Restore
The fact that you don't see the insignia splash screen tells me it's not looking good for your computer.
- Have you tried another working monitor with your computer? It could be your monitor died.
- Where is your monitor plugged in on your computer? To the mainboard or a graphics card? It could by your onboard graphics or graphics card has died. Try switching, if possible.
- Have you tried reseting your BIOS? You'll need to open your computer case and look for 3 small metal pins with a connector connecting to two of those pins (it should be on the lower-right hand of the motherboard when you open your case). However, depending on your computer ability, I would generally hold this off.
Unfortunately, without actually being there and without the proper equipment, there's not much I can do. If none of the above helps, then you'll need to open your computer case, and do some equipment checks, however this is only for people who have built computers before and know what they're doing. If you can get a friend thats knowledgeable in building computers to take a look at your computer, then definitely go that route.
All I can do is direct you to the product specifications of your motherboard (the D400a has a D845GVSR motherboard)
http://support.intel.com/support/motherboards/desktop/D845GVSR/
Click "Manual" under System resources and download your language version of choice. Good luck.
Apr 03, 2008 | Insignia D300a PC Desktop
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
My monitor isnt working
Motherboard Setup Defult monitor setting.
Or set the defalt for eveithing.
Nov 11, 2007 | Insignia D300a PC Desktop
Insignia D300a PC Desktop Logo
260 people viewed this question
Top Insignia Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Carlos L. Burgos
Carlos L. Burgos
Matthew Spark
Matthew Spark
Are you an Insignia Computer and Internet Expert? Answer questions, earn points and help others
