Question about Fisher and Paykel 24 in. DS-603 Built-in Dishwasher
We just purchased a used Fisher and Paykel DS 603-i. After installing and running the normal cycle there was a lot of water left on the bottom of each drawer. We ran the bottom drawer (water stil siiting on the bottom of the top drawer) and part way through the main wash cycle we got what I think was a F1 error code (we do not have the LCD version but the Rinse light was activated). I took out the bottom drawer, dried out the basin and then took out the washer and reattached the drainage pipes to the air gap on the sink (previously the drainage hoses were just placed in a drain pipe behind the washer. I ran the rinse cylce on the top and bottom drawer and there was still alot of water in the bottom of the drawers (1/2 inch or so). I am currently running the top drawer on the fast cycle and I haven't heard any draining or seen any water go through the air gap. Any ideas, any help would be appreciated! Thank you!
  • j_pickel Jun 04, 2010
    Yes, the solution was perfect! Just the advice I needed. I wish I would have found this site sooner. Thank you!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.
F1 error means that the flood switch has been activated. You’ll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
  • 4 more comments
  • j_pickel Jun 03, 2010
    I did use the hair dryer to dry out the bottom and am no longer receiving the F1 message but the washer is still not draining correctly. How high is too high to hang the hoses?
  • Rylee Smith
    Rylee Smith Jun 03, 2010
    As I said check the drain hose for any blockages and also check the flood switch that is located at the bottom of dishwasher.
    Note, I am no longer receving the error message and I checked and dried around the flood switch. I disconnected the drain hoses from the sink air break and put them into a bucket then ran the rinse cycle on both drawers. The hoses are definately draining some water which would seem to rule out a blockage in the hoses. However, after the rinse cycle there is still approximately 2 inches of water left in the bottom of the drawers. The machine is now leaking out of the bottom as well but not out of the hoses in back. Any ideas?
  • Rylee Smith
    Rylee Smith Jun 04, 2010
    Also make
    sure the dishwasher is sitting level (you can adjust the front feet up or down,
    and many units have some type of levelers at the rear). Water under the
    dishwasher may be originating from a leaky hose or loose hose connection.
    Remove the lower front panel, and check the hoses. The pump seal may be
    defective, too; replacing this is a job for an appliance repairperson. An older
    dishwasher may corrode at the bottom, but this is fairly uncommon. If this is
    the case with your dishwasher, it's time for a new one.
    Well it seems like the leveling did the trick! It was level from side to side but not front to back. I raised the back feet a bit and now it drains completely. Thank you!!
  • Rylee Smith
    Great! Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Beep continuos and cycle stops
Water flood in the base of dishwasher. Check the fault code lights. If F1 then this confirms the problem. Need to find the source of leak.
Mar 14, 2014 | Fisher and Paykel 24 in. DS-603 Built-in...
Water will not empty and beeping will not stop on Fisher & Paykel DD6051
The flood switch has turned on. There is a leak into the base of the housing. Turn mains power off. Open bottom drawer and dry the base using towels etc. Need to find the source of leak. Lid seal or hoses.
Sep 14, 2013 | Fisher and Paykel 24 in. DS-603 Built-in...
The drying function doesn't appear to be working
If water remains on the dishes after washing even when you select the normal wash modes (not ECO) then the air dryer fan is faulty assuming the water heater is working.
May 14, 2011 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
How to change a element in a Fisher and Paykel Ds 603 dishwasher
these units r very tricky to change the element. it involves pulling the wiring loom, hoses and turning it upside down to make it easier. sorry to ask u this but why r you changing the element? please reply and i can help u more.
Apr 28, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Dec 12, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Flashing F1 code, how do I fix
F1 code is water leaking. 1- Dry out the bottom housing to make the F1 disappear. 2- Replace Actuators and the lid seal to prevent this happens again. The actuators is pulling down from the left and right sides to hold the top lid against the top surface of the tube groove to seal water from coming out during the wash cycle. When actuators are bad, they can not hold the lid down or make the lid tilted to one side hence the leak is coming. When the lid is tilted for a long time the seal is distorted then it has to be replaced since it is out of tube groove shape
Dec 11, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
My Fisher & Paykel DD 603 has the fault code
Check at bottom housing both top and bottom drawers for leaks.
Pull the tube out, on the left side below the tub you can access to touch the bottom housing. Dry it out with a tower. Un plug the power cord at least 24 hor so the flood sensor can be dried out before pluggin it back.
However, if you don't fix this leak, the sam F1 problem will happen again.
There is not much clogging up in filter. If you expect something clogged up, you have to take the spraying arm off then take out the bottom stainless steel with a lot of holes out to see the impeller clean or not. Good luck.
Sep 10, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishwasher "F1 and a small wrench symbol" blinks continuously
The unit has a leak causing floor sensor activated.
1- Unplug power cord.
2- Pull oull half way the drawer so an access from the bottom left could be obtained.
3- Use Paper towel or small towel to dry out the water on the bottom housing.
4- Wait for 48 hour so the sensor can be dry out.
Plug in the power cord. The unit will act as normal.
Your problem is solved.
However you can't operate since you know you have a leak problem. Let me know how it in progress and you decide to call service to fix it or I can guide you to fix it. Good luck.
Apr 05, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Beeping fault code Fisher and Paykel DS603
Stop the unit and check to see if it's heating when it's beeping at you. eg is it warm water inside at the time? if not you may have a faulty element.
Mar 09, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher and Paykel 24 in. DS-603 Built-in Dishwasher Logo
130 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
