Question about Panasonic KX-T7736 Corded Phone (KXT7736)
Change speed dial numbers on Panasonic phone KXTGA614
    President:
  • 1,118 Answers
I've found the operating instructions for the KX-TGA641T cordless phone instead, but, unfortunately, KX-TGA614, as you have typed in, doesn't seem to exist at Panasonic's support page. Hope you have mistyped your phone model, and that this one might suit your needs,
Regards, Caroos
Posted on Jun 03, 2010
Can you speed dial on the Panasonic KX-TG4011?
This model doesn't have a speed-dial or one-touch dialing feature. It does have a phonebook feature that allows you to store up to 50 phone numbers, and you can select an entry and the phone will dial automatically. Not quite the same, but it's all that's offered. The manual gives the steps for entering names and numbers into the phonebook, and for selecting and dialing an entry.
Sep 13, 2011 | Panasonic KXTG4011 Cordless Phone
Hi I have a panasonic KX-T433 phone system which I am trying to put in speed dial numbers, we have to dial 9 to dial out does any one know how to do this using a 9 in front?
You have neither a 7730 (the category you asked in) or a 7433 phone sytem. If your phone is really a 7433, you have a TD phone system. Which "speed dial numbers" are you trying to program? System speed dials, are stored in system program 001 and consist of a 3 digit number (may be 2) with a "9" in front and the number as you would dial it from the keypad. Personal speed dial numbers depend on the button you're programming it onto. If it's a button with a light, you dial "2" in front of it. If not, you don't. So, Program 99, button, and either 29 + number STORE or 9+number STORE programs a personal speed dial.
There are other programs to store under the tone pad keys. Those features are covered in your User's manual for the TD system.
Carl
Jul 06, 2011 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone programmed speed dial numbers not working. will not dial numbers programmed
When the system is installed, you need to make sure that only the lines equipped are in the access plan (program 400 in a TA series box). When you go to the intercom on a phone and dial "9" you should get an outside line every time. If that works, system and personal speed dials include that access code as part of the number. eg my test number is 914197845522 9+1+10 digits.
Carl
Apr 01, 2011 | Panasonic KX-T7730 Corded Phone
Changing all speed dial numbers
Speed dials reside in programming memory 001. You can change them from the maintenance console software, or an extension, usually on Jack #1, operator, or the manager's phone.
From the phone, (ext 101) press PROGRAM and dial **1234. If the display says SYS PGM then dial 001 and start with your first speed dial number (3 digit, 001-999). By stepping through the ENTER key, you will be able to find the existing numbers. A trunk access code must be the first part of a speed dial number. You probably see it as the first digit "9" in front of all your numbers.
Carl
Apr 10, 2010 | Panasonic KX-T7630 Corded Phone
I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Carl
Nov 09, 2009 | Panasonic KX-T7730 Corded Phone
Having trouble entering speed dials - please help!
Not knowing the specific model of the phone system itself (the PBX cabinet in the telephone closet) I would guess you are using the "personal directory" and it only has 10 number memory and it goes from 0-9. The system directory will give you more mems.
Sep 03, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Speed Dials - Please Help!
So I guess that means you're not programming SYSTEM speed dial numbers. Those are programmed from the system manager or operator's station. Personal speed dials are 1-0 and are programmed per set.
Carl
Sep 02, 2009 | Panasonic KX-T7730 Corded Phone
How to store numbers for speed dialling on Panasonic KX-T7730 having only 12 CO buttons.
Well let's see. You have 12 CO buttons and 12 PF buttons, and at least 100 system speed dial numbers available.
Which ones are you looking for?
Depending on what Panasonic system you're connected to, the PF buttons program by pressing PROGRAM and the button, and dialing the number with a "9" or trunk access code in front of it then STORE. If you're connected to a TD system it's PROGRAM 99.
System speed dial numbers are entered from the main or manager's phone under system program 001.
Carl
Jun 28, 2009 | Panasonic KX-T7730 Corded Phone
Programming Auto Dial Number
Yep. Those are speed dial numbers. They are programmed from ext 101 or the main phone. Without picking up the handset, press PROG **1234 and dial 001 and ENTER. Dial your 3 digit speed dial number If there is something there, it will be displayed. A speed dial number is stored with the trunk access code in it (usually 9) so if you're putting in a new number, include the "9" plus the number exactly the way you dial it. Dial your new number with the access code and press ENTER.
Number changed :-)
You can keep putting in a whole boatload of new numbers with this procedure.
Carl
Mar 16, 2009 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7736 Corded Phone (KXT7736) Logo
157 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
