Question about Maytag Neptune MAH5500B Front Load Washer
Will not spin or sometimes even turn the drum. Trouble code Lr shows. Repair guy said the harness from the motor control board to motor is bad but you have to replace the whole motor control board, costs $250. From your experience, does this make sense?
  • stevemccoole Jun 03, 2010
    But does it make sense that a harness would go bad and if so why do you have to replace a $250 control panel because of a bad harness?
    Brigadier General:
  • 4,090 Answers
On checking our records for this problem I have seen that the average cost is between $280-320 to fix this error. So the quote is very much within the range I also consulted the Maytag error code book and the explanation fits with what you were told
LR usually means that the the signal from the control circuit board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first, if they are ok replace the CCU (central control unit) board, this is the board behind the touch controls.
Thanks for using FIXYA
Posted on Jun 03, 2010
  • 10,865 Answers
Hello. I have been in this repair business for a long time. His numbers are not bad. I do not recommend putting that much money into it. Shop around for a sale and get a new one with a warranty and which will use much less water and electric than the older ones do. In the long run the new one will pay for itself and it will have a warranty.
Joe
Why is my Maytag washer showing lr code again?
If you live in North Hollywood, CA and need washer repair service call us at (626) 460-0903 or visit our website Washer Repair North Hollywood CA 747 248 4544 Samsung
Sep 03, 2017 | Washing Machines
My front load washer wont spin and when the spin cycle is done the letters Lr show up as a code what does this mean
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question %$W%TR
Sep 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
It will fill with water but it won't spin or tumble in any cycle, also it will empty out in spin cycle but still won't spin,and on key pad display it shows Lr
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question $#%$#
Sep 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water is left in the drum after the cycle is over. leaves a display code Lr
Aug 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
Flashes lr willnot spin out
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question #$TWRE
Jun 02, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Have a neptune mah55lbww front load that stops after filling and does not spin out,starts leaking out of door and then rotates drum off and on about every 30 seconds for a second at a time even after...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$%#
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer says LR, im thinking locked rotar , will not spin
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question GT#%E$
Jun 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer stops midcycle with a LR showing on the digital screen
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question $%^
May 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Drum doesn't spin error code LR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question $^$W#TG
Feb 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Error code Lr
i am a appliance repair man and this is a normal problem and you need to replace your motor and motor control board sold as one unit these are 3 phases motors and one of the phases is bad. dont forget to put a surge protector on these machines because a little power surge can damage the boards maytag just figured this out because they are sending one with the new machines
Oct 11, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
15 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
