Question about Goodman CLQ36AR49 Air Conditioner
AC NOT WORKING
Already replaced capasitor
    President:
  • 1,515 Answers
Hi, you have replaced the run capacitor already. Has the outdoor unit tried to run at all? You have probably checked the main breaker already to make sure you have high voltage to the unit. If not, do this. Also, you will have a disconnect box at the unit. Some or most people don't know this, but if you remove the plastic cover in this small box, you will have 2- 30 to 35 amp fuses inside that will blow . If one is blown, it will not run. I would recommend replacing both even if only one is blown. Now, if you have had high voltage to this unit all this time, and the outdoor condenser fan motor is running but the compressor does not start, this may be your problem. I don't know unless you tell me more on what this unit is or is not doing? All I can do is give you some things to check based on what you have said. When you say you replaced the capacitor, i am thinking you have power, fan on, but no compressor? If this is the case, the compressor may have a locked rotor, or may be shorted.If you have a voltage meter, make sure you have 24 volt control voltage coming from the indoor unit to energize the contactor coil to start things in motion. If the compressor does not come on, and fan is running, make sure you have a full charge of freon in system, and its not off on its low pressure switch. You can check this switch by jumping across it from one side to the other and restoring power. If it starts and runs, shut it back off quick and you will know you have a leak and lost your charge. The switch will be around the compressor area mounted onto and silver soldered to the larger of the copper lines.It has 2-BLUE wires connected to it. The high pressure switch will have 2-RED wires to it. What works best is if you have a piece of insulated wire with to clips on each end to jump it out. Leave the existing wires on the spades, you may have to raise them up to get to metal, and connect the lead. If its out or low enough on freon and the compressor is good, the unit will fire right up. Anyway, try and check what I have asked you to do, and let me know what you have found out. Try and give me more information on what this unit is doing or not. It is a 3 ton unit, I know this. About a 14 seer. This model has been discontinued, but parts are and will always be available for it. I know this is a long solution, but I need to know as much as possible in order to help you on this. Heck, it just maybe a blown fuse? Keep me posted on this. Best of luck to you. I will be waiting to hear back.
Shastalaker7
Posted on Jun 04, 2010
Bosch wfr2460 washer not working after replacing motor with new motor- will not spin at all
Have you checked to see if it is wired correctly? Next, is there a run capasitor that goes to the moter, ir is it wired directly to the moter?
If it has a capasitor, you might need to change that. Any time you replace a motor, you always replace the capasitor with it. Let me know what you find out and we can move forward from there.
Oct 18, 2013 | Bosch Classixx WFC 2465 Front Load Washer
V203h acer lcd 20" no power,i already change all
sometime there is a main power switch on the back of some tv's. if that is not the case try replacing the power plug.
Apr 05, 2011 | Acer V203H 20" LCD Monitor
My rudd ac quit working opened panel and found black round part is blowout
Hello That is the START capasitor,disconnect it & get and install a HARD START KIT on the run capasitor.It is a simple 2 wires that plug on the run cap and will do the job of the defective factory one.
Aug 28, 2010 | Weather King 10AJA4201AH Air Conditioner
AC unit wong start unless I spin the blower
you have 2 windings that are in you motor,One winding is the start winding It give the motor its initial boost that gets the fan spinning.The other winding is the run winding and it takes over and keeps the fan running.So it sounds like the motor is bad because the start winding is not giving the boost it needs to start. good luck--Nate
Jul 15, 2009 | Coleman Mach III Air Conditioner
T.V. turns on, then turns off
Check your all capasitors of pwd supply any capasitor is lickege or short or not work poperly if you cann't find any problem replace your all capasitors of pwd supply
Mar 12, 2009 | RCA 20F410T 20" TV
Sometimes the TV comes on and works fine with no problems for weeks, other times it will not come on at all, not even a click when pressing the on/off button. Strange but seems to work ok in hot humid...
Mar 08, 2009 | Televison & Video
Mar 08, 2009 | Zenith 12vDC 800mA 20W AC Adaptor A41208...
Dryer won't turn on all of a sudden. confirmed power is okay.
Soubnds like the Start capasitor or start winding inside of the motor if it has no capasitor are going out .Replace capasitor , if it has one or replace motor if it does not. The other , less likely posibility is that the starter switch is going out. you can carefully jump out the switch with a wire from the back, when it is not working to see if it is the switch.   If it has that start capasitor i talked of they can be tested with an ohm meter. The values are printed on them. The mortor itself can also be tested with an ohm meter,but if you look at it closely or try to spin it by hand I am fairly sure you will see that it has a problem already.
Jan 07, 2009 | GE Dryers
Monitor problem....(blurry image and red flickking)
the only real soluton is to replace this monitor sounds like the red cathode is shorting out (basicly piture tube is going out.
Jan 30, 2008 | Computers & Internet
Goodman CLQ36AR49 Air Conditioner Logo
152 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
