Question about RCA D52W135D 52 in. TV/DVD Combo
The tv trys to turn on 3 times then I get nothing and I have to let it sit for a while to do anything. What could this be and is it an easy fix can someone please help me with this. Thanks
  • 10,515 Answers
Kindly Let me know Few Details :-
1. Make and Model of the TV?
2. How old the TV is?
3. How many Blinks you could see?
4. Do you have any Soldering Experience or Electronics
Repair Experience?
Thanks!!
Posted on Jun 03, 2010
  • zacvanasten Jun 03, 2010
    Thank you it is a RCA D52w135d it was manufactured in 2003 I believe it was 3 blinks and I have worked with electronics and have soldered before. I just have a hard time locating the part...
  • taran_2005
    taran_2005 Jun 03, 2010
    Thanks for your response!!
    First thing, you can disconnect the part number High Voltage just from fly back, be sure away from any ground wire and turn on, you will see or ear a little sound come in on, so then replace the splitter high voltage. Second thing, 2 capacitors in power supply all the time are bad ( 2.2 uf 50 V and 15uf 100v), common problem on this chassis. Other thing, resolder all connections around power supply and fly back.
    Note - You need to be very careful as it any mistake could cause serious injury.
    Let me know,once done.
    Hope i helped you.
    Thanks for using ' Fixya ; and have a nice day!!
I have a 95 honda accord dx. When i put the key in and turn it nothing happens. All my dash lights come on but nothing trys trys turning over or anything. I was told by a handful of mechanics and people at...
Only thing it could have been in the first place is the wire from the switch to the starter is disconnected from the starter. Even a new switch won't fix that. Just get under the car and plug the wire back onto the spade connector.
Aug 26, 2014 | 1995 Honda Accord
I can't get my tv to turn on. I turn it on and the green light comes on 3 times and the light only stays on for 3 seconds and then turns off. Can't get anything to happen with screen. Can you help me
Does it sound like it's coming on then powers down? Mine turned out to be the bulb. I bought a bulb on Ebay for less than $90.00 and installed it myself.
The bulb was inside a square metal housing, pull housing and bulb out of tv, replace the bulb reusing the existing housing, then replace..... Pretty easy fix, and I'm not all that mechanically inclined. Good luck!
Apr 05, 2013 | Televison & Video
My RCA 52 inch projection TV will not turn on. After hitting the on button, It trys 3 times and then nothing. How do I fix this?
replace the CP150, CP120 and CP114 capacitor. You can get the repair kit by the same name from www.tvrepairworld.com the kit also has the CD with instructions.
Apr 12, 2010 | Televison & Video
After turning on wont work for an hour or so
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Continue to use the TV and your problems WILL multiply.
Call the manufacturer to find you nearest authorized service center.
Please give is a good rating.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | RCA P60920BL 60" Rear Projection...
When i hook up the ps3 it turns on but nothing comes up on the tv
the only times this has happened with me is when the lead was not pushed in all the way at the back of the console. Or the tv was not set to the correct channel or the lead going into the tv was not sitting correctly. Try all of these three things to see if it helps. If not try pressing the power button on your ps3 until you hear 3 beeps to reset the display.
Jan 14, 2009 | Sony Playstation 3 (PS3) Console
Vizio L32 hdtv10a..
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Dec 15, 2008 | Vizio L37 Television
52" rear projection television
you need to rplace the flyback. very easy repair. you need flyback 259296 you can get a replacement flyback at the following link with free step by step installation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
Sep 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Xerox Phaser 2135
Try to isolate the problem. You said that the printer is Displays Tray 4 I/F Error Power Off/On. Put paper only on the Manual Tray (Tray 1), just to force the printer to print from that Tray. If the paper pass all the way through the machine, then you know that there is no paper inside the top portion of the printer. Now repeat the same thing with Tray #2,#3, and any other Tray but not #4. If the printer works fine with all the other Trays, probably Tray 4 is the problem or the whole drawer. Check switching another Tray with Tray 4.
Sep 10, 2007 | Office Equipment & Supplies
Unit trys to go on but than shuts off...please HELP!!!
It's one of the protection overload circuits connected to the high voltage power supply. I would take it to a repair shop and let them fix it for $200.00. A TV is no place for a novice. Even if its unplugged, it can seriously hurt you.
Jul 07, 2007 | RCA F36450 36" TV
RCA D52W135D 52 in. TV/DVD Combo Logo
113 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
