Question about Whirlpool Duet GHW9150P Front Load Washer
F35 keeps displaying and won't cycle out - Whirlpool Duet GHW9150P Front Load Washer
  • 10,515 Answers
This Error points to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after doing this, you will likely need to replace the pressure switch.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 03, 2010
  • 2 more comments
  • mhicks746 Jun 03, 2010
    which one is the sensor hose? there's about 4 hoses?
  • taran_2005
    taran_2005 Jun 03, 2010
    Thanks for your response!!
    Sensor Hose????
    Kindly Clarify the same.
    Thanks!!
    i meant to say vinyl hose, but I think I got it, was it a thin hose that was connected to another thicker black hose that is connected to the tube?
  • taran_2005
    This is How Vinyl Hose Looks Like :-
    Hope i helped you.
    Thanks
What does F35 code mean and what to do?
  • Run an empty cycle without using any detergent. Often the fault code displays when too much detergent is used and the detergent sits in the drainage system. A cycle without any detergent is often enough to clear out the buildup.
  • 2 Pull the drain hose out of the standpipe mounted to the wall behind the washing machine. Complete a visual inspection of the hose for any clogs. If you see any, remove the screw that holds the hose clamp onto the discharge pump and then force water through the drain hose with pressurized water from a garden hose. Reattach the hose and then run an empty cycle to see if the code goes away.
  • Read more : http://www.ehow.com/how_11368049_fix-whirlpool-washer-f35-code-alert.html
    Oct 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    My Kenmore Elite Front Load Washer -HE3t keeps stopping the cycle and the error F35 displays
    Hi
    The error code F35 is commonly associated with the Sud error, which comes on within a minute of running any cycle. It means the Analog Pressure Sensor (small plastic electronic circuit) has gone bad. It could also mean the Air Pressure Tube from the Sensor has a hole or isn't connected.
    Once you get the new Sensor, remove the 3 screws holding the top panel inplace - they are on the backside on the very top. Remove the top and look at the far back upper right corner (looking from the front). There is a small crimson & black piece attached to the metal side wall with 5 blue wires& 1 black wire (pressure tube) attached to it. Make sure there are no leaks or disconnects...if not, then replace with new sensor.
    Please get back to us if you have further query or else please accept the solution.
    Thanks for contacting fixya.com
    Sep 02, 2011 | Kenmore HE3T Washer
    Ok I had my pump replaced a few weeks ago but now I am getting the sud and f35 and f28 messages. What shouli do anjow much is the switch?
    Try this one to remove the error display f35 and f28
    Press Pause/Cancel twice.
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    Jun 03, 2011 | Whirlpool Washing Machines
    My whirlpool duet washing machine displays code F35 and won't complete the washing cycle.
    Hello & Welcome to FixYa
    F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
    Kevin
    Apr 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    In some cycles the word sud appears on the display. Then the cycle will stop and F35 appears on the display.
    one of our techs has already answered this on the f35 error code click here http://www.fixya.com/support/t400054-error_code if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future Thanks Rick
    p.s to repair this issue you would replace the analog pressure switch the switch's part number is W10156252
    Mar 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Washer is vibrating badly. it shows a cod f35
    The F35 indicates a water level pressure sensor failure. The SUD is normally displayed when there is excessive detergent suds in the tub. Make sure you are only using the recommended amount of HE detergent. Then run the washer without clothes on a drain and spin cycle.
    Jan 10, 2011 | Kenmore Front Load Washer
    Suds, and F35 keeps coming up when trying to wash!
    I would put bleach in the detergent slot, run through each cycle. Then run the cycle again with just water. These are really touch when using detergent. Just a little bid of suds sets these things off.
    Jul 26, 2010 | Kenmore 44102 Front Load Washer
    Code F35 on Kenmore Elite HE5t front loader washer.
    F35 is a water level error.
    The water level switch (pressure switch) has malfunctioned.
    Also - please be sure to use He soap.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
    Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
    F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
    Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
    Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    My Kenmore Elite HE5t washer flashes SUD continually, then goes to F35 mode and shuts off. Help!
    Sometimes the SUDS/F35 is because of TOO MUCH detergent. To clear you have to set the cycle on rinse and then keep pouring cups of water into the detergent container as the cycle is going. You might have to do this a few times because if the SUDS message comes up the water flow will stop. Just unplug and try again. Also when the detergent container is finally clear you will see the little rotators gears move around when the cycle starts.
    Aug 02, 2009 | Kenmore Washing Machines
    Whirlpool Duet GHW9150P Front Load Washer Logo
    20 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
