Question about Sta Rite Sr200na - Max E Therm - Pool & Spa Heater - Dual Electronic Iginition Lo - Nox - 200,000 Btu - Natural Gas
Sta rite sr200na heater. flashes 180 then "r 8" then shuts off
I own a sta rite sr200na spa heater. i was having a problem with the heater reading a higher tempature that it actually was in the spa. i believe this is due to the thermistor being bad. however, i started having a second problem that seems to supercede the thermastor. when i turn on the heater, it flashes 180 on the LED, then flashes "r 8" then shuts off. do you know why this may be happening?
  • 83 Answers
SOURCE: sta-rite gas heater won't ignite
I am not sure if either of these issues have been solved, but with the AGS light on, you will need to check the flow of water first. If it is below what is needed for the heater, this will light up. If the water flow is fine, then check the water temp on the display panel. If it is readin higher than that of the ACTUAL pool water temp, you need to replace the Thermister.
If the water temp displayed is about that of the pool water, then the Automatic Gas Shutoff will be the next thing to check and replace.
You can tell IF a Sta-Rite heater has been converted by the model number. The Convesion Kit is supposed to come with a sticker stating that the heater has been converted, but there are two options for the kit and the one without the sticker is cheaper.
If you take off the top two halves of the heater, on the Junction Box there should be a Tri-fold card there. Unfold it, if the model number ends with NA it is a Natural Gas Heater, LP would be Propane.
Posted on Jul 10, 2009
  • 128 Answers
SOURCE: Sta-Rite Problem; Error codes R8, Won't stay on.
Its the top membrane where the control buttons are. The circuit board plugs in to it.
Posted on Aug 23, 2009
  • 128 Answers
SOURCE: sta-rite lp heater wont start
Its the top. There is a membrane that controls the circuit board....the button pad is bad
Posted on Aug 30, 2009
Testimonial: "Thanks, I agree. After checking power supply all the way through to control board, placing a jumper from pins 9/8 and 9/7 on J6 I get lights on LED's"
  • 246 Answers
SOURCE: sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
Posted on Dec 07, 2009
  • 990 Answers
SOURCE: Water Temprature read 126 on heater and will not Fire
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Posted on Dec 21, 2009
Our spa heater has no lights on and will not turn on. When I reset the breaker all the lights come on and it shows 180 in led display and then r 8, then shuts itself off.
If one of my customers had this issue with their heater I would call the Sta Rite technical support at 888-782-7483 and they would likely be able to help you diagnose this issue.
Please let me know how this works out and ask subsequent questions. Thank you.
Sep 02, 2011 | Sta Rite Sta-Rite Max-E-Therm High...
Temperature reads 125 degrees.
I am not sure if you have solved this issue, or not, but just in case. The problem is the Thermister, or temp sensor. That will need to be replaced since it is reading the water temp at 125.
The Thermister is located on the manifold, left hand side, between the first two bolts. It is pretty easy to change out and this will correct the problem.
Jun 08, 2009 | Sta Rite Sr200na - Max E Therm - Pool &...
When Spa heater is turned on,Fan comes on but burner never lights
this is typical of a dirty flame sensor.your model does not have a thermo couple.remove sesor and clean with steel wool or fine emory cloth
May 11, 2009 | Sta Rite Sr200na - Max E Therm - Pool &...
Sta Rite Sr200na - Max E Therm - Pool & Spa Heater - Dual Electronic Iginition Lo - Nox - 200,000 Btu - Natural Gas Logo
98 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
