Question about AOpen s661FXm-7US (918EM10S6G) Motherboard
I have inserted a 1 GB mamory modual and the system is not reconizing the additional memory. Are there jumpers or switches that need to be reset?
  • Sean Mack Jun 05, 2010
    What is the speed of the memory? Also, when you say the system does not recognize it, do you mean at BIOS or after loading the OS (Operating system)? If it is the OS, which one are you using?
    Scholar:
  • 94 Answers
No jumpers or switches need to set. If your going to upgrade/change your memory, just make sure that the memory your're going to insert are compatible with your motherboard. Check the system bus of your memory slots if what are the maximum system bus can support of that motherboard. Like example; DDR PC266 to PC400 or PC400 to PC800, make sure that you are not exced the maximum requirements of the memory for your motherboard it is because they cannot recognize your memory.
Posted on Jun 05, 2010
GA-EP43 -UD3L motherboard will not boot with 16 GB of memory
Time to RMA, sounds like you have a faulty memory channel on the MB. Possibility the slots are not getting enough power to handle all 4, you try to see if you can increase power in bios.
Mar 01, 2017 | Gigabyte GA-EP45-UD3L Motherboard
Computer will not turn on.green light on but screen not lighting up.
Hello jaysmith362,
Your computer problem has 3 different cause:
1. VGA cable is not plug-in properly into the computer
2. Your System memory is not properly inserted.
3. BIOS problem
To solve your problem it.
1. Please ensure that your VGA is properly inserted into your VGA port of the computer. Or if you got an Videocard see to it that it is plug-in to your videocard.
2. You have to remove your system memory then return it properly into your memory slot.
3. Or by BIOS resetting, in your motherboard you will see an CMOS reset in it, try to remove the jumper then insert it in the other portion of it (it always has an 3 pins or 4 pins in the BIOS reset, if the BIOS jumper is located in the 1 and 2 pins try to insert it in the 3 and 4 pins). then restart your computer then turn it off after 3 seconds. Then bring it back the BIOS jumper into normal that is 1 and 2 pins.
I hope it will solve your problem
Thanks for using FIXYA...;-)
Aug 19, 2011 | Computers & Internet
My Matsonic MS8177C will not work with 2 DDR 400 PC3200 1 GB memory. However, it works with one in either slot. It will also work with one 1gb & 1 512. Why will it not work with two 1gb?
Please refer to the motherboard manual to know the memory capacity that can be inserted in your motherboard. If you already know about it and still doesn't solve the problem then follow this steps:
1. Remove all the 1 GB memory and then clean the pins of each by using an eraser of a pencil in your motherboard.
2. Find the motherboard bios jumper settings and reset it and turn it back to normal again.(Please refer to the motherboard on how to do this.)
3. Insert again the two 1 GB memory.
4. Power on the computer.
Take note: Be sure that both 1 GB memory have the same frequencies because some memory will not work if they don't the same speed and frequency.
Hope this could help you. Don't forget to rate me please..Thanks..
Oct 26, 2009 | Matsonic MS8177C Motherboard
I'm having 1 GB micro sd memory card for my mobile nokia 3110c ..
HI You have to choose the simple way to remove the password in your , Follow the steps below...
Insert the memory card into the card reader or any mass storage device into your computer
go to the file <memorycard>:/system then find the file "mmc store".and rename the file to "mmcstore.txt" (Hidden file should be made as shown from tools->Folder option->Show hidden files) Now open the file in notepad , No you will see the password.
Sep 04, 2009 | Nokia 3110 Cellular Phone
No boot after putting 2 Gb additional in Mb
try to reset cmos after putting 2 -1 gb rams(pulout power cord,and change clear cmos jumper to clear for 10 secs,or just remove motherboard battery for 30 secs,post mb info if no luck with cmos clear
Jun 12, 2009 | Acer Aspire™ T180 PC Desktop
COMPAQ LAPTOP MAMORY EXTEND
This laptop has 2 slots
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot.
So maximum memory supported is 1GB.
If you install more memory there is a high probability it will not be recognised.
You can get more information and order memory from the link below:
http://www.crucial.com/store/listparts.aspx?model=Presario%20M2000%20Series
Jun 08, 2009 | Compaq Presario M2000 Notebook
Nokia 3110 reset codes(reinstall software code)
nokia 3110 reset codes ,i m using 2 gb memory card.when i insert the memory card it automatically swicth off and on after that. after emoving card it gets normal.mamory card is ok.itz new one card..
reply soon
Apr 27, 2009 | Nokia Cell Phones
Purchased new San disk 4G microcard,and unable to format on mp3
What i did when it did not reconize was keep blowing and wiping in the card slot and wiping the card and it worked
Mar 28, 2009 | Audio Players & Recorders
Dosen't reconize 8 GB SDHC memory card
Older model printers won't recognize high-density memory cards.
2 gb is probably the largest to be used in your printer.
Dec 26, 2008 | Epson Stylus RX500 All-In-One InkJet...
My k810i memory
that phone can only go to 1gb so you will need to place back in the 1gb this will correct the issue.
Mar 19, 2008 | Sony Ericsson K800i Cellular Phone
AOpen s661FXm-7US (918EM10S6G) Motherboard Logo
82 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
