Question about Garden
The mower doesn't start and sometimes when I pull the rope it jerks back really hard
  • 420 Answers
Sounds like the flywheel key is deformed from shock. Remove the engine rewind and cover to get to the nut that holds the flywheel on. Remove the nut and flywheel. You can purchase a small engin universal flywheel puller cheap, install a new flywheel key and it will run great!
Posted on Jun 04, 2010
Why won't Lawn mower pull cord rewind ?
the springs break when jerked too hard and more than the rope lenght
Jun 28, 2014 | Poulan Pro " Pro" Self Propelled Mower
Yard Machines 25b-520c000 9-inch 148cc Briggs Stratton 450 Series Gas Cant pull start it. Its really hard taken off the housing and everything looks to be alright but wont spin freely if i use both and...
if I am reading this right it turns over by hand but not when you pull it? if it pulls but jerks the rope out of your hand then check the flywheel key. if it won't pull at all then I would venture to say you have an obstruction in the recoil that needs to be found
Mar 29, 2013 | Garden
Pull rope on sears 5.0 lawn mower pulls hard sometimes or you pull the cord and the spindle does not always turn. I guess it's not catching all the time. What can I do for it ?
If mower has sit outside for a while the works in the recoil may be rusty and dry. Try some oil in all the working parts. See if that works for you.
Aug 02, 2012 | Sears Garden
Briggs and stratton lawn mower 4 stroke engine
did you hit something while mowing the key way between the flywheel and crank shaft might have sheared it will act like the blade is missing pull back on you while pulling the rope
May 25, 2012 | Briggs & Stratton Briggs Stratton...
My yard pro lawn mower will not start, when i try to pull start it the crank rope vets pulled back sometimes
Two things to check here, check the blade is tight, it acts as a flywheel so needs to be tight, second, check the flywheel key has not sheared as this will cause the engine to kick back as the timing will be out.
Apr 25, 2012 | Garden
Starter rope on walk behind mower is hard to pull so mower won't start
Pull the spark plug out and give it a pull. It should pull VERY easily. You could have a vapor lock inside the cylinder and this will clear it. If it still doesn't pull easily with the plug removed then you've probably either bent the crank shaft or seized the engine, due to a lack of oil in it. Hope this helps. Best of luck.
James
Sep 02, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Hit steel rod. bent blade. replaced blade, runs but vibrates,bad. and when you try to start it the pull cord, jerks your hand back
probably sheered fly wheel key also check to make sure crank shaft is not bent. lay mower on side air cleaner up remove spark plug wire have some one watch blade bolt while u pull rope bolt should turn with out wobble.
Aug 12, 2010 | Garden
Pull mower rope on troy built self propelled mower and it jerks it back out of your hand,hard,,and will not start
This sounds like the engine is out of time.
Usually this happens when the blades hit something hard and shears a small aluminum"key" between the crank shaft and the flywheel.
This is reparable. The little key is less than a buck. A person needs some skills to remove the flywheel to replace the "key".
Wayne
Jul 30, 2010 | Troy Garden
When I pull the cord, the string is hard to pull and recoils out of your hand about half way through the pull
Sounds like you have two problems. One the flywheel brake is not being released completely and second the flywheel key has been sheared. It is why the rope is being jerked out of your hand. The mower is out of timing and when the spark plug fires before it is suppose to, it jerks the rope out of your hand.
Jan 22, 2010 | Toro Lawn Mower With Toro Power Tools
Wont start
frist thing did you check the flywheel key, if it is sheared its out of time, it will pull back hard .
Jul 01, 2009 | Garden
Garden Logo
179 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
