Question about Samsung DLP HL-P5663W 56" TV
I have my samsung almost for 3 years. and cahnge the original lamp after that i replaced the lamps 3 times more.i dont kwon is normal. but i think is something else. thank god i dont pay anything for the lamps . because lamps was on warranty. but now the warranty is expire and the last lamp is gone. now a need to replace the lamp or maybe you guys give me a ideas what is wrog with my tv. is a samsung 56 ich the model i can tell you .maybe later .because the manual is in my house. i give my email a you guys tell me your phone. i contact with you tomorrow. my email is reypin63@hotmail.com
I am having the same problem, my TV wont even come on anymore, I was watching it and it just shut off, all 3 lights are blinking and I have had the televsion for only 16 months. How do I change the lamp or should I pay 300.00 to have repaired, please help
Posted on Jun 15, 2010
  • 91 Answers
Use only original samsung lamp with the housing and socket attatched.
The lamp door switch may be intermittent,so you are temporarily fixing it by open and closing the door. The ballast can cause the failure as well. Avoid short period off and on times as turning the set back on in intervals less than an hour will cause microscopic cracks in the glass because the lamp needs too cool down to room temp before it is restarted for ultimate life........I hope this helps!!
Posted on Jun 04, 2010
The screen goes black, power light blinks with sound on, then screen comes back normal and so on.
This symptom of weak lamp that has reached its end of working life and will be dead/ broke any time.
If lamp has not been replaced in tv since last 2-3 years then it is time for new lamp in tv to fix this issue. lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good quality picture.
Let me know if you have additional question.
Thanks.
Nov 05, 2010 | Sony KDS-55A2020 55" Television
No picture, replaced lamp on HL-S6187W. TV makes a audio sound when I turn it on. Lamp does not light.
Did you replace the lamp? Was the Lamp original? Some time if you dont replace the lamp with original you are going to have this issue. Is there any sound. If you have sound and no picture is the Color Wheel.
Thank you,
Nov 03, 2010 | Samsung HL-S6187W 61 in. HDTV
Picture comes on initially then the screen goes blank. the lamp was replaced about 1 1/2 years ago. could this be caused by the lamp going bad again?
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The part # is "BP47-00027A" When you replaced the lamp did you replaced it with an Original Philips,if you did those lamps average 6000-8000 hrs 2-4 yrs.But if you didn't get a Philips but an aftermarket or Osram they average only 4000 hrs 1-2 yrs.Have a bless one!
Apr 26, 2010 | Samsung HL-R6167W 61" HDTV
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
My TV turns off by itself. It is a Samsung HlP6163W. Service Model HLP6163WX/XAA. The two green lights flash at the same time. I think it is overheating the bulb. How do I fix it.
Lamps don't really last very long typically 1 to 3 years depending. You may just need to replace the lamp. A burner gap of a lamp expands as the lamp warms up. If the gap is too large due to age (normal usage) the lamp will fail to light or shut down once the expansion occurs. The solutions to either problem is to replace the lamp.
Mar 15, 2010 | Samsung HLP6163W 61" Rear Projection...
When i turn on my samsung projection tv, the LAMP, TIMER, and STANDBY indicators light up and the TV Shuts off after a couple minutes. Not sure what is causing the problem. TV is 2 years old
Hi,do you hear clicking or like wanting to turn on? If you do it could be an issue with the ballast which is the board that powers the lamp.It sounds like the lamp because they normally last 2-4 yrs and when its bad you'll get 3 led indicators and will shut off every few seconds.Make sure you get the Original Philips lamp you can find it on discount-merchant.God bless you!
Oct 06, 2009 | Samsung Televison & Video
Everything functions fine but the picture is very dark and beyond adjustment through normal menu options, I can move the brightness all the way and it doesnt help any, is there a backlit bulb that might be...
I think you answered your own question. You have a rear projection television. It sounds like the lamp is not functioning correctly.
All projection lamps have a recommended life measured in hours. I checked the web and this model appears to be about 3 or 4 years old. from 2005 or so.
The lamp in my Samsung is rated at 3000 to 5000 hours, I had 12,800 when the service Tech was in changing another part.
3 or 4 years running one lamp is a good run. This is why DLP has lost favor for table top sets, Most are LCD or Plasma now.
Check you TV for it's lamp model and them shop around allot. Lamps are not cheap however some suppliers offer much better pricing that others. Care should be taken to make sure you order and purchase real replacement lamp and not a clone / compatible model. Original parts should produce the picture you are expecting
Jul 08, 2009 | Toshiba 57H81 57" Rear Projection...
Lamp keeps burning out. I have had the tv 2 years. The original lamp burned out in 1 year. I have since replaced the lamp at least 3 more times in the following year. Help!
Hi.
Im not at all familiar with your sony model but I do know that when A lamp is replaced you must reset the lamp timer if it is not reset it will cause premature lamp failure.
This is normally in the engineers menu as I said I dont know your model its not one I recognise so im sorry but I cant tell you how to enter service mode.
Hopefully one of the techs on here will know how and help you.
http://dysonmanuals.inc.io/
Chris.
Nov 17, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Samsung DLP HL-P5663W 56" TV Logo
170 people viewed this question
Jerry Greenberg
Jerry Greenberg
