Question about Maytag Neptune MDE6700A Electric Dryer
Dryer motor wont start
Dryer drum motor wont start on its own. ihave to push the drum manualy and then it will run.
Maytag dryer m#mde308dayw will not start just hums
Posted on Sep 08, 2011
  • 547 Answers
There are 2 fuses located one on the heater side at the top and the other at the exaust side at the bottom if you hard wire the one then the other you can figar out witch one it is if none work hard wire both then replace them.
Posted on Oct 17, 2013
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryerdryer motor wont start - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 04, 2010
Kenmore dryer wont start with the start botton but if i push the drum while pushing the button it will start
Motor is going bad...if it has a capacitor, try changing that first...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 27, 2010 | Dryers
Dryer wont start, makes a humming noise. I have to manualy turn the drum then the dryer will start
Check the belt to see if it is worn or loose. If it has a capacitor start motor, the capacitor or motor could be going bad also. If the motor is spinning but the belt is not turning then you have a loose belt.
Jun 14, 2010 | LG DLE2532W Electric Dryer
Wont turn on and run the timer runs but the push button to start wont do anything
SOUNDS LIKE THE BELT ON THE DRUM IS BROKEN, LISTEN CLOSELY AND YOU MAY HEAR THE MOTOR RUNNING THAT DRIVES THE DRUM.
Mar 10, 2010 | Maytag SDE2606 Electric Dryer
Dryer hums when turned on. Drum will not turn. I can turn drum manually.
try tuning the tub manualy when your hold ing start and the door switch, you may need some help
if the motor starts and runs like normmal, you have aproblem with the start winding on the motor
replace that, and you should be fin
i could not tell you how because i did not have model or manufacturer,,,, but most motor repairs can be done by the homeowner
got to
www.appliancepartspros.com
type in your model look for the motor
keep that section it will show you how to break down your machine as well
Oct 25, 2009 | Dryers
The WHIRLPOOL TEDS840PQ0 dryer wont turn on. The
Check the house electrical panel dryer circuit breaker pair--push off, then on. Try the dryer again. If still nothing, measure the voltage across the two slanted slots in the dryer power socket. It should measure: ~230 volts AC. If at or near zero, either one of the breaker pair is defective, or a wire is open from the breaker to the socket. If you read ~230 volts, then the problem is within the dryer--motor runs, but drum doesn't turn (broken belt), or motor doesn't run (bad controller, motor, door switch, start switch. Does the unit get hot? Need more help on your end.
Oct 18, 2009 | Estate TEDS840JQ Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryer drum won't start unless I manually push start the drum,  then it'll run fine. Turning the start knob just sounds like it want's to start. So right now I have to hold the start button, hold the...
unfortunatly it is either the motor or the drum bearings in the machine. if it is really hard to push i would suggest looking at all the bearings the drum rides on otherwise it is probably the motor that is getting weak.
Jun 08, 2009 | KitchenAid KEYS700LQ Electric Dryer
Dryer wont run/push power-sounds like it wants to start/nothing
i get this all the time,yes it is the motor,what happens is the motor gets so weak that it will no longer turn the drum it just hums,a motor on ebay runs about $65,your model number if you want to tackle it is inside the dryer door-mike
Apr 24, 2009 | Dryers
Dryer drum wont start spinning after pushing the start button
the problem is with the start winding on your dryer motor.it is centrifical switch,so if a lint build up gets in that motor switch area it stays on the run winding.pop the top .remove the frount.pull drum.vacume motor out if then starts on own great.other wise you need new motor.parts about 100$God bless,tom
Jan 02, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Jan 06, 2008 | Dryers
Maytag Neptune MDE6700A Electric Dryer Logo
216 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
