Question about Mercury KVM266PM-U (KVM266PMUD1600) Motherboard
MERCURY MOBO KVM266PM-U WON'T SHOW ONBOARD OR AGP VIDEO ON BOOT
I uninstalled a bad HDD and then tried to install another and nothing. I took ou t that HDD and tested it, no good: dead. I took one slave of my spare which is in excellent condition, nothing. I can't find the manual. I read that that this board is very finicky regarding RAM. I took the RAM out and installed DDR 512 MB 2100 which is lower than recommended still nothing. I tried the clear CMOS moved the jumpers. Help...
    President:
  • 739 Answers
Download this motherboard guide. Click here
Hopefully it can help solve your problem
Posted on Jul 23, 2010
How do you disable the onboard graphics on an emachines C2825? I am attempting to install a Sapphire Radeon HD 4650 AGP video card, but my computer will not boot when i plug in the new video card. I have...
First of all that motherboard is too weak to fully use that video card, you could get the same framerate in games using a video card 2 generations older.
Proper way of installing a new card:
1. uninstall the driver of the old one and reboot in BIOS - in there put all settings to auto;
2. shutdown the pc and install the new card; connect the monitor to it;
3. boot into BIOS, disable the onboard video card and reboot;
4. boot normally and install the driver.
Jul 24, 2010 | Intel D845GVSR Motherboard
PCI Video wont work with Gigabyte GA-K8VM800M motherboard
hey try the removing cards.....
window 7 may took up it best when no such changes are around..
! Gb or 2 RAm is enough to get run your Win 7
and sound card is noot required untill you have 4 or more speakers
Feb 12, 2010 | Gigabyte GA-K8VM800M Motherboard
Im trying to install agp...how do i disable the on board vga
Hi there.
Remember that if you are swapping from on-board graphics to a card you have to go into the BIOS and tell the machine that the primary graphics adapter is AGP/PCI Express.
Plug the VGA cable into the on-board graphics port, start the computer and enter the BIOS, tell the computer to use the AGP/PCI card as primary, press F10, save the changes and exit the bios.
The computer will try and restart so let it boot to post and turn it off, then put in your card and try to boot again.
Please post back if you need more help or advice.
Good luck and thanks for choosing FixYa!!
Jun 04, 2009 | HP Compaq Motherboard
P4m800pro-m478 "No video"
if you have another pci slot install the card there
if that does'nt work
your card has probably gone
please rate me
thanx
Feb 02, 2009 | EliteGroup ECS P4M800-M Socket...
Unable to install XP sp2 on Intel D865GBF Motherboard
Maybe having trouble with a device, remove any pci or agp cards and usb devices, use built-in video until installed.
Set bios to defaults, make sure bios is latest version.
I have found this happens with a promise ultra-100tx2 and any nvidia video card.
May be a bad install cd, if you can boot it with a dos or win98 disk/CD, copy xp i386 folder to hard drive install from i386 folder on hdd by running winnt.exe
I have installed xpsp2 on about 10 d865gbf's and 2 days ago installed xp sp3 on one with no problems. may also be bad mobo.
Jun 28, 2008 | Intel D865GBF Motherboard
Video card makes system unstable
Hi Wayne, it's rule of thumb to always uninstall the old software from add/remove programs before installing the newer software drivers. The reason for this uninstall is so the two programs do not over-write files with the same name.
The ASUS P4S800-MX motherboard does have an onboard graphics card, (SiS Real256E). If you added another video card into the AGP slot & did not disable the onboard graphics, than you're AGP card will not run correctly. (I'm suprised it even loaded)!
Please read page 2-19 in you're motherboard manual to help fine tune the bios when using an AGP video card. Than go to page 2-21 & than set, Primary VGA bios to; [AGP,VGA Card]. Save & exit. The PC will restart.
Press & hold the power on button on the case. This will power off the system. Unplug the power cord from the power supply. Insert you're AGP card & make sure it is fully seated. Close the case & plug in the power cord. Boot up the system. Uninstall any other software you did install for the AGP card. Retsart the PC after uninstall is complete. Install the latest software you downloaded for the AGP card. Restart after install is complete.
Lastly, run windows update service & choose ustom, not express. Check for hardware & software updates. You're system should function much better & when you check the system properties you will find you have more system memory. This is because the onboard video used you're system memory to run.
Good luck Wayne!
Mike
Jun 25, 2008 | ASUS P4S800-MX Motherboard
Problems with video card installation
uninstalled your RAM, turn on your PC for about 20 seconds, shut it down and reinstalling your RAM again...
Feb 14, 2008 | Computers & Internet
Mer cury PVM7 mobo wont display on monitor
So I think you are saying it did work and then stopped, right?
If that's the case then I would try booting into the BIOS setup and reseting it first. If that does not work then I would reboot into the BIOS again and see if there is something there you need to enable for the AGP port to function.
If all this fails then you most likely have a bad motherboard. It's probably not worth the money to consider having it repaired, and I doubt you'd find anyone who's even interested trying.
Good luck.
Dec 28, 2007 | Mercury P4VM800M7 Motherboard
No display on monitor
no, its working as you said. try to uninstall your video if you installed to expansion slot (agp) then use the on board. that is one of the most common problems of pc specially when you're moving this from one place to another. if it boots from your onboard vga clean your uninstalled video card then reinstall to your agp. i hope that this helps you
Dec 08, 2007 | EliteGroup ECS P4M800-M Socket...
Hp compaq dc5000 small form factor
Hi, uninstalling the onboard video will only be reinstalled by Windows next time you boot up. Disabling it in the Device Manager might and mght not do the trick if your mb is set on using the onboard. You might want to try and disable the onboard video in the CMOS/BIOS set-up. In some instances, you are asked in the BIOS what video will be used such as onboard, AGP or PCI or a selection of something like that. Also you can try and not allocating any memory to the onboard video. Hope this be of some help. Pls post again how things turn up. Good luck.
Apr 28, 2007 | HP Compaq dc5000 PC Desktop
Mercury KVM266PM-U (KVM266PMUD1600) Motherboard Logo
73 people viewed this question
Top Mercury Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
vsri9
Computer Links
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
