Question about Emerson LC320EM8 32 in. LCD TV
Tv wont stay on
Goes in standby mode
  • 23 Answers
Power boards have gone
Posted on Jun 03, 2010
freetek
  • 5568 Answers
SOURCE: TV & Tuner stays in Standby mode
Assuming you have tried changing batteries in your remote and any front panel power switch your set has, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.  What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Oct 29, 2008
SOURCE: My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
Posted on Jan 08, 2009
  • 9 Answers
SOURCE: my hd4208TIII-PDP WONT COME OUT OF STANDBY MODE
You Need a new Power Supply, part # LJ44-00025A
buy it here for $139 http://www.adc-ast.com/
I have my tv working like new.
If you want this time the power supply last, do not turn off, just press tv/video button to switch input source, let the tv in sleep mode.
Credit: User IMJR
Posted on Apr 05, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: TV on Standby
There is a Sony S3000 protect blinks table:ebf219b.gif
Posted on May 28, 2010
SOURCE: i have a philips 42pf7520d/10. it goes into
Replace C2465, C2508, C2540 and C2541. Replace with 25v /105*C types.
Posted on Oct 10, 2010
Television will not stay on. Runs for 5 seconds then goes into standby mode.
Modern Flat Panel Televisions these days are really just computers inside. The Switch Mode power supply has the ability to sense faults & over current draw. So... there really isn't much the average person can do to fix an electronic problem.
The usual problem is overheating, bad connector problems & electrolytic capacitors leaking or popping. If you don't have the skills to open & look for problems then you will have to take it to a tv electronics guy.
Cheers
Feb 21, 2015 | Panasonic Televison & Video
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
Schamthmsch
Hi.
If you have no picture, no sound and the TV stays in standby it is not the remote sensor. That is the TV in protect mode (forced standby). The TV goes in forced standby when an internal problem is detected. Most Sony have buttons on the TV set. If problem is the IR sensor the TV Twill wake up if you press the channel buttons on the set. Try disconnecting power cord for ten minutes. If that does not work call the Sony support number listed in your user guide.
Regards.
Ginko
Dec 15, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Power turns to standby
Go into the menu and change to setting for the timers and power settings.
Nov 20, 2009 | Televison & Video
Bush lcd 37 inch tv keeps going to stanby
my bush lcd tv keeps staying in standby mode and wont go on if it does go on its only for a minute or two....
Help please
Mar 04, 2009 | Televison & Video
My hd4208TIII-PDP WONT COME OUT OF STANDBY MODE
Credit: User IMJR
Feb 28, 2009 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Dec 16, 2008 | Televison & Video
We have a large tube pansonic wide screen tv. it sometimes would stay in standby mode and would not turn on when using the remote or channel switches on the tv.. this is getting worse to the point where...
This fault can be caused by low secondary supply voltages often caused by the value of capacitors becoming low and requiring replacements but you will have to have a technician.
SUPER8
Dec 01, 2008 | Panasonic Televison & Video
Emerson LC320EM8 32 in. LCD TV Logo
196 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
