Question about Humminbird Fishfinder 565 With Transom Mount Transducer
Hello, my Humminbird 565 startred to misread the tempereture, when stoped or in low speed it show the water temp 10º c bellow the real temp. The same happens in Fº. The sounder otherwie works just fine. Any ideias?
  • jonifili Jun 03, 2010
    Maybe, but I haven't change the transducer, and it work just fine until now.
    But is an idea.
    Thanks,
    JF
  • 416 Answers
More than likely you have your sensor run underneath the boat and therefore the sensor is directly in the water. When you speed around the hot water on top is what your sensor is picking up, when you slow, you are allowing the sensor to pick up on the colder water just inches below the surface
Posted on Jun 03, 2010
I did lost my operation manual for my fishfinder humminbird 570
Hi!
Since your unit isn't listed in their owners manual section, you'll have to contact their support rep.
http://www.humminbird.com/support/Contact_Support.aspx
Hope this helps you out.
Jun 20, 2011 | Humminbird Fishfinder 565 With Transom...
I have a Humminbird 565 that is about 3 years old and the end of the transducer has opened up and the sealant has all leaked out. I also have and older one that is doing the same thing. What's up with...
I have no idea, I use these same ones and havve several mounted and they are used both in summer and winter, never had one leak. I also looked up these and did not see where there were any issues with this problem. I suggest you call Humminbird and talk to them, they are usually very helpful.
Toll-free: 1-800-633-1468
Monday - Friday
8:00am - 4:30pm CST
Mar 04, 2011 | Humminbird Fishfinder 565 With Transom...
My fishfinder 565, just suddenly stoped working. We were in the boat and all of a sudden it went dark. Can there be a fuse of somekind that could be replaced?
yes, generally there is an inline fuse on the hot (red) wire. it is incased in a white sleeve that twists apart and reveals the fuse. if its not the fuse check the battery or connections to the back of the depth finder.
Aug 31, 2010 | Humminbird Fishfinder 565 With Transom...
Humminbird 7300211 speed unit
Hi!
Installation of the speed/temp wheel is quite easy, here's a manual:
SW Speed & Temp
The new sensor cable plugs into the square plugin in back of your Humminbird....it's the small square connector with 4 holes.
Best of luck!
Mike
Apr 30, 2009 | Humminbird 7300211 SW Speed Sensor GPS...
In water less than 5', my Humminbird 565 reads that it is .6''of water
Hi!
If the sounder works in deeper water then try changing the unit to fresh water instead of salt water (or vise-versa). You'll need to switch to advanced settings first (in the setup menu tab), then switch to the afformentioned salt or fresh water (in the sonar menu tab).
Alternatively, switch back to factory defaults as these settings are made to work "right out of the box".
Best of luck!
Mike
Apr 26, 2009 | Humminbird Fishfinder 565 With Transom...
Humminbird 565 says its loading
You'll need to take this one to an authorized service center to have them have a look at it. My guess is that the software is corrupt, so it may just be an easy fix. You can try it yourself if you like (if it's out of warranty). Go to www.huminbird.com and register your sounder. That will give you access to the software updates and instructions.
Best of luck!
Mike
Mar 31, 2009 | Humminbird Fishfinder 565 With Transom...
Humminbird fishfinder 565
according to the manual... 10-20 VDC
Please rate this solution.. thanks
Feb 04, 2009 | Humminbird Fishfinder 565 With Transom...
Humminbird Fishfinder 565 With Transom Mount Transducer Logo
321 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
