Question about Garden
AM TRYING TO RESTORE A SUFFOLK PUNCH COLT LAWN MOWER 14 INCH CUT AM HAVING TROUBLE GETTING A SPARK TO THE IGNITION SYSTEM
  • 177 Answers
More info
Posted on Jun 07, 2010
    Problem Solver:
  • 8 Answers
Had no spark on a machine that has been unused and left in a shed for over ten years. It was surprisingly clean but no spark. Removed the plug cap and checked with the end of the lead against the cylinder head, still nothing. Removed the rotor so I could get to the coil and points, the points gap was good although there was a little corrosion/oxidisation on the points. I took the points and coil off to test with a meter, can't check much with it in place as both sides of the points go to earth, one side via the coil. Measuring across the points I had no continuity! I could see metal to metal contact but the meter said it was dis. Looking with a high powered jewelers magnifying glass I could see a slight discolouration of the contact area of the points so I took a folded piece of fine (600 grit) emery paper folded and gently drew this between the points carefully so as not to round the edges, until the metal contact area was shiny metal coloured. Now I measured no resistance across the points, the way it is supposed to be. Replaced coil, points, gapped the points while I could get to them easily, rotor, side case and pull start, tested and saw a nice spark at the end of the lead. Replaced the plug cap, cleaned and gapped the spark plug, and with a bit of clean fuel it started first pull. Stopped it immediately as now I have to replace the engine oil and check everything else before I try to run it.
Cleaning dirty points was a lot cheaper than replacing the points and coil assembly.
Posted on Apr 18, 2014
Any one know where i can source suffolk punch parts.
Hi try these sites www.ransomspares.co.uk. . www.mtmc.co.uk. . www,raidiy.co.uk..,.,.< discontinued spares <. good luck
Jul 29, 2016 | Garden
Where can I get my old SUFFOLK COLT (ATCO) 14 inch blade mower serviced? I am sure one of the jets in the carburetter is blocked! Birmingham B17 9BX
Hi there. The best place to get a Lawn mower serviced in birmingham by you is Heritage. He is based in a Factory unit off the Pershore Rd in Stirchley. Mobile number is 07966052226 and i think he does a Collection service if needed.
Oct 20, 2014 | Garden
SUFFOLK PUNCH PETROL MOWER 17SK
check and make sure all the tires have the same pressure
Aug 11, 2014 | Garden
Suffolk Punch 35s not starting
carburetor have a setting level for its fuel , check the floating control adjust fuel level , also check spark plug current is there,just by rotating engine and keeping spark plug out of cylinder , just keeping it with engine body.
Apr 12, 2014 | Garden
Replacement bottom blade for suffolk punchl lawn mower
Hi Keith,
You can find spares here:
http://www.espares.co.uk/search/lawnmowers/suffolk-punch/p/1116/2173
If you google suffolk + punch + spares you should be able to find more websites which supply blades.
Hope this helps!
May 30, 2011 | Garden
Please advise on where to puchase replacement parts for old Qualcast punch classic 30s lawn mowers
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Aug 30, 2009 | Garden
My mower is not cutting level. I have a new base
If the baseplate meets the cutting cylinder across the entire cutting width, it's adjusted properly.
Check that the front roller is level - it usually IS as simple as that.
If the roller has ben replaced with wheels, check that they are the same height.
Aug 22, 2009 | Garden
Manual for Suffolk Super Colt lawnmower needed asap
have you tried **** into the carb i did this with mine...............it didn't work but it felt soooo good
Apr 06, 2009 | Garden
Maintenace Manual for Suffolk Punch petrol-driven Lawnmower
Have you checked with the company that makes the mower for the manual? Hae you tried searching the internet to see if you find the manual there?
Sep 14, 2008 | Garden
Garden Logo
561 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
