Question about Traxxas Rc Revo Nitro Monster Truck
My nitro revo 2.5r rc will only start with a glow plug igniter.
I have a nitro revo 2.5r rc. It will only start when i connect a glow plug igniter into it. What is wrong with it? Does it have something to do with the glow plug wire and the ez-starter?
3 Suggested Answers
SOURCE: wont start have a traxxas revo 3.3
Hello!! ,
To the point!!! , All gas cars are "Nitro" , there are "Gas" Cars but there more expensive and fairly new... , by my experience Ez starters dont have wires on them in order to start the motor.. , if you cut!! a wire.. in there maybe it could be it... , but these cars dont need ground wire.... ,Sooo if u say its ground wire i dont think theres a problem , its only incase if there's an electrical over-out-charge that will put the chips in danger... , so THIS MESSAGE IS QUITE COMPLICATED : ) ... ,
and it shouldn't turn over there not designed that way , only if you put another motor that maybe is'nt apropriate that has more speed or power if i may or it does'nt have a back "Wheel" Slider..., and if the gears got something in it well... , maybe they might chiped a "Tooth" there and is not gearing well wich may lead to more gear problems as u can imagine , check the steering batteries too , or maybe it just needs "Idle-ing" so the motor can run Fine and Dandy like Tom Hanks says jaja , but i think the problem is that your not Idle-ing it well in twisting the Knob fairly 1/8 at a time to get a smooth sense and sound of the motor because it can over heat , or maybe there's something about the carburator that's not working well , Orrrr maybe it needs a clean with white Gas in unscrewing all the "Motors" Parts and cleaning them for a while so the motor can run better , Ive got an Exceed Rc "Mad Storm" so im kinda of guessing but they all work quite almost the same , Hope this helps : ) Ciao!!!!!
Posted on Apr 13, 2010
mr1967mejias
  • 636 Answers
You could have the clutch slipping on the easy start. It's a very common problem especially on the easy start system. Los shop will take to replace that clutch but that's not necessary. You drill a small hole at the very bottom of the EZ start less than 18 if possible just enough to break through the black part of the plastic. Then you will have access to shoot contact cleaner and there which gets rid of the excess oil which is causing the slippage. One little shot in there of contact cleaner tried in the fire right up. I have lots of experience with the EZ start system but I refuse to use any other that's why I stick with Traxxas. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Posted on Nov 22, 2014
Troubleshooting
Bad glow plug. Dead battery in ignighter. No fuel going to carb.
May 07, 2013 | Traxxas Rc Revo Nitro Monster Truck
My glow plug isnt getting hot
Please check your battery and also check your glow plug wire it may be damaged .
Jan 08, 2013 | Traxxas Rc Revo Nitro Monster Truck
My husband has atraxxas rc truck, he replaced the glow plug, it has apull start motor but still cant get it started. what else can he check/
So he replaced the glow plug. Make sure that it is seated properly and that all connections are good strong and tight. Also make sure there is a good seal on the combustion chamber. Look for leaks or restrictions in the intake and exhaust. And be sure to use the proper mix of fuel.
Oct 24, 2011 | Traxxas Rc Revo Nitro Monster Truck
How to take the glow plug wire from the part were there ez start goes
when you get a new glow plug wire a tool is packaged with it and instructions its a small brass tube you slip over the pin to release it.
Aug 06, 2011 | Traxxas Rc Revo Nitro Monster Truck
Revo 3.3...engine doesnt stay on...
Could be a couple of things. Firstly the glow plug may need changing or youre running slightly rich. If you was replacing the glow plug you should retune the engine anyway. When the fuel is entering in the engine where the glow plug is theres either to much fuel and flooding plug out or the plug is not up to the job of burning the fuel. Replace plug and retune. You have had car for two years so guessing you know how to tune the engine.
May 27, 2010 | Traxxas Rc Revo Nitro Monster Truck
3.3 revo hard to start after started it will not idle and when it dies it does not want to restart. This did not happen until I drve it thru alot of wet grass last year
Hi
2 stroke engines are very simple. If there's fuel (under pressure) and a spark it will run. Check the glow plug by trying to start it with glow plug removed but still connected and touching the engine body. If the little center wire glows bright red, then it's OK. Only do this for a second or so. If the plug is OK then it has to be a fuel problem. Traxxas has a long history of cracked gas tanks. Good luck
Apr 30, 2010 | Traxxas Rc Revo Nitro Monster Truck
My revo is getting fuel light on start remote are on both motor and glow plug engine will just turn over but will not start up
Hi
You've checked the glow plug externally to see the wire get red? If so, as long as you've got fuel and fire then it has to start. My guess here is that you have either a bad glow plug, low batteries, fuel air leak or clogged pressure line. Put a charged battery into the starter. Remove the glow plug and try to start - fuel should spurt up through the glow plug opening. Now connect the glow plug and touch it to the engine. Try to start and you should see the glow plug wire glow red. (do this only for a second. Now disconnect the pressure tap from the muffler and try to start. All else fails, replace the fuel line to the carb and the pressure tap. Your carburetor can leak air through the rubber gasket . Also, Traxxas fuel tanks have a cracking problem. Good luck
Apr 14, 2010 | Traxxas Rc Revo Nitro Monster Truck
I have a revo 3.3 nitro and im having problems starting it im am indoors about 70 and im flooding the engine i go through the steps for a flooded engine but the easy start won't turn i let it cool...
i'm new to revos two but i just bought a couple and had the same problem with one of them, make sure your glow plug is ok or just replace it and adjust your high speed needle, i'm in oregon i had to richen mine about 1/4 turn. i also noticed both of the models i got were set differently from the factory. there's info on traxxas website on where the factory needle settings should be.
Feb 02, 2010 | Traxxas Rc Revo Nitro Monster Truck
I have a traxxas revo 3.3 and it turns over but it will not start what do i do
The glow plug could be bad. If the motor turns over and is getting fuel I would replace the glow plug.
Jan 07, 2010 | Traxxas Rc Revo Nitro Monster Truck
Traxxas Revo 3.3 engine cooling head
Remove the glow plug wire and there are just a few bolts that hold the head on. Just make sure you install the new head with the head shims like they were under the original head.
Jul 03, 2009 | Traxxas Rc Revo Nitro Monster Truck
Traxxas Rc Revo Nitro Monster Truck Logo
46 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
