Question about Hitachi 60SDX88B 60" Rear Projection Television
No power on tv make one click led red ligh - Hitachi 60SDX88B 60" Rear Projection Television
  • 1 more comment
  • thielectronick
    thielectronick Jun 03, 2010
    you can see which power supply lines come up or don't by monitoring all the green leds inside the set which lines arent coming up? careful, high voltage inside, procede with caution
  • omar_aguilar Jun 03, 2010
    please spanish answer
  • 505 Answers
Verifique las luces verdes, las que no se encienden indican que faltan tensiones. proceder con cautela, no es de alta tensión dentro de la televisión. si usted tiene un medidor de ohmios, controle los fusibles. dentro hay una etiqueta que indique la ubicación de los fusibles y las luces.
Posted on Jun 04, 2010
Five red blinks in Sony LED TV KDL 40W900A.
5 red flashes is a bad panel connection or internal panel short, very carefully take the panel connectors off and reseat them and see if that helps, unfortunately you may have a bad panel.
Oct 14, 2017 | Sony Televison & Video
Grundig Xephia 42 in.stuck on stand by
Probably the internal power supply has failed.
Nov 22, 2013 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
The adappter red ligh comes on for a second then goes off
If it is blinking then there is an issue with it's hardware. If it is solid red, that means it is just waiting for the configuration from the Xbox. If it is blank, either the green led is broke, or it isn't receiving any power.
Jan 22, 2011 | Microsoft Wireless Network Adapter Xbox...
I have a sony kf60xbr800 60 when i press power
Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Part # is XL2000 found it here: http://www.discount-merchant.com/SearchResults.asp?Search=XL2000+?Click=48173
Nov 18, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Tv light truns on green and then the red power ligh starts blinking
It might be a issue with the power supply, do you hear any strange noises or do you see any other led warning light?
Jun 24, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
No picture or sound
Remove the rear panel. With the TV on you should see a red LED near the center of the PCB. There should also be 5 green leds, 3 to the left a 2 behind. If there is no red leds, check the fuses. If there are no green leds or maybe 1 or 2, disconect PSD5. It's a connector on the left side of the power board that connects to the audio board. It's the 3rd on fro the back. It's labled. With that disconected, turn on the set and look for the green leds. If all 5 light, the power supply is OK and you have a problem beyond that. If they don't all light you have a bad power supply.
Jul 21, 2008 | Hitachi 50EX20B 50" Rear Projection...
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Hitachi 60SDX88B 60" Rear Projection Television Logo
129 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
