Question about Frigidaire 30" Self-Cleaning Slide-In Gas Range - White
Can gas range grates and burners be painted
Can the grates & burners on a gas range be painted,with heat resistant paint . if so where do i buy it.
thank you
Lowes has it
Posted on Dec 21, 2012
4 Suggested Answers
  • 2557 Answers
SOURCE: need help finding a fire proof paint or ceramic paint
have never come across any might be better to just buy some new ones ,
Posted on Jan 18, 2010
  • 2557 Answers
SOURCE: Frigidaire Gas Range with paint blistering around largest burner etc.
go back to where you got it from the paint should not come off after such a short time same as the grates .
Posted on Jan 05, 2009
  • 78 Answers
SOURCE: Top of range paint peeled. Buy new top
You will have more luck finding this top on ebay go to appliances and put in all info, untill you find one, i do this a lot when i cant even get parts, and i hav a shop, you will find one
Posted on Feb 18, 2010
I cleaned black gas stove burner grates with vinegar and they got all greyish. What can I do to get them black again? Is there some kind of paint that could be brought on?
No paint will withstand the heat at that point; those are protected with porcelain when new and they unfortunately will always degrade with time. Porcelain is applied with very high heat but doesn't retain its gloss in service. You might try one of them, on one small area, to see if a 'rust remover' such as Lime Away will somewhat defog them but they will never appear as new once they have been exposed to use.
May 04, 2011 | Frigidaire 30" Self-Cleaning Slide-In Gas...
I bought the Ducane Affinity 3100 from Ace Hardware in 2009. The paint on the inside of the grill lid has started to bubble, peel and fall off. Is this covered by the manufactory warranty. Is it still safe...
According to the Owners Manual for your and the reading of the Warranty, No the paint flaking under the grill hood is not covered under warranty (see link below). As far as safety of using it is concerned ... only if you clean all the flaking paint and any residue, and repaint it with High Heat Grill Paint. This should only be applied after all greasy residue has been removed and only in light coats. Several light coats, in fact. It should be allowed to thoroughly dry between each coat, before applying the next coat. Once the final coat is applied, wait at least five days before using the grill. Be sure no paint gets down of the cooking grates or the burners. You can get the High Heat Grill Paint , form the same Ace Hardware store you bought the grill from. I believe Ace carries Krylon, which is one of the best High Heat Paints.
Apr 10, 2011 | Ducane Affinity 3100
Burners black paint is coming off, pots seem to slide when cooking
The black paint burning off the grates is normal. It happens after a while. The pots seemingly sliding could be an indication the stove is not level.
Jan 01, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Can ~i respray the top of my Aga cooker with heat resistant enamel paint
yes but it will soon peel of you will need to chip off all the glass enamel first to give the heatproof paint something to stick to, use 650 degree paint
Nov 23, 2009 | Kitchen Ranges
Need help finding a fire proof paint or ceramic paint
Aug 20, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
The paint around the control knobs showing the heat levels, burner locations etc is wearing off. How do I replace the paint?
can you find some spray paint to replace it with?...cut the right size hole for the circle in a piece of cardboard...it should have enough cardboard to keep the "spay-over" off the rest of the stove. and then just make small marks to replace the numbers.
Jul 31, 2009 | Belling CookCenter 151 Dual Fuel (Electric...
Stained gas range burner grates
Hey y'all. I have the same lame GE profile gas cooktop with the gray grates and burner covers. I know this is the expensive way to go, but I use Easy-Off "self-cleaning oven" oven cleaning spray. For about $5, you get 3 cleanings. It is a pain to do, but I have better things to do than scrub these grates all the time. I don't know why, but the baked on crud just drives me crazy. I tried everything to clean them completely. I even tried to scrub the darn things with a kitchen pumice stone(sold at walmart)but it is impossible to get the curvy areas clean. Now the paint has started to wear off on the burner covers.
I do not use the oven cleaner on the cooktop itself. I use soft-scrub with baking soda, then cover the cooktop with a sheet of heavy duty aluminum foil and cut out holes for the burners. This keeps most of the spills contained, and helps with cleanup.
I visited to the GE parts web page, and they only sell gray grates and covers. I am going to buy black BBQ grill paint(spray can)from Home Depot and try it on the burner covers first. They are the least expensive to replace if it fails, and if it works, I will paint the grates with this high temperature paint. I will keep you posted on the results.
Regards,
Laura D.
Feb 14, 2009 | GE 30 in. JGP337 Gas Cooktop
Paint on stove top is coming off.
with smaller spots you can use appliance touch up paint and it should hold paint down and keep spots from getting bigger. Depending on how old the range is your landlord might be able to order a new top. I would voice my concern to the landlord and see what they might be willing to do to appease your concerns.
Jan 16, 2009 | Sears 61301 Gas Kitchen Range
Oct 11, 2008 | Frigidaire FGF326AS Gas Kitchen Range
GE PROFILE RANGE TOP
psnowden this can happen. If I remember correctly GE is using a Hi Temp paint, not porclean, on this range. And if they are using porclean, it is a thin coating. With current ranges the cooking oil gets into the finish and runs the heat up causing the finish to lift. The is espically true with white. The gentlest clean will in time not stop this from happening. You can get some hi temp touch up paint to make it look better, however it will keep doing this, espically on the burners you use the most.
Feb 03, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire 30" Self-Cleaning Slide-In Gas Range - White Logo
474 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
