Question about Coby TF-DVD7005 Portable DVD Player
My Coby TF-DVD7006 Portable DVD player's screen will not brighten enough to be able to see the picture (except barely) even though the brightness is turned all the way up.
  • 10,594 Answers
It seems that lcd is not getting proper/ enough back light to present picture with good brightness. Most probably connecting wire between top and bottom part of unit got cracked/ damaged and causing low or no back light in lcd section of dvd player.
Please check connecting flexible wire between lcd and lower dvd section and replace it. Unit will take apart and it is not job of novice.
Hope these info will help you.
Thanks.
Posted on Jun 03, 2010
  • Coby Master
  • 6,993 Answers
the screen flex or screen inverter is beginning to develop some fault. Or the screen flex is has loosed contact from the inside.
This is a fault from your player and not the brightness setting of any kind. This problem is common with portable DVD players.
If you have a knowledge about repairs you can look into the screen inverter and flex yourself. If not, take the player to a qualified tech for repairs.
To confirm that the fault is from the screen inverter/flex, connect the player to a TV and you will see the is will display well, with no problems.
Take care.
My 9" Coby V.ZON TFDVD9109 Swivel Widescreen Portable DVD Player won't charge but will turn on and stay on as long as I have a charger hooked up what can I do about that
Coby TFDVD9109 9-Inch Widescreen TFT Portable DVD ...
www.amazon.com/Coby-TFDVD9109-9...Widescreen...
Amazon.com, Inc.
Rating: 3.6 - ‎52 reviews
Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ... has never been easier with the Coby TFDVD9109 9" Portable DVD Player. .... The DVD player finally stopped working, won't load discs anymore, gives error message. I had a ... I'm currently doing my research for a new a player but likely will end up ...
Coby TFDVD7009 7-Inch Portable DVD/CD/MP3 Player, Black
www.amazon.com/Coby-TFDVD7009...Portable-Play...
Amazon.com, Inc.
Rating: 3.7 - ‎240 reviews
Ac Power Adapter Cord for Coby Dvd Players Tfdvd1029 Tfdvd7009 .... So in my case 5 zone is needed and it worked well. ... There is inconvenience in charging. ... that once you unplug the battery the connection is so cheap that it won't reconnect. .... Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ...Missing: tfdvd9109
Coby Electronics TF-DVD7006 7-Inch Widescreen TFT ...
www.amazon.com/Coby...DVD7006-Widescreen-Port...
Amazon
Jan 10, 2016 | Coby Televison & Video
Where can I order a new power cord for a coby portable dvd player TF-DVD7006?
Hello and Welcome to FixYa!
It seems like this is a discontinued item. Specs on the AC adapter are listed as:
The AC adapter operates on AC 100-240V ~50/60Hz (DC Out: 9V; DC
Current: 2.0A minimum
Your best, quickest solution is to check with a place like a Radio Shack who may have a universal adapter with the correct fittings to plug into your player.
Concerned.
Jan 28, 2011 | Coby TF-DVD7006
I need a Coby TF-DVD7006 DC adapter
acadapter.com, lcdpayless.com, ebay, are just a few that I can Think of.
Sep 30, 2009 | Coby TF-DVD7006
Need to down load an operating manual for the Coby TF-DVD7006,
http://www.cobyusa.com/files/manuals/TFDVD7006_MN.pdf
Apr 20, 2009 | Coby TF-DVD7006
The player will play commercial disk but will not read blanks to record
the problem is that your portable dvd player is not a recorder. its just a player that is capable of reading already recorded dvd's.
Feb 21, 2009 | Coby TF-DVD7006
My Coby Portable DVD PLAYER
the cover plate broke and will not stay down i need a new one?? I only use this 3 times ocean
May 20, 2008 | Coby TF-DVD7006
Coby NTSC to PAL
this is the link to solve your problem. just done it and it works fine.http://www.videohelp.com/dvdhacks/coby-tf-dvd7006/8694
Jan 24, 2008 | Coby TF-DVD7006
COBY V.ZON TF-DVD 7006
try this link. it just worked for me.http://www.videohelp.com/dvdhacks/coby-tf-dvd7006/8694
Nov 23, 2007 | Coby TF-DVD7006
Coby TF-DVD7006.
The second question, I couldnt work that one out at first, but now i think I understand. If you plug the player into the mains, turn it on, red light shows. Light turns green when battery charged. Do not use until light turns green (if plugged into mains). In other words dont use the player while the battery is charging. If it isnt plugged into the mains then the battery cant be charging and you can use. Until battery gets too low :)
Nov 13, 2007 | Coby TF-DVD7006
Coby TF-DVD7005 Portable DVD Player Logo
114 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
