Question about Homelite Mighty Lite Lawn Trimmer
How do I feed string into my Homelite Mighty Lite 26ss grass trimmer? I don't have a manual and I can't figure it out. Thank you!
  • kyla_graham Jun 03, 2010
    Well I think I found the problem. I can't get the ball off :) It's locked in place.
    I think I found the problem. The ball won't come off. It's locked in place. Should it unscrew?
  • 416 Answers
Cut a 6 ft piece and wind it (starting with the middle of the trim line) around the head with each head going opposite directions. When you get it wound up, you will have two pieces sticking out in opposite directions and they can be clipped into the small plastic slots on the edge of the string canister. THen press the ball on, and attach to the trimmer.. Just keep the string the grooves and you will be fine...
OHYEAH!!! dont worry if it keeps coming unwound or pops off the trimmer at first, it will happen until you develop the technique needed for a quick replacement
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Posted on Jun 03, 2010
Testimonial: "Thank you! Your response helped me troubleshoot."
  • Remote Computer Rescue
    Sorry for the slow reply.....but the answer is yes.......it should unscrew counter-clockwise and must be removed prior to lifting off the string canister
    Hope this address the issue
    GOOD LUCK!!!!
Need to find where air cleaner is ?
If your unit has one, it would be in front of the carburetor. Some Ryobis and Homelite trimmers do not have an air filter on them, just a screen inside the choke cover.
Sep 08, 2011 | Homelite Mighty Lite Lawn Trimmer
I was given a homelite mighty lite 26VT and I can not figure out how to remove the spool to insert the string.
There is a threaded cap on the spool that can get very tight, but a pair of Channel-loc pliers usually does the trick to remove the cap. Getting the string to feed consistently is a trick that I have not figured out how to do...
Aug 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Installing new line on my string grass trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jul 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite grass trimmer won't automatic feed line when tapped on surface
the problem with it is its a piece of **** excuse for a line feeder if its a mighty lite. mine is new and in perfect condition and getting it to feed string is close to impossible.
Jun 07, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite 26ss weedwacker won't start, its getting spark and gas.
http://www.fixya.com/support/t2258508-homelite_mighty_lite_26ss_weedwacker
May 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Can't find manual to 26ss mighty lite trimmer. how do i open nylon spool? trying to pull nylon out of holes (somehow they retracted into the spool as I tried to start trimmer).
Hello jonandchima:
This is a Homelite Product.
You can Order a Manual from this Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information and Select "Need Manual" . Remember to Include the UT Numbers.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Homelite Mighty Lite Lawn Trimmer
Hardto Start
Hello jetsondent:
Good Luck
Respectfully
jbridger (John)
May 06, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
1,249 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
