Question about Dometic Refrigerators
Propane burner won't stay lit
The burner in my Dometic refrigerator lights up quickly but won't stay lit. There is good gas supply. The burner housing was recently cleaned out and it worked well after that. After sitting all winter without being used it now won't stay lit. It works well on 12vdc and on 110ac.
    Top Expert:
  • Dometic Master
  • 7,919 Answers
Bad flame sensor
Posted on Oct 14, 2017
4 Suggested Answers
  • 9 Answers
SOURCE: Dometic refridgerator won't stay lit on Propane
A bit more info is needed. What model #, and how old is it? In back, does it have a computer board (underneath a green or black plastic cover, appros 4" x 6")? Im guessing that it does, ('cause you get an error message,) Make sure that you have a good 12 volts going to the board at all times, and make sure that the glass fuses on the board are not blown. If that checks out, than its a real good bet the you have a defective board. For Americana models, you're going to need a Dometic board, and for other models, an aftermarket board will usually do. Althoiugh the OEM ones have a better chance of fixing your problem.
Posted on Jul 26, 2009
  • 79 Answers
SOURCE: Dometic refrigerator will not stay lit
sand your thermal cupler off or replace it not centing the flam
Posted on Apr 11, 2010
  • 2006 Answers
SOURCE: dometic rm2453. Works
Interesting! Did you remove a shield that was there before? The only time I have had a problem like that is when we took the shield coving the pilot light area off and didn't put it back on right. You might want to check and make sure that everything is in place.
Posted on Aug 17, 2011
CAN YOU MANUALLY LIGHT A DOMETIC RM2652 PROPANE FRIDGE IN A 2006 TRAILER
It will not light manually as the ignition probe is electronically controlled. If it doesn't stay lit normally then it will more then likely not stay lit when trying to light manually.
b2d344ab-6ceb-4320-bc24-f6c38ab91df8.jpg ArctiCold Refrigeration We keep it cold
Jul 24, 2014 | Dometic RM2652 Refrigerator
Dometic rm2453. Works perfectly on gas or electric or dc. But, won't stay lit driving down the highway. Flame costantly blows out. Perfectly...
Aug 17, 2011 | Dometic RM2452 Refrigerator
We can't get our Dometic fridge to light when it's turned to gas. Model number 2453. It works on AC and DC but just won't light at all on gas. The gas will light but won't stay lit in the...
If you are lighting the pilot corectly and waiting for the thermo couple to warm up and then setting it to on, then the thermo couple is probably bad. Good luck!
Jun 27, 2011 | Refrigerators
CHECK LIGHT COMES ON IN LIMP MODE
Hi!!
Check propane tank is open and full. The check light comes on when there is air on the line or no gas reaches the burner. If propane is OK, press power botton OFF and then ON and it will try to lit up again. This is standard procedure, sometimes you have to do it a few times.
Good Luck!! Don't forget to rate this post!
Aug 13, 2010 | Dometic RM2852 Refrigerator
Gas shuts off after 30 seconds
first try fitting a new thermocouple,its the short 1"stick that keeps the pilot lit....
Jun 02, 2010 | Dometic RM2620 Refrigerator
Apr 11, 2010 | Thetford Norcold RV Cooler/Freezer
Jul 26, 2009 | Dometic RM2652 Refrigerator
Why is it difficult to light our dometic refrigerator, when using it on propane?
Hi: In my travel trailer I find it is easier to light my Dometic if I bleed the lines by starting my stove top. It uses a lot more gas to get lit and floods the lines with propane. Your fridge uses such a small amount of gas it takes a long time to bleed the line to it. Don't focus on just the oven.... run any propane appliance on the way to it first. I hope this helps, Jeff
Jun 12, 2009 | Dometic RM2620 Refrigerator
Dometic rm 2652 fridge works on a/c. i get a check light on lp gas, i can light burner with flame, it stays lit
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Feb 25, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
