Question about Acer Aspire 5335-2257 Notebook
My ACER ASPIRE 7736Z-4809 will no longer show my DVD drive and I was trying to back up data files to that drive. My Optiarc DVD RW AD 7580S gives me this message: Windows cannot start this hardware device because its configuration info (in the Registry) is incomplete or damaged (code 19). I have used this drive in the past but can't today. What do I need to do?
    Guru:
  • 868 Answers
Check Device manager First if the DVD-ROM is detected there, check for any question marks on the drive exclamation or a red X question mark it is detect but no drivers are installed exclamation mark means it is installed and detected but drivers are incorrect or corrupt can still be fixed 99%, red X means it is either disabled or not responding.
go to run type REGEDIT then enter,Click HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Once you find your DVD-ROM look for upperfilters and LowerFilters on the list delete Both if it show both some time it can either be just one of the two, after deleting the filters restart your computer then try a dvd and a cd to make sure both types of disc are detected and working on the drive,
Posted on Jun 03, 2010
Testimonial: "Your solution solved my problem. Thanks."
  • ayonbaxter Oct 25, 2013
    Thank you this solved my problem. For a while I had this problem where 2 CD drives would show up and I had pure problems getting the ROM to read or write. So I realize there was some conflict going on. Not only did I find the upper and lower filters, but I also found that extra drive list in the registry. deleting the generic one solved that.
Won't burn DVD data discs, error code 0x207
Have you looked at this from ACER: http://acer--uk.custhelp.com/app/answers/detail/a_id/3410/~/error-code-0x207-shows-during-recovery-dvd-creation I'm sure you already know it seems to be a common problem. Every post seems to point to Media type , can't use RW disk, +or-, seems kink of finicky which seems odd. Only use DVD+R or DVD-R.
Apr 02, 2013 | Acer Aspire 53362524 Intel Celeron 900 2....
Optiar dvd-rw ad-7580s
Go to this
website http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/optiarc-dvd-rw-ad-7580s-ata-device-my-dvd-drive/fb3f6aa1-31c3-4f7f-9738-807977a1ea78
and read the article
Dec 22, 2012 | Acer Computers & Internet
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
Iam using ACER Aspire 5542G, with optiarc dvd rw ad 7580s sometime its recognising DVD's which i kept but, sometimes its not. It buffers for a long time when a DVD is Kept and when i click on dvd icon...
If the it's three month old then it is not about any dust collected on the lens, but the dvd drive, acer is giving lot of common problems like this, if you can return it. else do not try to repair claim your warranty. HP, Dell, Toshiba is much better and a little expensive :) anyway good luck
Jan 30, 2011 | Computers & Internet
Acer Aspire One cannot load the correct driver for Acer External USB DVD Slim . An error occured so that the optiarc dvd rw ad-7580S driver is not installed properly. Any kind of help please?
make sure the device is listed in the list of compatable products for your make and model,possibility could be faulty rom-disc,thats a pretty common type of fault
Sep 17, 2010 | Acer Aspire 5335-2257 Notebook
Having problems with my optiarc dvd rw ad-7580S ata device for acer labtop computer!
clean the dvd rw wihth lense clenaer or window cleaner put a few tinhy drops on the disk put in and when dik is dry its done, also unplugg and plugf bk in all connections esspecially ur dvd rw
Nov 23, 2009 | Acer Aspire 5335-2257 Notebook
ACER Optiarc DVD
just do a search for the model of your motherboard and u should find easly enuf
Oct 04, 2009 | Computers & Internet
OPTIARC DVD RW AD-7560A ATA DEVICE locked by region My (Acer Aspire 7520 running Vista HP) Optiarc DVD RW AD-7560A ATA Device has stopped working (tries to start but unable to find inserted discs)....
it might be a lens problem , if it was working ok before for sometime then its a drive related issue hardware try changing the drive go to ebay find a cheap one like under 60 bucks , also try checking with drive info tools
Feb 19, 2009 | Acer Computers & Internet
Optiarc DVD-RW AD 7560A - well recording CD-ROMs, but not DVDs
i had the same problems so i updated the firmware for the cd/dvd drive and now its working perfectly
Jan 01, 2009 | Sony Optiarc AD-7170S Burner
Open Questions:
acer aspire 5335-2257 replaced 4 pin power jack intermittent power, only runs with battery but barely charges. acer aspire 5335-2238. My son's friend recently asked me to take a look at his laptop because he couldn't get it to take a charge or run without the battery when plugged in. Right away I noticed the dc jack was charred and the plastic around it melted. He said the power cord "brick" got really hot, all the way to the tip where it plugs into the laptop. I know the bricks can get warm but he said it actually burned his sister. I ended up replacing the dc jack and 4 pin harness with a new one and figured this would solve the power issue. It won't get power with the original power cord and I also tried a few others that were similar. The only one that worked was an adaptor that I think went to a cordless phone or something like. The next problem was I had to fiddle with the dc jack to get the yellow battery light on. Still won't turn on without battery. The battery at this point is drained so I left it plugged in all day, at least 12 hours and the green light finally came on indicating a charged battery. The battery only charged about 8-9% and died fast. I tried more adaptors and got another one to light up the yellow battery light, again a small modem adaptor, not one with the brick. This time I left it over night and got about 12% charge. Both times the laptop turned on, booted up and ran until the battery died after about 5 min. I'm out of ideas aside from maybe a bios problem but I can't get it to stay on long enough to do anything about it. I don't understand why the new jack isn't working, it's a pretty simple install, no soldering. I looked real close at the board and didn't see any obvious fried chips or anything like that. Any suggestions would be great. I've had this 14 year old kid's laptop for almost 2 weeks trying to figure it out (I also replaced his keyboard, disc drive and cleaned it up) and he's calling me every day.
Feb 27, 2017 | Acer Aspire 5335-2257 Notebook
See all Acer Aspire 5335-2257 Notebook Questions
Acer Aspire 5335-2257 Notebook Logo
894 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
