Question about Zenith DVC2550 Multi-disc DVD Player
My player has power, but it will not open. - Zenith DVC2550 Multi-disc DVD Player
    New Friend:
Did you ever figure out how to fix this??
Posted on Jul 28, 2013
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray DiscĀ® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
How can I change the region on my Toshiba SD K860?
1. Power on the DVD player
2. Press the Open/close button on your remote control to open the drive tray and remove any disk
3. Press 2403960
4. Press 9 for multi-region playback. DO NOT Press Enter button on your remote control
5. You will see a 9 (region-free) on the TV (right corner)
6. Press the Open/close button on your remote control to close the drive tray
7. Power off the DVD player
8. Power on the DVD player and it is region free.
May 22, 2011 | Televison & Video
The power button is on but I can't get it to open, any suggestions?
If Your players power is on and refuses to open, it is either the disc tray is jammed or the mechanism is not functioning properly, what You have to do is to service the mechanism, To service the disc tray please follow the steps below:
  1. The instrument You will be needing is a screwdriver and gloves,
  2. Power off the player,
  3. Unplug it from the power outlet,
  4. Then You allow it to rest for about 6 hours, Then You put on Your gloves, and unscrew the screws around the player,
  5. Take off the players cover and check the mechanism on the left side of the player,
  6. Plug in the player then You power in on, press the open button and see if it will attempt to open, once it attempts to open,
  7. Then You apply a little force in pushing the disc tray in the direction it is supposed to open,
  8. Pull it out and in several times till it seems free and opens on its own when You press the open button,
  9. If it still does not open on its own, then it means the mechanism is bad and need to be replaced.
  10. To replace the mechanism, just carefully disconnect it and get a replacement,
  11. Reassemble the replacement into the player,
  12. Then You try to open the player, it will work this time,
  13. Reverse the process to reassemble the player back together.
Hope this helped. Thank You for using FixYa!!!
Jan 17, 2011 | JVC XV-S300 DVD Player
Cd compartment wont open and it is locked dvp sr200p sony
Ensure the child lock feature is disabled. Try Power resetting the Player.
Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons.
If the issue still persists, service might be required.
Jul 26, 2010 | Sony DVP-SR200P DVD Player
UNABLE TO OPEN THE FILE UNDER POWER DVD 6
which file format you r trying to open in power dvd player.
powr dvd player doe not support all formats.
i will suggest you to download and use the vlc player,it almost supports all video formats
May 07, 2010 | CyberLink PowerDVD 6 Deluxe Full Version...
LG BD390 Disk Tray does not open. Pressing the button on the player or using the remote does not help.
PLAYER POWERS UP FINE BUT DVD DOOR WILL NOT OPEN AND KEEPS DISPLAYING PLEASE WAIT
Nov 26, 2009 | LG BD390 Blu-Ray Player
The dvd player tray does not open
# Ensure that any locking feature on the DVD player is disabled.
# Attempt to open the disc tray.
# If the issue is not resolved, turn off the DVD player.
# Unplug the power cord from the electrical outlet for 10 minutes.
# Plug the power cord back into a functional wall outlet.
# If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
good luck!!!!!!!!!!!
Sep 20, 2009 | Toshiba DVD Player
Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
May 13, 2009 | Panasonic DVDS97S DVD Player
Door won't open
Those kind of problems just require that the door open one time. However, to do that you will have to take the cover off the player with the power off of course. Once you have take the cover off ( only a few screws ) you will be able to see the disk player well enough to see the back part of it. There are two ways you can do this, first, is to power the player back on, press the power button on. Then when you press the open door button or use your remote whichever, have your finger on the very back end of the carriage that holds the disk and push to the front gently as it tries to open the door, you will know because you will hear a short click from a relay. If you cannot open it after a couple of tries then power it off again and unplug it. There are only four screws that hold the disc player part in itself. Take those four screw off so you can lift it far enough to get to the bottom front of the disc player. Once you can do that, without the power on, there is a white neoprene part that moves from left to right or right to left to open and close the door. You will be able to see it and you can manually slide the part to whichever side it will move and that will open the door. You can gently push the door back closed and open it again a few times. Then place the disc player back in place with the screws in and power it up and open the door with the remote or button. It should open. What happens is that depending on how long the player has set on a wharehouse shelf or just around even if it is new, the lithium grease that they use for the moving parts dries out and it needs a little push and use to work properly again. Let me know if I can help in any other way.
Feb 09, 2009 | Sharp BDHP20U Blu-Ray Player
Dvd tray will not open
In order to open the disc tray.apply one of the following solutions;
--- Turn off the DVD player. Unplug the power cord from the AC outlet for 30 seconds.
Plug the power cord back into the AC outlet. Try to open the disc tray.
--- If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
--- If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons ,
- If the disc tray still does not open simultaneously press the RETURN + ENTER+ POWER buttons.
If the problem is still unresolved, a service may be required.
good luck...
Apr 06, 2008 | Sony DVP-NS400D DVD Player
Zenith DVC2550 Multi-disc DVD Player Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
