Everytime i use the OS recovery cd from dell i get as far as the blue screen downloading but then get 4-5 error codes oxooooo something and have to turn cpu off. How do i get passed those errrors?
  • installn2os Jun 03, 2010
    Is it true that once you create a cd you cant create another one? I went back to the screen and the option to create a recovery cd is still there.
    President:
  • 1,561 Answers
Anytime you see a blue screen downloading, the problem is that the os is corrupt, you will need to get a new os cd in other to solve the problem.
If the problem persist after getting a new os cd, then you will need to change the memory card on your system.
This are the two possible solution, so i advice you get a new os cd to load on your system because the os recovery cd you are trying to use is corrupt.
Take care.
Posted on Jun 03, 2010
I have a serious problem with my computer and I was wondering if you can help. You see, when I try to restore my compaq presario by clicking f11 when it starts up, it will load for a minute and a blue...
Hi there, please try this solution, no promises as it appears yo may have a fatal HDD error ot virus:
1. Power on the computer
2. Press F10 repeatedly when you see the HP or Compaq logo.
2. When the recovery screen appears, press Next and then Yes to perform a non-destructive recovery.
3. To perform a destructive recovery, click Advanced and then Yes.
4. After the recovery is finished, the PC will reboot.
cheers
iain
Apr 30, 2011 | HP Compaq Presario SR1265CL-B...
My daughters computer is a dell latitude D610 notebook running Windows XP.....when powering up XP starts to load and then goes to a blank blue screen....Is there a restore disc or something i can download...
Hi. I provided you a link where to download the restore disk. Once you have downloaded the restore disk, here's the instruction on how to use the disk.
Instruction:
  • Backup all the data you want to keep on an external hard drive, flash drive, or rewritable CD. Resetting your Dell to factory defaults will erase all data currently on your computer.
  • 2
    Insert the Recovery CD into your CD-ROM.
  • 3
    Reboot your computer.
  • 4
    Watch the text in DOS carefully. When prompted to boot from your CD, do so.
  • 5
    Choose System Restore and then follow the instructions presented. Once system recovery beings, it may take a few minutes. Once it's done, your system will reboot again.
  • 6
    Remove the Recovery CD from your CD-ROM and store it carefully. Your system has been reset to the factory default.
  • Nov 09, 2010 | Dell Latitude D610 Notebook
    MY LATITUDE D610 DOES NOT BOOT UP or RATHER IT GOES TO A BLUE SCREEN WITH AN ERROR CODE c0000218 . SINCE IT DOES NOT MOVE FROM THAT BLUE SCREEN I CANNOT DOWNLOAD THE SCAN AND REPAIR TOOLS U RECOMMEND...
    Unknown Hard Error, if a corruption of the registry.
    Run HDD diags and see if the drive fails, if it does, then the HDD is bad. You can try booting to you XP CD and running CHKDSK in recovery console.
    Otherwise, reinstall windows
    Sep 24, 2010 | Dell Inspiron 8600 Notebook
    Help! My Dell latitude d800 beeped than the screen went white. Than turned aqua so I turned it off for a half hour. When I turned it back on the windows screen pop up. Then it went blue and started...
    i think there is problem with your video driver or lcd
    you should hook your dell with external monitor and look out for error and then download a recovery cd from following link
    Windows Vista Recovery Disc Download — The NeoSmart Files
    Burn it to cd and boot your laptop with this cd and it will repair your windows
    Jul 21, 2010 | Dell Latitude D800 Notebook
    Blue Unmountable Error Screen
    run MEMTEST, DOWNLOAD MEMTES, BURN IT ON BLANK CD OR DVD, RESTART YOUR LAPTOP WITH THIS CD IN, CHECK THE PROBLEM, MAKE SURE IT PASSES ALL THE STEPS, ALSO TRY TO INSTALL OS FROM ANOTHER CD...MAYBE THERE IS CORRUPTED FILE ON CD OR IT`S SCRATCHED OR SOMETHING, AFTER ALL THIS IF YOU STILL HAVE SAME ISSUE- 2 ND STEP IS REPLACING YOU HDD
    Mar 08, 2010 | Dell Inspiron Mini 10 Notebook
    Sata hdd windows dell recovery cd will partition install windows
    The system is originally designed to use IDE HDD, make sure the necessary chages for Sata HDD are made in the BIOS, next make sure the Recovery disc is fine without any scratches. You can order a new Windows OEM recovery disc by calling Dell tech support (1-800-624-9896-US) and try installing the OS. The disc will cost you not more than $12.
    Nov 15, 2009 | Dell Dimension 4700 PC Desktop
    My NEC ND-3530A DVD drive causes my Dimension 3000 to go to the dreaded blue screen and dump. I have changed discs, downloaded updates, ran check disc, did a virus scan, everything that Microsoft...
    This could be a problem with the burner, but it could also be a driver conflict of some kind, or a software issue. What OS are you using, xp?
    What software are you using to burn with? (Try using this instead: http://www.cdburnerxp.se/)
    Try disabling the automatic restart so you can read the blue screen stop code and report it back here. (Go to control panel>system>advanced>startup & recovery and uncheck the automatic restart. You will have to manually shut down the system after you get the stop error code.) This page will help decipher the error code you get back.
    Possible MS help articles here and here. (You may need to reinstall the drivers.)
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    Aug 25, 2009 | Computers & Internet
    When i turn on my lap top which is a dell 1525 Inspiron it goes as far as putting your password in and from there it goes straight to a blue screeen and nothing else comes on the screen after that.
    just open spare the parts then u can do the foolowing things
    plug ot the battery for 10 minutes
    if it does working there is an extra another find it do as that
    if it is not workable u did want gone for customer care for dell company
    Jul 16, 2009 | Dell Inspiron 1525 Notebook
    Dell Dimension C521 w/Vista will not boot OS.
    There is no way around this you need to get your OS from Dell and reload.
    Sorry.
    Feb 19, 2009 | Dell Dimension C521 PC Desktop
    Computers & Internet Logo
    60 people viewed this question
    David Payne
    David Payne
