Question about Nokia N81 Smartphone
Key pad the number keypads work, but the main key pads like answer key pad and other keys dont work
  • gttq Jun 20, 2008
    cannot use my number 2 on keypad. phone goes crazy sometimes and enters its own digits. mainly 2's and 4's.
Help, n81 8gb keypad problem!!!!!
Posted on Feb 02, 2010
Open the front key face by placing a card on the side of the phone. careful not to poke it harder as there are some chips inside the front slide. once it is open, clean it or try to adjust the keypad face then place it back. If problem still exist, bring it to the mobile center for repair.
Posted on Aug 10, 2008
I dont understand when it says go to set up and press the numbers on the keypad what key pad and iv tried putting in the numbers and it didnt work
ok we need more info to help you with this problem what Receiver are you using, it could mean push the setup button then use the arrow keys on the keypad to move around but without more info it's very hard to help you with this problem.
Jan 23, 2011 | Audio Players & Recorders
Keypad in w350i not working...how 2 repair tat
Remove the external key pad and press the internal keypad on the phone board directly, may be the external key pad rubber is not contacting the one on the phone board.
Or you can loose the phone, and clean the internal part of the key pad. There might be dust on it, you could also use this medium to service your phone. If it does not work after all these, then I think you have to change the key pad completely.
I wish you the best.
Nov 23, 2009 | Computers & Internet
The number 9 key won't work on Nokia 6500s phone
It happens when the number 9 key is overused or does not press the main keypad IC,
Please take the Handset to the nearest repair place/Service centre who can change the keypad and tell them check the keypad.
They will be able to suggest you what needs to be done.
Thank you for using Fixya
Nov 16, 2009 | Cell Phones
Key pad does not always open door
It sounds like the contacts on the keypad are going bad. A new opener with the wireless keypad is the answer.
Sep 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keys not working
dont worry.its only the key pard problem.you need to replace the key pad and dont forget to ask the repirer to clean the circut board.avoid hard use of key pad.take care
Aug 21, 2009 | Motorola Mobility W230 Phone US with...
Keypad dosent work on my samsung SGH E315
hi im josh in cebu phils.friend may i help you? Friend the problem when the key pad wont work is the connection your keypad board or dome to the main board.all you have to do are: 1. open your phone with T6 screwdriver for phone and clean the key pad mat or board or dome with a soft pencil eraser and a small brush like tooth brush. 2. check the wire of the key pad connection be sure it has no moist ect. 3. check the keypad IC. if detached re solder it. 4. if you dont have the skills of doing these or if dont want to risk. you let the phone service center do the job.  thats all hope i helped you.good luck
Mar 14, 2009 | Samsung SGH-e315
Liftmaster key pad opens door with a single number punch
You are using a universal keypad and usually the 0 button is "enter" look up directions for the brand keypad you are using
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sprint motorola v3
you need to change the flexcable on the phone and also have the keypad flex reflash as well.
Jun 02, 2008 | Motorola Mobility RAZR V3
My Nokia 7610 Keypad Problem
my 7610 keys 2 , 5, 8 and * are not working. kindly give me any solution.
Jan 22, 2007 | Nokia 7610 Handheld
Keypard problem
this problem comes due to moisture so 1st of all wash the keypad with actone. and dry it. yet it don't work than check the keypad ic.
Dec 28, 2006 | Nokia 6230
Nokia N81 Smartphone Logo
253 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
