Question about Install Essentials 489P Responder 2-way Remote 902
My system is on a silent mode or something, it still engages and dis-engages, and locks and unlocks, just that when I press the transmitter, it doesn't beep and horn doens't beep.
  • 20 Answers
Sounds like the alarm is in valet mode. to get out just open a door, then lock, unlock, lock on the remote. should be fixed.
Posted on Jul 08, 2010
  • 416 Answers
Take the battery out for a few minutes then replace it, or if you have many custom settings, you have to press and hold the side button until options pop up.
IM GONNA BE HONEST, I HAVE NOT USED THIS DEVICE, BUT I HAVE A PRESTIGE ALARM WHICH IS MUCH THE SAME.
Hold the buttons in combinations. by themselves and so on until you get a menu, then press a button to change the value or the option, this is the best way to get to know your 2way responder....
GOOD LUCK AND PLS RATE THIS POST FIXYA!!!!!
Posted on Jun 03, 2010
How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
Theft Deterrent Arm/Disarm Modes
Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
Changing the Feature Customization Modes
  1. Turn off the IP dimmer switch.
  2. Turn the ignition switch to the LOCK position.
  3. Remove the BCM PRGRM fuse.
  4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
  5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
  6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
  7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
6.1.
Insert the key in the left front, right front, or liftgate door lock cylinder.
6.2.
Rotate the key from the center to the unlock position.
6.3.
Press the horn button on the remote keyless entry transmitter.
6.4.
Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
6.5.
Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
6.6.
Turn the key back to the center position and remove the key from the door key cylinder.
In order to exit and save the current feature customization modes use the following procedure:
  1. Turn the ignition switch to the LOCK position.
  2. Reinstall the BCM PRGRM fuse.
If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
Aug 25, 2015 | Cars & Trucks
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
Autopage xt74 alarm in silent mode
The only reason that your alarm would not chirp when locking and unlocking the doors is that the system is in valet. A visual notification that the alarm is in valet mode is the LED light is on solid. If the LED is on solid and you wish to make the alarm active again, turn the ignition on then, press and hold the valet/programming switch for two seconds. The LED light will turn off.
If the LED light is not on solid then, the issue may be with siren itself.
Sep 25, 2012 | Megatronix - TW71 - 5 Button 2 Way LCD...
The lock button on my key fobs will not lock the doors on 06 honda crv
CHeck to see if it is the right battery - Should be a CR1616 - previous year models, had a different battery.
Does the light come on on the key fob, when you push the button?
You may have to reprogram the remote - check the owners manual for instructions - if you can't find them...
Programming the Transmitter
NOTES:
• The system accepts up to three transmitters. The
transmitter codes are stored in a stacking-type
memory. If a fourth transmitter code is programmed,
the code for the first transmitter is erased.
• Entering the programming mode cancels all learned
transmitter codes, so none of the previously
programmed transmitters will work. You must
reprogram all of the transmitters once you are in the
programming mode.
• You must complete each step within 4 seconds of
the previous step to keep the system from exiting the
programming mode. Program the transmitters within
10 seconds.
1. Turn the ignition switch to ON (II).
2. Press the "Lock" or "Unlock" button on one of the
transmitters. (An unprogrammed transmitter can be
used for this step.)
3. Turn the ignition switch to LOCK (0).
4. Repeat steps 1, 2, and 3 two more times using the
same transmitter used in step 2.
5. Turn the ignition switch to ON (II).
6. Press the "Lock" or "Unlock" button on the same
transmitter. Make sure the power door locks cycle
to confirm that the system is in programming mode.
7. Within 10 seconds, press the "Lock" or "Unlock"
button on each transmitter. Make sure the power
door locks cycle after you press each transmitter
button to confirm that the system accepted the transmitter's code.
8. Turn the ignition switch to LOCK (0) to exit programming mode.
IF so, and more likely, the fuse on the car side of the remote, is probably gone.
Apr 25, 2012 | 2006 Honda CR-V
I have a 2000 ford mustang. Suddenly my keyless entry remote stopped working. I replaced the battery and turned the off and on 8 times and the locks cycled. after which i pushed the unlock but nothing...
The keyless entry system is controlled by the (GEM) - generic electronic module .
Keyless Entry The electronic door lock system has two main components:
  • generic electronic module (GEM)(14B204)
  • keyless entry remote transmitter (15K601)
  • NOTE: Battery power and ground must be remove before disconnecting the GEM connectors to avoid setting false codes.
    Power Locks Operation The power locks feature allows the customer to lock and unlock the doors via momentary switches located on the driver and passenger door. When the GEM detects a momentary press of the driver or passenger lock button, the GEM will supply power to the driver or passenger lock actuators for approximately 250 ms from relays internal to the GEM. When the GEM detects a momentary press of the driver or passenger unlock button, the GEM will supply power to the driver or passenger unlock actuators for approximately 250 ms from relays internal to the GEM.
    Remote Keyless Entry Door Locks Operation The remote entry feature allows the customer to unlock the driver door, unlock all doors, and lock all doors using a valid remote transmitter as long as the ignition switch is not in RUN or START. The driver door is unlocked whenever the GEM detects a valid remote transmitter unlock transmission. All the doors are unlocked when the GEM detects a second valid remote transmitter unlock transmission within three seconds of the first transmission. All the doors are locked when the GEM detects a valid remote transmitter lock transmission. If the GEM detects a second valid remote transmitter lock transmission within three seconds of the first transmission, the doors will lock again, the horn will sound for 20 ms and the parking lamps will flash for 200 ms to indicate the doors are locked. If the GEM detects the driver or passenger door is ajar during the second lock transmission, the doors are locked again and the horn is sounded twice. If the GEM detects a valid remote transmitter lock transmission within three seconds of detecting a valid remote transmitter unlock transmission, the GEM will lock all the doors
    • The doors do not lock/unlock using the remote transmitter
    • Ignition switch.
    • GEM.
    • Remote transmitter.
    • Remote transmitter batteries.
    • GO to Pinpoint Test C .
    You followed the program instructions to the letter ? Programming -Keyless Entry Remote Transmitter NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
    NOTE: All previous transmitter identification codes (TIC's) will be erased when programming mode is entered.
    NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM)(14B204), perform the following steps.
    1. Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
    1. NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met.
      Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
    1. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
    1. Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
    1. Take an have the vehicle checked for DTC'S
B1396 Power Door Lock Circuit Short to Battery GEM GO to Pinpoint Test B . B1397 Power Door Unlock Circuit Short to Battery GEM
Apr 12, 2017 | Ford Mustang Cars & Trucks
Replaced batery in key fob and now there is no connection between fob and security system...I can lock and unlock doors with the key and I can start car ...fob doesn't work; does not lock or unlock...
reprogram the remote transmitter. first leave driver door open all other doors closed,key removed from the ignition switch. insert key into the ignition switch,then remove it.press lock and unlock on the vechicle door lock control switch at 1 second intervals 5 times. close and repoen drivers door.press lock and unlock on the vechicle lock control switch at 1 second intervals 5 times. insert key into ignition switch. switch ignition on and off twice to program a remote transmitter code whilst erasing the original codes or three timre to check how many remote transmitters are currently registered.remove key from the ignition switch.system should now lock and unlock.twice to indicate programming mode or one to four times,slowly to indicate number of remote transmitters registered.for the solara press and hold lock and unlock remote buttons together, press lock remote button for a second period of 1 second. system should now lock and unlock vechicle.once to confirm, twice to indicate registration has failed.if required repeat button procedure to program remaining remote transmitters.note to exit programming mode close drivers door or insert ignition key.maximum of 4 remote transmitters can be programmed.if akk failed let dealership reprogram remote transmitters.
May 18, 2011 | 1999 Toyota Camry Solara
How to take automate car alarm off silent mode
{: ) When armed, the content theft deterrent (CTD) system is designed to deter vehicle content theft by pulsing the horns and exterior lamps for approximately 30 seconds when an unauthorized vehicle entry is detected.
An unauthorized entry can be any of the following with the CTD system armed:
• When any door is opened without first being unlocked using the keyless entry transmitter • After a battery reconnect, if the battery was disconnected with the CTD system armed
Disarming an Armed System/Silencing an Alarm
If system arming has been requested by the power door lock switch or the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the content theft deterrent (CTD) arm mode. Also, disconnecting the battery or pulling fuses does not disable the arm mode, since the BCM stores the CTD mode status in memory.
• To disarm the CTD system in standby mode, perform one of the following: - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and switch to the ON position. • To disarm the CTD system in the armed mode (non-event) or when activated (during an alarm event): - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and switch to the ON position Locking the Vehicle Without Arming the CTD System Locking the vehicle may be accomplished without arming the content theft deterrent (CTD) system. Use of the manual door locks or using the key to lock the doors will lock the vehicle, but will not arm the CTD system.
Apr 23, 2011 | 2007 Chevrolet Tahoe
I used csorb's instructions to reprogram a master key for my 2000 Lexus RX300. The ignition works perfectly, but the doors don't lock or unlock.
Hi!!
I believe your alarm is in the PASSIVE MODE, here is how it works.
PASSIVE MODE Setting (Arming) Anti-Theft System The system will automatically set 30 seconds after following methods are performed: Remove ignition key from ignition switch. Exit vehicle, and close all doors. After performing this, anti-theft indicator on left side of instrument panel will light continuously for about 30 seconds. After 30 seconds, anti-theft indicator will blink once per second. When system is set, doors cannot be locked or unlocked using door lock control switch.
CANCELING THE ALARM AND REPROGRAMING MAY SOLVE YOUR PROBLEM.
Canceling Anti-Theft System Setting (No Alarm) When system is set (armed), but alarm is not sounding, use one of following methods to cancel system setting:
  • Unlock left or right front door using key.
  • Unlock all doors using remote keyless entry system.
  • Insert key in ignition switch and turn to ON position (this is operative only when anti-theft system has not been triggered).
HERE IS HOW TO REPROGRAM THE ALARM IN CASE YOU NEED TO RESET IT.
PROGRAMMING
PASSIVE MODE NOTE:Initial mode is passive mode off. If there is a different signal in middle of programming, signal is invalid.
Programming Passive Mode Off
  • Remove ignition key from ignition key cylinder. Ensure all doors (including back door) and engine hood are closed and unlocked. Perform all of following methods within 30 seconds:
  • Lock or unlock any door with key or remote keyless entry system.
  • Open driver door.
  • Lock and unlock driver door lock knob 3 times.
  • After performing this, system should start force lock after 2 seconds. Perform all of following methods within 20 seconds:
  • Unlock driver door lock knob.
  • Close and open driver door 2 times.
  • Lock and unlock driver door lock knob.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be off.
Programming Passive Mode On
  • Remove ignition key from key cylinder. Ensure all doors, engine hood and luggage compartment door are closed and unlocked. Perform all of following methods within 30 seconds:
  • Open driver door.
  • Close and open driver door 4 times.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be on.
If you need further assistance, please provide an email address to send more info on your security system
Good Luck!! A 4 THUMBS UP rating would be greatly appreciated for this solution. Thank you for using FixYa!!
Mar 01, 2011 | Lexus RX 300 Cars & Trucks
Need to reprogram new keyless entry fob.Thanks.
You may program up to 4 transmitters, using following procedure:
Transmitter Programming Procedure (No Tools Required)
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN position in order to exit the key-less entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation
Jul 22, 2009 | 2001 GMC Jimmy
Keyless remote wont work
try to reprogram the remotes using these instructions..........
i assume for 02 explorer not th 05 frestyle listed (although similar procedure)
Remote Transmitter Programming NOTE: All remote transmitters are programmable and must be set at the same time.
  1. Make sure that the anti-theft system is not armed or triggered and key code programming is not active.
  1. Open the door, then press the driver door lock control switch UNLOCK button.
  1. Turn the key from OFF to ON 8 times within 10 seconds, with the eighth turn ending in ON. If the program mode is sucessfully entered the doors will lock and unlock to confirm.
  1. Press any button on a remote transmitter, and the doors will lock and then unlock all doors to confirm that the remote transmitter is programmed. All remote transmitters must be programmed within 20 seconds of each other. Up to four remote transmitters can be programmed to the vehicles security module each time programming mode is entered.
  1. If the door locks do not respond for any remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Locks, Latches and Entry Systems — Late Build or Locks, Latches and Entry Systems — Early Build in this section.
  1. NOTE: Exiting is acknowledged by locking and unlocking the doors if at least one remote transmitter has been programmed.
    Exiting the programming mode is accomplished if one of the following has occurred:
    • The key transitions to OFF.
    • 20 seconds have passed since entering programming mode or since the last remote transmitter was programmed.
    • Four remote transmitters have been programmed.
Jun 02, 2009 | 2005 Ford Freestyle
Install Essentials 489P  Responder 2-way Remote  902 Logo
586 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
