Question about HP Pavilion dv6000z Notebook
Replacing dvd/cd-rom drive on gateway laptop
Does anyone know how to replace the existing cd drive with a cd/dvd rom drive on a gateway laptop? My laptop fell a few days ago, and the LabelFlash DVD player will not recognize any cd/dvds in the player. It flashes on and off and acts like it wants to read, but can't quite get there. I was going to pull it out and reinsert it to see if that made a difference, like the plug might have been jarred loose. I don't really know how to get this dvd out without breaking anything. I cannot see a release anywhere. Can you help? Thanks Rich
  • 472 Answers
Without knowing your specific laptop, look underneath about 5 inches from the edge where the drives slides in. You should see a screw there but not holding a panel.
Remove that one screw, pop the drive open and give it a gentle pull, it should just slide out.
Most laptop drives are the same with the exception of the faceplate and the bracket (surround) that is attached to the bare drive.
This is removable and can be transferred to another drive. Careful not to lose any of those tiny screws =)
Posted on Apr 09, 2008
AM USING A GATEWAY LAPTOP WITH OPTIARC DVD RW AD7640S ATA. IT WAS WORKING INITIALLY BUT FOR SOMETIME NOW WHEN I INSERT ANY CD, IT TELL ME TO INSERT A CD INTO THE DEVICE EVEN THOUGH ITS INSIDE. AM USING...
2 possible issues....1 driver for the dvd rom is corrupt.....try using the cd the unit came with and re-installing the driver....2 bad rom....if your under warranty...try just sending the rom in....if now...flip over the laptop....find the 1 screw that will let you slide out the rom...look for the part number/ model number....find one on ebay....real cheap there...usually under 10 bucks....try cc.texas.smart.shop (member) that is me and i have a few gateway roms avail.
Oct 12, 2010 | Gateway (5500652) (  5500652)...
Need to install a new CD/DVD drive in a Gateway Laptop model 7110GX Does anyone have info on how to do this plus recommendations for a replacement drive for this model. Thanks, Bill
Here's a direct link to the service manual for this laptop:
http://support.gateway.com/s/Manuals/Mobile/8511184.pdf
On page 36 of this manual, you will find details on how to replace the CD/DVD drive.
Oct 22, 2009 | Gateway 7110GX PC Notebook
Dvd cd-rom will not play any cd, you can hear them spinning but that is as far as it goes. I have tried updating the drivers and it says they are up to date, I have tried uninstalling the dvd cdrom and...
Try to use brand new scratch free CD/DVD. Try to Unplug CD/DVD ROM from laptop and Plug it again. If problem persist, replace your CD/DVD Rom.
Regards;
Hassan
Sep 19, 2009 | Gateway ML6732 Notebook
I can't insert any cd's.
Maybe the laser eye is jammed. It tracks back and forth reading data from the disc.
You may either replace the drive or have it repaired.
I had one on my PC do the same vibrating, clicking noise. It only cost 40.00 to replace.
But for a laptop, you're looking between 60-100 dollars to replace.
You can see how much it would cost to repair first, but my guess is it would be cheaper to replace.
Jul 12, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Cd rom drive not working, will not read discs
If it will not read anything and doesn't spin up then it's time to replace it.
Here's one on ebay that should work for you...
http://cgi.ebay.com/GATEWAY-4000-4028-4520-DVD-CD-RW-COMBO-DRIVE_W0QQitemZ170320375444QQcmdZViewItemQQimsxZ20090412?IMSfp=TL090412151007r16432
This is not my auction....I live in Missouri.
Apr 26, 2009 | Gateway 4028GZ Notebook
My cd rom drive will not recognize any cds or dvds. When I put a disc into the drive it will tell me to insert a blank disc into the drive. I have tried over ten different discs (including the one that...
what do you mean not recognized? not detecting the drive or not reading? if not recognized by windows you can check the driver for drives in the windows if not reading it is the lens problem..if the lens problem, the solution only is to replace the lens or to replace the whole drive
Mar 07, 2009 | Computers & Internet
Gateway M505 internal cd-rom slot does not take in a cd dvd
Not unless you know A LOT about electronics. It's best to just remove the drive and buy a replacement on ebay.
You can either search for M505 drive
or use the part numbers from the drive if you want an exact replacement.
Best of luck!
Feb 25, 2009 | Gateway M505 Notebook
Depends - what gateway? the one you listed under?? Because the model you posted with already came with a DVD drive.
Reply with the model of your machine and i can probably find you help. Gateway usually has instructions on their site.
The instructions for the M305CRV are here.
That model can use pretty much any standard laptop CD if you dont mind the face not matching get a generic drive like the Sony CRX880a at
http://www.directron.com/slimoptical.html
Sep 16, 2007 | Gateway M305CRV Notebook
Removing the DVD-ROM drive
hi the removel of the dvd drive is easy as taking out the battry 1. Remove the battery from the bottom of the laptop 2. Make sure the laptop is NOT plugged in. 3. There is a release button for the CD/DVD ROM drive on the bottom of the laptop, simply press and hold the release switch and pull the CD/DVD drive out. replace it with your new 1 good luck
Apr 06, 2006 | Toshiba Satellite Pro A10 Notebook
HP Pavilion dv6000z Notebook Logo
207 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
