Question about Kicker CVR12 Car Subwoofer
I have a cvr 15 kiker and it was bumoing and moving and forth alot and the cables from the ohm broke off how do i fix
Cut the rubber like tarr coating of right at the cone. make you a longer wire that u can put in the broken wires place and sodern the wires back up. then finish by appling a heat resistant electrical addhesive at each connection. SOLVED
Posted on Jun 24, 2010
  • 94 Answers
If it broke off the cone you cant fix it to my knowledge
Posted on Jun 07, 2010
How can i fix broken shifter on 2003 ford super Duty , automatic ? Seems like a pin broke and i cant put it into gear or out .
hey look under neath where ur driver footpedals are. chances are that the rubber grommet on the end of ur cable came off or broke.. look up into the column area an look for the black cable goin to a pivot point on shifter arm. reconnect. but will prob need new cable cause if end is no good will fall of again. move shifter back an forth to help u locate area of cable
Jun 28, 2015 | Cars & Trucks
How do i wire a single 12" kicker cvr dual 2 ohm
Simple power fom amo to power on sub. Ground on amp to ground on sub
Feb 28, 2013 | Car Audio & Video
Ihave 2 kiker 15 inch solo l5 1500 max 750 rms so what kind power , how many chanal am.p i need ? im confused......
If they are 2 ohms I would recommend dropping to 1 ohm for maxium out put. To drop to 1 ohm you are going to run the 2positives and 2negitives together in either a bridged or monoblock 1500w amp. After doing so i would get the spects for the speakers freq. ect. or go to a quality audio store and most of them will help tweek it for free. I would recommend Kicker ZX1500.1amp for best compatiblity.
Nov 07, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How you hook up 15 inch kicker cvr show diagram please
Here are a few wiring diagrams to get your started.
Oct 01, 2010 | Kicker Car Audio & Video
I have 2 15'' CVRs and a 1200w amp
1 OHM...ONE... sheesh now thats a low resistance for anything... If they are only 500 watts and they are in parallel, series well NO.. your amp puts out wayyyy too much for those speakers.. 1200w versus 500 watts by 2... srill NOT enough "Head room" for it to be safe... about half is all you could expect before Pop.. sound is heard.
Mar 05, 2010 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
Wireing two dual 4 ohm kicker cvr 15s on a memphis pr1000 at a 1 ohm load. I trying to get these kickers to hit harder. Do I need a bigger amp or what?
CVR series do not have large power handling capabilities.
Your subs will melt before the amplifier is used to its full potential.
If the subs arent in a ported enclosure - do that.
They both handle 500w rms - so the pr1000 is perfect.
bass response is all in the enclosure!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
How do you hook up 2 15 inch cvr to 1 ohm
Hello juanelreypla,
If your CVR's have dual 2 ohm voice coils, they can only be wired for 0.5 ohm, 2 ohm, or 8 ohm final loads.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=3
If they have dual 4 ohm voice coils, they can be wired to a final load of 1 ohm. Wire the voice coils in parallel and then parallel both subs. Like the diagram in Wiring Option #1 shown here.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=4
Nov 10, 2009 | Kicker CVR12 Car Subwoofer
I have 2 12 in kicker cvr tryna drop to lower ohm
http://www.colomar.com/Shavano/dvc_spkr_wiring.html
Use the above site for several wiring schematics on dual voice coil speaker hookups. It will show how to wire for different impedance.
Also, I think the CVR 12's come in 2 ohm and 4 ohm impedance. See if you can check yours to determine which you have....
Jun 28, 2009 | Kicker CVR12 Car Subwoofer
15 cvr 4ohm trying to drop to 1 ohm
Are these Dual Voicecoil Subwoofers? Are there 4 terminals on each sub for wires?
If they are Dual 4 ohm voicecoil subwoofers
- connect both + on subwoofer 1
- connect both - on subwoofer 2
- connect both + on subwoofer 2
- connect both - on subwoofer 1
This will give you a 2 ohm STEREO load.
To get a 1 ohm MONO load...
now connect only one of the + on EACH sub to the + on the amplifier.
and the - on EACH sub to the - on the amplifier.
You now have a 1 ohm mono load.
If your speakers are 4ohm single voicecoils (one pair of terminals) the lowest impedence possible is 2 ohms.
This is wired in the same fashion. Both + on the subwoofers to the + on the amp, and both - on the subwoofers to the - on the amp.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 11, 2009 | Kicker CVR12 Car Subwoofer
Need to know how to wire 2 15 inch cvr to a zx1000.1 amp at 2 ohms
If they are 4 ohm single voice coil subs, just connect all the negatives together and then all the positives together. If they are DUAL vc's then need more info.
Aug 04, 2008 | Kicker Car Audio & Video
Kicker CVR12 Car Subwoofer Logo
97 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
