Question about Uniden Cordless Phone
Model#25865 2 line cordless, will not rollover to second line
We have two lines at this business. When we have someone on hold on the primary line, the cordless phone will not rollover to the second line when another call comes in like our corded phones do. Is the phone not capable of doing such? Help!
  • cowgirl5823 Apr 09, 2008
    The second line never rings. It won't rollover????
    Genius:
  • 1,027 Answers
The handset should display which line is on hold, when the other line rings the handset operator would have to push the corresponding line/talk/flash button. e.g if line 2 is on hold and flashing, press line1/talk1/flash button.
consult manual
Page 30-31
Posted on Apr 09, 2008
  • Mark Williams
    Mark Williams Apr 09, 2008
    Handset Ringers
    You may program the following items independently for LINE 1 and LINE 2 under the RINGER menu; Ringer Volume, Ringer Tone, VIP Melody and Key Tone. To access the RINGER Menu:
    1. Make sure your phone is OFF (not in talk mode).
    . Press the MENU soft key to go to the main menu.
    . Use the 5 or 6 buttons to scroll to RINGER.
    4. Press the SELECT soft key to confirm.
    5. Use the 5 or 6buttons tos to select LINE 1 or LINE 2 for setting line 1 or line 2.
    6. Press the SELECT soft key to confirm.
    Genius:
  • 3,422 Answers
HI,
Click HERE to download the manual to find some troubleshooting steps.
You need to have adobe acrobat reader to view the manual in pdf format.
Click here to download it if you don't have.
Goodluck,
Please don't forget to rate the solution.
    Master:
  • 788 Answers
The manual is available here: http://telecom.hellodirect.com/eBiz/pdf/phones/GE_25865_Manual.pdf
I'm looking through it to see what I can see.
  • Dean Joly
    Dean Joly Apr 09, 2008
    The only mention of on hold in the manual is this:
    Hold:
    Press the HOLD soft key to put a call on hold. LX ON HOLD shows in the display, where X is the line number.
    To take a call off hold, press the UNHOLD soft key.
    • To switch a call on hold from the base to the cordless handset, press the TALK/LINE1/flash1, TALK/LINE2/flash2or handsfree button on the handset.
    I can't see anything about answering a second incomming call. My guess is that like most cordless phones the base can only have one channel with the handset. I would assume that if you are using the handset on one line and the second line rings that you could answer it using the speakerphone in the base and vice-versa but you probably can't use the handset with both lines at one. Same would be true if you added an optional cordless handset to the mix, the second handset would be unusable if the first one was in use.
  • Dean Joly
    Then this is not possible for this phone set. Sorry.
4 Suggested Answers
SOURCE: Single Line Cordless Phone with two mailboxes
There are a number of VTech 1-line phones with 3 mailboxes.
Posted on Dec 28, 2008
johncaman
  • 201 Answers
SOURCE: How to dial out on a uniden Cordless phone on a pulse line
I still need a model number, but if it's not possible and you reeeally want to use the cordless, if you have a modem in your computer, you can have it dial pulse, pick up the cordless, and hang up the modem......
Posted on Mar 13, 2009
SOURCE: No dial tone on Uniden Dect 6.0 land line and portable phone
We've had the same problem with our new Uniden phone. Sounds like someone's on the other line - no dial tone and answering machine doesn't work. The telephone line works though because we plugged our old phone in and it works fine. Any solutions anyone?
Posted on Feb 05, 2011
My M7310 won't forward a call to the next open line but gives a busy signal
Hard to answer because your problem description does not match the part.
Nortel Meridian M7208 Corded Phone is a digital phone which works off a phone system.Also note that the carrier controls the rollover, not the phone or its system.
Once you have more/proper details maybe you can be helped.
Dec 14, 2012 | Nortel Meridian M7208 Corded Phone
KX-TG5622 -
MAKE SURE HAND SET 1 IS IN HANDSET HOLDER 1 AND THAT HAND SET 2 IS IN CRADLE 2. MAKE SURE TO POWER BOTH PHONES OFF AND THEN ON. THEN WITH POWER ON BOTH PHONES LET THEM SIT IN THE CORRECT CRADDLES FOR 30 SECONDS. TEST YOUR CONNECTION BY USING ANOTHER PHONE. ITS A CHEAP WAY TO SEE IF IT IS DUE TO HOUSEHOLD WIRING. GOOD LUCK.
Aug 12, 2007 | Panasonic KX-TG5622M Twin Cordless Phone
Phone lines are not rolling over to the other lines, also when retrieving a call from line 2 ..I can here the person on hold but not able to speak with them.
The rollover trouble is a service provider issue, you need to call your service provider to report it. The second trouble could be related , I would report it to the service provider also. Once the rollover rissue is fixed, test for the second trouble again.
Jan 24, 2011 | AT&T ATT-974 Corded Phone
When the phone is in use, and someone calls - they cannot leave a message
Now that's a thought. A single line device and how could it possibly accept another call when you're using it?
Some people get central office based voicemail or use call forwarding busy to send it to an answering service. Whatever you do, it will be external to the cordless phone line.
Carl
Sep 22, 2010 | Panasonic KX-TG1033S Cordless Phone
I just want to make sure that I am shopping for the right product. We have a dental office with 1 phone#, but we have a rollover line. Our fax has it's own# which "was" what we called line 3 but as of...
Yes, you can use a regular 2 line cordless phone with your 4 line corded systems. The only concern is when you put someone on hold. The on hold function may not release if you have different makes of phone. If you already have Panasonic get a Panasonic 2 line cordless phone with the on hold feature.
Yes, you can just take line 3 and plug it into your new fax. I might suggest looking into a fax to email service instead of buying a new fax. If you receive more than send it's a great way to save on the phone line and paper.
Digital phones are pretty secure, no one will accidentally hear your conversations. It is not encrypted but I think it would be perfectly fine in your office.
Greg
Feb 18, 2010 | RCA 25205RE1 Phone
Is it possible to do 3 way calling with the Panasonic KX TG6071B
Not unless the phone as 2 lines but u have to call the both people or the person you called can but it go's both ways you just have to press the talk button then call someone then press talk again then call that person then press talk again and you all three should be on the same line
Nov 18, 2009 | Audio Players & Recorders
Phone screen says line is busy but it isn't. people can't reach
here is a link to a page where you can download the manual for free hope I helped
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/model.KX-TGA630S
Aug 31, 2009 | Lands Phones
Kxtd816 how to do rollover or call forwarding line busy
Roll over or hunt group is handled by carrier
Mar 18, 2009 | Lands Phones
Need to reverse line 1 and 2 so that line 1 is the primary number
you could swap at the demarc(where telco responsibility ends) usually a box with screw down lugs one side marked customer the other marked phone co.
Jul 24, 2008 | GE 29439GE2 Corded Phone
Uniden Cordless Phone Logo
290 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
