Question about GE JRP15 Electric Single Oven
Flashing f 7
Oven control pad is beeping and flashing f 7
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F7 means that the control panel has gone bad and should be replaced with a new one. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
Jenn air expressions double oven
F-7 error code means that the Function Key is stuck or shorted out. You will have to replace the touch pad or if the touch pad is part of the clock, you will have to replace the clock (ERC).
Aug 18, 2014 | Jenn-Air Ovens
F-7 code has been flashing, along with constant beeping. This has happened about 5 times over the past 2 months. Eventually it stops but now we resort to flipping the fuse off to get rid of the noise. ...
Hello Marylou,
The F7 code means the same thing on all domestic (USA) brand ovens.What is means is that a button on the touch pad is shorted (welded together) out. Since you did not include brand or model#
i will give you the following advice, if your touch pad is a seperate part that plugs in clock (also called the oven control,or eoc..electronic oven control) then just the touch pad can be replaced,on certain brands or even some models within a brand the touch pad is integrated into the clock/oven control or eoc in that case the complete touch pad/control asm. is what needs to be replaced
Hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Ovens
Error Code F1 displays once in a while. What does it mean?
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
1. Disconnect power to stove
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
7. If you get the F1 and beep, replace the ERC.
8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
* ERC - Electronic Range Control
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
Apr 20, 2011 | Ovens
My oven keeps beeping and flashing an f-7.....what can i do to stop it?
Turn off house breaker to the unit at the breaker box of your home. This will be a double breaker.
F7 Touch pad or Control board...... Most techs start with touch pad.
Sep 05, 2010 | Maytag CWE5800A Electric Double Oven
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
The F7 alert keeps flashing/beeping on my JKP27 GE electric double oven even after clearing it or cutting the power to the oven for a period of time. Any suggestions? Thanks!
Ya either have a stuck keypad or a bad oven control. To see what it is you push the clear/off pad, disconnect the ribbon from the control and wait 32 seconds, to see if the if the F-7 code occurs again, If it don't then bad keypad, if it does then bad control.
Jan 28, 2010 | GE JKP28 Electric Double Oven
I have an in the maytag gas oven that keeps beep and show f-1 when its shut off
This simple test will help determine whether the ERC (Electronic Range/oven Control or Clock) or the touch pad is defective when this error code is present.
1. Disconnect power to the range/oven (unplug the range/oven power cord or turn the power off to the range/oven at the circuit breaker). It is very important that the power to the range/oven has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC/EOC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back (usually accompanied by a beeping sound).
7. If the code comes back and the beeping as well, replace the ERC(control board). If it does not, replace the touch pad.
Nov 02, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
F1 message flashing, annoying beep in the middle of the night
you could have a bad touch pad or ECU which is the main control board.
Sep 16, 2009 | Amana AOCS3040 Electric Single Oven
Range keeps beeping and flashes F-1
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Jun 19, 2009 | GE Ovens
Double GE wall oven - F7 code
from repairclinic.com:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 | GE Ovens
GE JRP15 Electric Single Oven Logo
102 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
