Question about Casio Watches
How to change the battery in a CASIO CA53W-1 Watch with Calculator
    Problem Solver:
  • 15 Answers
Open up the watch. there is a small spring that could fall out. dont lose it. use a small pin to pull battery clip off. put new battery in, replace strap and pink plastic. short the tiny contact labeled AC with the + on the battery. check that the clock now operates. lastly, reassemble
there is a spring inside that goes betweeen one of the contact holes. dont know which.
Posted on Dec 27, 2013
Benimur
  • 6966 Answers
SOURCE: casio watch problem
Appreciate the direct "Ask Me".
Offhand, I would say yes to the battery replacement. Though watches are not within my immediate field. This would be based on your post "2-5 minutes behind". As to the "lost signal" after a reset, may I request that you post back the specific model number pls.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
  • 183 Answers
SOURCE: Changing the battery on My Casio watch module 1848. Two
The contact springs most likely have nothing to do with your screen being black.
The watch will have an "AC" or all clear function that needs to be performed. Check the back lid for AC or reset instructions. If there are no instructions there then you will have to visit a watch repairman/technician to have this procedure performed as it involves touching the AC pad on the circuit board to the back of the battery already installed. The circuit board is easily damaged if not performed properly.
Posted on Sep 17, 2009
escapement
  • 2334 Answers
SOURCE: Hello,i've got an old casio c 80 calculator watch
Clean the contacts. Get the sharp needle and scrape both contacts. If it does not work, you need a watchmakers help. Rate me, plz.
Posted on Feb 04, 2010
  • 15 Answers
SOURCE: Casio DBCW150-1 Databank watch (battery change)
DONT THROW IT AWAY THAT IS A COLLECTORS ITEM... You can get it taken care of at www.casiowatchrepair.com or call them toll free 877.659.0761 and have them take care of it, the watch will be as good as new.
Posted on Feb 23, 2010
SOURCE: Casio 1170 ATC-1200 watch needs to have batteries changed
I'll post in case somebody still needs this. This is the general procedure to switch the ATC 1200 from meters to feet. You can also switch the ATC 1200 (1170) from C to F. This is very helpful if you change the batteries and the watch gets reset to meters.
Also note, when you pull out the two batteries, you may not get the watch to come up. This is because of a race condition when the watch gets power. To fix this, look for the AC mark on the inside of the watch. Under this marking, in a little space to the left, are two copper pads. Short this out with a small screw driver to get the watch to ground zero.
To fix the Metric measurements:
1. Go to the home screen on the watch. This is when the the 3 letter abbr for the day is at the top. Also, if you cycle the mode button, it is the screen where the final beep is "high."
2. Then press the "memory" button, which will take the home display to the data screen. This shows current time, pressure and temperature.
3. Hold down the adjust button, until the set screen comes up.
4. Tab the mode/select button on the watch until you get a flashing C. Then press the memory button to toggle to F.
You can adjust all the measurements from this screen.
Posted on Dec 30, 2010
My Casio WV-58A keeps losing time and date.I reverts to date 1-1-2005 . This is my third wave-cepter. Is there any to fix this malfunction. This watch is just over two years old.
Try the battery first. Make sure to do the all reset inside of the watch after changing the battery. If it is not the battery send it to Casio. They may change out the complete module.
Jan 17, 2018 | Casio Watches
How to change the battery on my casio w-753 watch
change the battery on my casio w-753 watch Lee, Check the attached links,video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
replace the battery in the watch casio 753 CAR FLIP REMOTE CONTROL ALARM...
How to replace the battery on Casio watch
CASIO 753
Aug 02, 2016 | Casio W753-1AV Watch
How to reset a casio g shock watch
HOW TO set your time on a G-Shock watch - YouTube
? 0:56
https://www.youtube.com/watch?v=_cwKYE1JMXM
Apr 8, 2013 - Uploaded by JseanSSent
This is a how to video on setting your G-Shock. ... Casio GSHOCK GA110GB-1A REVIEW ' How To Set Time ' LIGHT DISPLAY - Duration: 2:59.
Reset gshock - YouTube
? 1:41
https://www.youtube.com/watch?v=s6XVUqui6Nw
Jun 7, 2014 - Uploaded by aswan yusof
Tutorial how to reset gshock after changing battery. ... Reset gshock .... GA110-1B Stealth Black Casio G-Shock WatchReview - Analog DIgital ...
Dec 29, 2015 | Casio Watches
I just want to take my Casio calculator watch off of military time.. :(
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Jan 04, 2011 | Casio 8 Digit Calculator Watch Ca 56
How do I replace the watch battery for Casio DW-6900?
mcdevito75 here, Casio uses an LCD crystal, Liquid Display Crystal, during a battery change any, any un do pressure remopveing or replaceing the battery could destroy the LCD. Take my advise, with a casio watch, look for a small watch repair shop in your area for the battery change. I"ve ruined many of my casio watches during battery change.
Aug 27, 2010 | Watches
I need to change a battery in a baby g watch
mcdevito75 here, Casio watch with the LCD display, any wrong pressure on this display and your Casio is ruined, the liquid display can break very easily. BEST BET, look for a small watch repair shop in your area for this battery change.
Jul 14, 2010 | Casio Baby-G Wristwatch
Does not start after battery change. buttons are not functioning. display is fixed on 1- 1 SAT. light is off. I tried to reset shorting AC and [-] for more than 3 sec. but nothing happened. I concern it...
mcdevito75 here, Return your watch to whoever replaced the battery for adjustments. ------ If you replaced the battery yourself, you may have mis-aligned the buttons that press against the quartz movement to change the display, you"ll have to go inside the watch and make sure the buttons are touching where they are suppose to. It"s also ossible your new battery is weak from a long shelf life. Here also is Casio contact number, 800-706-2534 Optn. 2
Jul 13, 2010 | Casio WVA105HDA Wave Ceptor watch
How do I replace the battery
mcdevito75 here, This can be very, very tricky on a Casio watch, Casio"s have an LCD liquid crystal Diode in the face and any un-do pressure on the face will break it. Best Bet, look for a small watch repair shop in your area to change the battery, a small shop will save you some money on the cost.
Jun 23, 2010 | Casio DB-1500-1 Data Bank Watch
Change time on Casio CMD-40
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
Dec 15, 2009 | Casio New CALCULATOR CASIO with TV REMOTE...
Jul 06, 2009 | Casio E-DataBank DBCW1501 Wrist Watch
Watches Logo
1,480 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
