Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Dishwasher will not start.
I pushed the cancel button and the clean light blinks, but dishwasher will not start. Thanks! Margaret This dishwasher is less than 3 years old and is falling apart. The utensil basket is held together with twist ties. :)
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
  • A. Dippold Jun 30, 2011
    Thank you for your solution, Rylee. It worked like a charm. I don't even use the heated water cycle, as my hot tap water is already set at a rather high temperature. Don't understand why the darn thing would therefore attempt to sense a temp increase in the first place. Could it be that the sensor is malfunctioning, and if so, is there anything I can do - other than call the repair service, that is? :)
Model MDB7749AWB. Why does it stop mid-cycle?
Defective washer control board is the most common fault.
Mar 15, 2017 | Maytag Dishwashers
I am locked out of cycle with clean light blinking green and cannot find my manual, dishwasher is about 1 year old. Is there a sequence to break this cycle? I turned off power for 60 seconds to no avail.
Hi
I have not seen this model in Australia, but normally if you hold down "Start/Stop" button for 3 to 5 seconds, that should clear the cycle.
Otherwise if you have a Clear button press that for 3-5 seconds.
Ash
Sep 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a kitchen-aid dishwasher model # KUDio1ibl6 and it will not come on and the clean light flashes 7 times then pauses and blinks 7 time again. Do you have any Idea what this code stands for I do not...
Hello Asa,
The light blinking seven times is a error code specifically it's error #7 .The E-7 error indicates the part called the flow meter is bad. To clear that error code and get the dishwasher to start push within 3 seconds
HIGH TEMP WASH -HEATED DRY-HIGH TEMP WASH- HEATED DRY
then push CANCEL sereval times to dishwasher shuts off..it should start and run then
If the blinks 7 times again the flowmeter will need to be replaced
ON some models the "HIGH TEMP WASH" button is labled power scrub instead of high temp wash
so in that case push POWER SCRUB-HEATED DRY-POWER SCRUB-HEATED DRY then cancel as described above
In case the E-7 error returns and the flowmeter needs to be replaced the part number for it is W10195536
Gene
Aug 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
I cannot unlock the commands ; the red light ( paddock ) is on
Push the HeatDry and High Temperature buttons at the same time
Then:
punch these buttons back and forth until lights light up (about 5 times) then:
Hit cancel
Jan 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore dishwasher blinking lights
Dear friend,
ngfam at you service! happy to assist!
The blinking lights are called codes and this is warning you that there is a technical problem. Probably an electronic failure some where. This can only be diagnosed by a trained service tech!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 29, 2008 | Dishwashers
My kenmore dishwasher had green clean blinking light
push cancel or start resume the green clean light will blink after every wash cycle to tell you the dishes are clean on some you just open the door to clear it on some you push stop or cancel
Feb 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
"Clean light" keeps blinking; dishwasher won't start new cycle
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
Feb 19, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
818 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
