Question about Harman Kardon AVR 340 Receiver
No audio sound, Reciver going to protection mode
I disconected all speakers from reciver and it still go to protection mode and I can not manipulate it with the remote control?
What are my options? If I need to have it fixed what is the expected cost for this 4 year old unit? How can I find out if it is still under warrenty if I cant find the paper work (I know we bought extended warrenty)?
    President:
  • Harman Kardon Master
  • 1,114 Answers
If you bought the extended warranty, you need to go where you purchased it and they can look it up on their computer system. If it's out of warranty, the repair cost is debatable. Between 125-175 average. 50% of the cost.
Posted on Jun 03, 2010
Wont turn on
tuner setting might be default only in stereo only. do you have passive or active speakers?
Apr 10, 2014 | Harman Kardon AVR 240 Receiver
Reciver is going to protection mode and sound turns off
is some speakers is defective, or not present (connected), check all cables
Jun 06, 2010 | Harman Kardon AVR 340 Receiver
Reciver goes into protect mode as soon as I turn it on.
Remove speaker wires and try again. If it still goes into protect mode, the problem is internal...shorted power transistors or some other fault. Check fuses also.
Apr 01, 2010 | Harman Kardon HK 3480 Receiver
I get a protected message in my reciver str dh 500 reciver
THE GOAL HEAR IS TO DETERMINE IF THE INSTALLATION IS CAUSING YOUR PROTECTION FAULT OR IS IT THE RECEIVER ITSELF HAVING INTERNAL DAMAGE. REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION, THEN THE RECEIVER WILL NEED TO BE SERVICED, AS YOU HAVE TOTALLY SIMULATED A BENCHED CONDITION THAT IS TOTALLY INDEPENDENT OF YOUR INSTALLATION. MOST TIMES, THE RECEIVE WILL GO INTO PROTECTION WHEN IT SEES AN EXCESSIVE LOAD WHEN TURNING UP THE VOLUME, WHICH IS USUALLY CAUSED BY TOO MANY SPEAKERS OR DAMAGED SPEAKERS, BUT IF NO SPEAKERS CONNECTED, THEN IT IS USUALLY BECAUSE THE RECEIVER SEE AN EXCESSIVE LOAD DUE TO ITS OUTPUT SECTION BEING DAMAGED. IN ANY CASE, ONCE REPAIRED, YOU MUST CHECK YOUR SPEAKERS FOR BURNED VOICE-COILS, WHICH WILL IMPOSE AN EXCESSIVE LOAD TO THE AMPLIFIER AND CAN CAUSE IT TO FAIL AGAIN. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 14, 2010 | Sony STR-DE475 Receiver
As soon as i turn on my STR-SE391 reciver the protection is on
It is unlikely that the pushing of buttons caused the problem. The protect flashing means that a problem was detected and the system has shutdown to prevent further damage. The most common cause of this is a failure of the output transistors. Plan on a parts cost between $20-$40 for this repair.
Dan
Oct 31, 2009 | Sony Audio Players & Recorders
Front left and right speakers don't put out sound
Hit the button  "speakers/a/b/off" on the left hand side of the front panel until it shows that "speakers b"  are turned on.
Jan 11, 2009 | Yamaha HTR-6130 Receiver
No sond from speakers but with headphone jack
there is no problem with the amplifier audio,check some resistors or disconections near the spkr terminals.
Oct 21, 2008 | Sony STR-DE605 Receiver
My KLH 2400 tuner plays wonderful and then clicks off and then on....and then off....
Suzie, your reciver is going into a protection mode. There is a problem with one of your speakers, the wiring, or +with the reciver itself. If you know how to use a multimeter, then you can test the resistance of the speaker, as if one speaker was partally shorted this problem would occor. If you have another set of speakers, try them. If not then you will need to have the reciver bench checked for a fault.
Oct 07, 2006 | KLH KL2400 Tuner
Problem adding wsp155 wireless speakers.
You must check with the instalation gude for the wireless speaker to see if the connection to the reciver is a high impedence or low impedence... If its like most wireless set-ups its going to be a high impedence output from the reciver to the transmitter part of the speakers. That would be from the RCA jacks in the back of the reciver maked line out or tape out. If you want to use them for a specific speaker output , some recivers have an output jack that would be labeled center sperker out but would be an RCA type jack ect ect. If your reciver dosent have that you can in a higher end audio store get an adaptor to convert the speaker output to a high impedence, But I dont recomend that as some of the adaptors do cause excessive strain on the output section of the amp or reciver.. If you buy a good one though you should be fine.. You get what you pay for.. Good Luck
Aug 06, 2006 | RCA WSP150 Main / Stereo Speaker
Harman Kardon AVR 340 Receiver Logo
241 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
