Question about GE Heating & Cooling
I have a window air conditioner and while moving it i punctured what i believe to be the condenser coil. it was a pressureized line on the back with the aluminum fins around it. Is this repairable/replaceable?
  • 360 Answers
yes, its is repairable, but it depands on the extent of the damage. The area of the condenser that was punctured will be sealed up and the air conditioner will be gas.
Call a repairman, and have him check the condenser in other to ascertain the level of damage, so that you will know if it will be repaired or replaced.
Take care.
Posted on Jun 03, 2010
I have a 5200 btu window unit not getting cold, can you help me
Try cleaning both of the coils inside the unit. If the coils in the back (condenser) are dirty, it will raise the head pressure and reduce the capacity. This will only help if nothing else is wrong (low or no charge).
Aug 25, 2013 | Maytag Chassis Built-In Air Conditioner...
Getting excessive condensation causing water problems at base of unit. Bought new pump but problem returned. Cleaned lines to outside by using wet/dry vac. How do I get to evaporator coil to spray it and...
Hello, in order to get to the evaporator coil you must cut into the plenum above the Furnace. This will require sheet metal tools and being very careful not to puncture the coil. Many times a cracked condensate pan under the evapoartor coil can cause water to leak down to the base of the unit.
Sep 15, 2011 | Ruud UBHC Air Conditioner
Ok..here's one. I have entire air duct system that is condensating ON THE OUTSIDE, UNDERNEATH. I noticed the problem before and after cleaning the coil in a closet air handler. Air runs fine, cools normal....
not moving enough air or duct work is in a unconditioned space and needs to be insulate. what are your freon pressures, suction and liquid line temps, and indoor wetbulb
Sep 20, 2009 | Heating & Cooling
Air conditioner not working properly
You can pull the inside of the unit out of the case to inspect the back coils mainly to see if there is any blockage. Note the screws on the bottom of the housing the holds the coils take the screws out and very gently take the coil and move out a little. It will flex enough to clean the coils. Just don't hit it with very high pressure water cause it will bend the fins that go around the coils. I have done a bunch of window units this way and you would not believe the difference it makes. Let unit dry out and re-assemble. Let me know if you need anything else.. ken
May 25, 2009 | LG LB8000ER Air Conditioner
WHERE IS A/C LOW PRESSURE SWITCH ON 1998 SUBU LEGACY 2.5L
Follow the return line from the compressor to the Condenser coil. The pressure switch should be located on that line.
Apr 25, 2009 | Coleman Mach 15 Air Conditioner
Window unit air conditioner
Sounds like a full cleanning job or the drain line is plugging up. First , check for A 10* lean toward the back of the unit for proper drainnage, 2- check for good air flow thru the front coils--(dirty filter --dirty coil and last ,add some clorox bleach all across the front coil while off>)
Aug 24, 2008 | GE APN10AA Portable Air Conditioner
A/C NOT COOLING
I am thinking more along the lines that you have a restriction somewhere in the condenser sheet coil, or the condenser line coming from the compressor. If you have no suction pressure this would explain a restriction.
May 28, 2008 | Intertherm P3RA-048K Air Conditioner
Ac unit
Reprocess the system.
Feb 24, 2008 | LG GL6000ER Air Conditioner
Leak repair Samsung window air conditioner
Modern window units intentionally do not allow the water to drain directly, they want the fan blade to sling the water on to the condensor (the coil that is outside) to aid in cooling actually helps the unit cool better in high outside temps, it also evaporates it this way, depending on where the hole was drilled it may be able to be repaired, if it was just a copper tube it will be less expensive than replacing the whole coil. Since its a relative inexpensive unit anyway the labor and freon may be more than its worth. Lesson learned dont drill a hole in the base it lowers it's efficiency and can lead to a punctured freon line.
Sep 29, 2007 | Heating & Cooling
Heating & Cooling Logo
51 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
