Question about LG LFX25960 Bottom Freezer French Door Refrigerator
Unit will not hold temp - LG LFX25960 Bottom Freezer French Door Refrigerator
  • LG Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerUnit will not hold temp - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 04, 2010
Why is the unit freezing? It is a TRUE TSSU-60-16.
Turn down the temp and move produce item closer to the front. The air exits the evaporator at around 28 degrees. Possible you need a thermostat.
Feb 04, 2013 | True TSSU-60-16-DS-ST-ADA Dual Sided...
How to set temperature on GE Profile PSS26NGPA WW?
Press and hold temp up button then press quick freeze button at the same time, your temp settings will be displayed on display for fridge and freezer, fridge temp is + and freezer -, cycle by pressing quick freeze, set temps by up and down temp buttons, once done, push vacation button. your temps are now set, turn the unit off for 2 mins the turn on. reaction is now set and normal. regards Russ
Jul 03, 2012 | GE Refrigerators
Lemair wine fridge not holding temp.sounds to be going ok but not cooling.temp keeps rising????.will not hold temp you press on digital readout.thks in advance
Hi.
If the unit looks like it is working regularly, but it does not keep the regular 14C temperature, then the problem is either defrost system or need for gas recharge.
Disconnect power and perform a full defrost leaving the unit off overnight. If the problem disappear, then the fault was the defrost system in the unit. If the problem comes back in a couple of days, then the defrost thermostat must be replaced.
If the problem comes back immediately after defrost, then you need a gas recharge. When problem is the compressor you hear clicking and humming, or motor does not start at all.
If you need recharge, parts or repair contact Lemair. Here their website. Contact page link is at the top.
Regards.
Ginko
May 17, 2011 | Refrigerators
My programmable thermostat does not work properly. When I attempt to push "temporary hold" and set a temp, it responds sometimes but will not continue to hear the house. OR it does not respond...
you should hear the themostat make a light click when it calls for heat...the hold or as you said temporary hold overides any programming you have and should maintain that temperature you are setting it on indefinetely of until the next programmed cycle... to check and make sure the unit is actually working properly try it again ... actually go after you hold the setting and see if unit is working...digital thermostat have a five minute time delay built in so from the time you press hold and raise the temperature above house temp a few degrees start a counter for 5 mins... if the unit does not come on then unplug the unit or reset breakers to heat and try again watching the unit to see if anything happens...is this a gas unit or electric unit? if the unit never responds then go to thermostat and remove cover take a small jumper wire and jump out the "r" terminal and the "w"terminal which is power and heat circuit see if it comes on if it does and should immediately as this way bypasses the thermostat operation then you have a faulty t-stat.
Jan 11, 2011 | Honeywell Programmable Thermostat Heater
My stat set @factory set up I want to set as manual so Ican control when we want on or off. As I work shift.
Manual should tell you how to do this or you can set the temp for what you want it to be and press the hold button and it should stay on the temp setting unit you push the hold button again to release it from hold
Nov 27, 2010 | Heating & Cooling
This unit has a manual thermostat. Is there a way
60 IS A DREAM TEMP MOST UNITS WILL NEVER REACH THESE TEMPS. THERE NOT MADE TO. AT 60 YOU LOWER THE HEAT ABSORPTION INSIDE AND OUTSIDE AND WITHOUT HEAT IT BEGINS TO ICE UP WHEN IT IS 70 INSIDE AND 70 OUT SIDE YOU WILL ICE UP 75 IS GOOD SETTING. IF YOUR TSTAT HAS A HOLD BUTTON SET TEMP AND PRESS HOLD THAT MY HELP
Apr 20, 2010 | LG LXA1030ACL Air Conditioner
My Uline ? Model U-217RS-O is 14 months old. The problem I have is the temp will not go below 38. What can I do?
Ok On the display hold the up arrow for 5 seconds then let go. It will tell you the temperature. Do you have and er at the display? Is the unit outside? What is the temperature(ambient) around the unit? If you hold the up and down arrows together for 5 seconds then release it will show you thermistor temperature for 2,3, and 4 You should only get 2 to give a temperature. 1=refrigerator temp and 2=evaporator temp.
Make sure the condenser is clean from dust.
Jun 28, 2009 | U-Line ?chelon 2175RB-00
I have a thermo king super 2 unit,that will not hold 36deg it just keeps going until it reaches 10deg.It has no trouble holding temp @ 10deg or less.I have replaced the temp control and it still does the...
Check your pilot solenoid. It may not be switching the 3 way valve. I have seen this many times. No codes in unit at all but temp goes passed setpoint
Apr 29, 2009 | Freezers
Programming code not working
Go to this web page to find the text answer below: http://www.fixya.com/support/t233614-reprogram_hv_board
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 :WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Aug 03, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
How do i reprogram my HV board?
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 SECS.-4.CONTROL WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Oct 26, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
LG LFX25960 Bottom Freezer French Door Refrigerator Logo
104 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
