Question about Whirlpool GEW9250 Electric Dryer
Dryer not working correctly
The diplay turns on but it shows sensing but the dryer does spin to turn on
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryerdryer not working correctly - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 04, 2010
Water does not turn off during spin cycle
Hi Robert!
If a washer unit is not advancing correctly to the next setting or cycle you could have a few issues. The main control board is not communicating correctly to the rest of the unit; the fill sensor and water valve sensor(s) are not operating properly; or the unit is not sensing enough water has been added to the unit. I would strongly suggest to contact a service professional to test all areas of the unit before repairing any further.
Mar 28, 2013 | Frigidaire FEX831CS Top Load Stacked...
What is wrong with my Kenmore Elite Quiet Pak 4 HE3 Electric Dryer?
Might be a2 things: Vent blockage causing overheat OR bad thermistor. Repair clinic shows how to replace it:
PART AND VIDEO
Note: Make sure you order the correct thermistor for your dryer
Dec 05, 2012 | Dryers
I turn the dryer on (Duet GEW9250pw1) and it just says "sensing" but wont start up...
HI. Your unit is equipped with an electrode(moisture sensor). This sensor helps the unit, in conjunction with the thermostats, to dry the contents during the cycle selected. This error is concerning this sensors integrity. It may be covered with lint, in return, preventing it to sense the moisture correctly, or the sensor may be damaged as well. It is locate just behind the Grill on the outlet lint screen door. I recommend to clean this sensor properly. if the unit continues to show the error code(sensing), this will confirm that the sensor is damaged, and it must be replaced in this case.
Oct 29, 2009 | Whirlpool GEW9250 Electric Dryer
I have an ariston amd 129 washer dryer. F-10 keeps coming up on diplay
F10 - Pressure switch not sensing correctly. blow in to switch gently it should click. blow into pipe should be clear.
Oct 14, 2009 | Ariston Technologies Washing Machines
Dryer not turning
you need a new drum belt
Jul 31, 2009 | Hoover Dryers
Magtag Dryer MDE2400 Dryer won't turn off
On our Maytag dryer, the looping marquee lights mean that the dryer is in "wrinkle" mode. This means that the wrinkle mode has been selected. In this mode, the dryer continues to rotate on and off after the heat cycle has ended. It does this to keep the clothes from wrinkling -- and it displays the looping lights.
Jul 24, 2009 | Maytag MDE2400A Electric Dryer
Another Whirlpool Cabrio Sensing issue
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
Mar 29, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer problem
You need to listen for the motor working ? Open the dryer door hold the door switch in and start the dryer . A buzzing sound may indicate a bad motor. If you hear a slight spinning noise ,it may just be the belt.
Sep 24, 2008 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
