Question about Toshiba Tecra A6-EZ6311 Notebook
Toshiba Tecra a6-ez6311 Removing Power-on Password
Toshiba Tecra a6-ez6311,Workmate set a power-on password. He can not remember it. How do i remove the Power-on Password
    Problem Solver:
  • 17 Answers
Unplug and open laptop and remove BIOS battery and leave unplugged and this will reset BIOS.
Posted on Jun 04, 2010
Tecra 8200 password
use bios password code for reset bios password
Removing BIOS password on Toshiba Satellite Laptop - YouTube
The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS. To clear the CMOS, you must remove the battery from
Jun 18, 2014 | Toshiba Tecra 8200 PT820U-OFG8C801...
Tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 | Computers & Internet
How to disable bios password on toshiba tecra A11-15Z laptop
dear sir "
this is not a just password this is a supervoiser password of toshiba tecra a11 please give me a stronge solution of this cheap password .
Apr 23, 2012 | Toshiba Computers & Internet
My tecra A6-ez6311 won't boot up when 'hot'.
I am pretty sure you have a root kit virus. Some would try to fix this, and some to be certain will wipe the disk and start over.
I try to hunt out the problem. Every computer that acts like this that I have seen have been Toshiba's with 512 to 1megmb of memory. They do have issues with the power plug being lose which is attached to the battery charge, so do not rule that out. Heat and time are what it could also be. You may have both a virus and power issue. it happens but not often. If it is virus only, I can fix this remotely with my services for $180 money back. I can tell in the fist hour if I can get it. Might not be worth it.
e
Nov 20, 2011 | Toshiba Tecra A6-EZ6311 Notebook
The password bios is closed. Its model is TECRA A6. Can you send me the password
We can't send you the password, but you can reset it. To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 29, 2010 | Toshiba Tecra A6-EZ6311 Notebook
How to reset bios password on a Toshiba Tecra A6-EZ6311 LAPTOP?
Hi. Here's a link on how to reset the Bios password fro your Laptop.
Nov 04, 2010 | Computers & Internet
Cant change anything my sisterf orgot the ad pass
I assume you have permission to remove the password. There is a program on the internet called active @ Password changer that will do the job. you can find it here http://www.password-changer.com/ but you will have to pay for it.
good luck
Jan 29, 2009 | Toshiba Tecra A9-S9012X Notebook
Non responsive
ok start your computer pressing f8 key and boot in safe mode then you can goto system tools and restore your computer to the time it was good earlier hope it works
Jan 27, 2009 | Toshiba Tecra A6-EZ6311 Notebook
Tecra a6 device manager , drivers req ethernet, mass storage, network controller, pci driver
hey just go to thoshobas website and select support and then fing your model & download the driver !
Jan 07, 2009 | Toshiba Tecra A6-EZ6311 Notebook
Toshiba Tecra A6-EZ6311 Notebook Logo
662 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
