Question about Siemens Gigaset A580 IP Cordless Phone
Gigaset A580 IP working with skype.
When I receive a call from on line number from skype ......my gigaset replaywith a error 404 not found , what is the issue?
CORDLESSGURU
  • 106 Answers
SOURCE: my siemens gigaset 4215 and 4000 don't work and need some kind of code whats the code?
Hello, Almost never is it the handset that is bad when those symptoms occur. It sounds as if your base has gotten hit by a power surge and won't boot (the handset now can't "talk to" the base and its always searching for it). Most people report this after a storm has passed through their area. You can try re-registering the handset to the base, but unfortunately it probably won't work, sorry. You can order the base only and register your handset to the replacement base when you get it. To order a replacement base using google, search for Siemens Cordless Repair and click the first non sponsored link. Good Luck
Posted on Jan 11, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: Siemens Gigaset 2420 corded unit resets when calls received
Your caller id log is full, you can fix your phone by pressing the Calls button, then the delete button over and over until it is empty. This will fix your problem without deleting all your programming.
Posted on Feb 10, 2008
SOURCE: Problem Siemens Gigaset 4000 and 4200
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
  • 9 Answers
SOURCE: Gigaset 8825 cordless phone pin reset
The default PIN for base and handsets is 0000 - if it has not been changed
  • Press Menu on Handset
  • Scroll to Mobile Settings - press ok
  • Scroll to Local Settings - press ok
  • Scroll to Chang Pin - press ok
  • Enter Current handset PIN - press ok
  • Enter New PIN - press ok
  • Display will show Confirm - Reenter PIN - press ok
Posted on Dec 26, 2008
SOURCE: Gigaset 8800 PIN reset
  1. Turn the handset off by pressing and holding the PWR key.
  2. While holding down the keys 1, 4, and 7, turn the handset back on.
  3. It will display "Handset Service".
  4. While this message is displayed, type in the numbers 4 6 8 5 4 6 3 (the word "hotline") on the number pad.
  5. The phrase "Settings Reset to Default" for a second or two and the handset will power itself off.
Note: When you turn the handset back on, the handset PIN will be reset to 0000.
Posted on Jun 02, 2009
How do I fix my siemens landline phone?
well lightening does do bad things to telephones . that are always plugged in to electric and phone lines
Feb 25, 2015 | Siemens Gigaset A58H DECT 6.0 Digital...
Siemens a580 error 404
Hi all error codes are here
http://www.gigaset.com/fileadmin/legacy-assets/errorcodes_eng.htm
Sep 10, 2013 | Siemens Gigaset A580 IP Cordless Phone
How do you connect Gigaset N300a IP to Skype?
Free Skype calls are for computer to computer. If you want to dial a corded or cordless phone you have to buy minutes
Mar 24, 2013 | Siemens Gigaset SL785 DECT 6.0 Expandable...
The second handset won;t let me phone out
  • Open the Web Configurator
  • Open the menu "Settings" - "Telephony" - "Audio"
  • Activate the option "No" next to "Allow 1 VoIP call only"
Feb 05, 2013 | Siemens Gigaset A580 IP Cordless Phone
How do i set up skype on my gigaset c610 IP phone
I haven't used it, but this might be what you are looking for.
Skype USB Interface M34
http://gigaset.com/hq/en/product/GIGASETM34USB.html
Mar 05, 2012 | Lands Phones
Where can I download hungarian specifications for A580IP the Gigaset phone. How do I set up my Skype and justvoip telephone service for this phone.
Azt hiszem, hogy magyar nyelven nem letezik. Nezd oda: http://goo.gl/iACdB. There are different versions, it seems, and hopefully you can find your answer.
Jun 17, 2011 | Siemens Gigaset A580 IP Cordless Phone
I am trying to update the firmware on my new A580IP phone using my web browser connected to the base station. I get a transmission error "0" every time. Is the default download web site...
According to the effectiveness of the past.
To update the firmware for gigaset A580ip not require you to download it,
just do the update directly through gigaset on-line
follow the steps below.
1> Menu » Settings » Base » Firmware Update
2> Enter base station system PIN (default setting: 0000)
3> Press the display key "Yes" to start the download
If your firmware is already up to date, the handset informs you. No action is needed then.
How to check for your firmware version:
Via Web Configurator: Status » Firmware version » The first 5 digits indicate the number of the firmware update
If you are in a call (> 8 sec): Menu » Service-Info » Scroll to list entry number 4. The first 5 digits indicate the number of the firmware update
regards
Apr 13, 2011 | Siemens Gigaset A580 IP Cordless Phone
The handset display cannot be seen, the backlighting is working. A580IP handset.
the display unit is not functioning... it is either the problem with the bus(wires) connecting the display and the board, or the problem with the display IC...
backlight is an ordinary led light, it will continue to work whenever there is a power supply to it...
Aug 09, 2010 | Siemens Gigaset A580 IP Cordless Phone
Siemens Gigaset A580 IP Cordless Phone Logo
801 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
