Kenmore Elite filling w/ Water when not running
I have a kenmore elite washer that is filling with water when the washer is not in operation. When it is actually on and washing clothes it drains properly. I will take the clothes out - no water. Come back a couple of days later and there is water sitting in the drum. Not sure what the problem might be?
  • 4,070 Answers
Your water inlet valve on the back where the water supply comes in is leaking. It needs replacing.
Posted on Jun 03, 2010
Why does my Kenmore Elite HE3 fill with water when it's off
The water valves are leaking usually from grit in the seat of the valve. They are a pair and can be easily replaced.
Aug 03, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
My kenmore elite HE3 fills up with water when it is not running.
Hi... if your Washer is filling and its not running... you need a new water valve
Mar 30, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore elite smartwash quiet pak 9 he4t the washer starts filing water when the washer is turned off.
This is symptomatic of a malfunctioning water control valve- not closing fully- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 19, 2011 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite washer will not fill.
yes there is a water inlet valve . it is the blue valve your water hoses connect to on the rear of the washer, they get sediment built up inside and get stuck , cost $26.50 from Repairclinic.com just go to site .find parts,then type in your model#
Jan 21, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE 5t
Low or no water supply, hot or cold side or water pressure switch not switching over to indicate fully filled though if this happens drain motor will continue to run continuously while f-20 flashes
Jan 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
